Skip to content
Snippets Groups Projects
Commit 566a9dee authored by Véronique Chaffard's avatar Véronique Chaffard
Browse files
Merge branch 'master' of git+ssh://git.renater.fr:2222/osug-doi
parents 0b983e6d a0fa610a
No related branches found
No related tags found
No related merge requests found
Showing
with 111 additions and 81 deletions
...@@ -32,7 +32,7 @@ ...@@ -32,7 +32,7 @@
<directory>${project.basedir}/target/</directory> <directory>${project.basedir}/target/</directory>
<outputDirectory>bin/</outputDirectory> <outputDirectory>bin/</outputDirectory>
<includes> <includes>
<include>doi-csv-trunk.jar</include> <include>${project.artifactId}-${project.version}.jar</include>
</includes> </includes>
</fileSet> </fileSet>
</fileSets> </fileSets>
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
PROJECT=AMMA-CATCH PROJECT=AMMA-CATCH
DO_GET=1 DO_GET=0
CONF=../conf/$PROJECT CONF=../conf/$PROJECT
INPUT=$CONF/inputs/ INPUT=$CONF/inputs/
...@@ -17,5 +17,5 @@ export JAVA_OPTS="$JAVA_OPTS -Dfile.encoding=UTF-8" ...@@ -17,5 +17,5 @@ export JAVA_OPTS="$JAVA_OPTS -Dfile.encoding=UTF-8"
export APP_CMD="java $JAVA_OPTS -jar doimgr-trunk.jar --v=3" export APP_CMD="java $JAVA_OPTS -jar doimgr-trunk.jar --v=3"
echo "JAVA_OPTS: $JAVA_OPTS" #echo "JAVA_OPTS: $JAVA_OPTS"
...@@ -18,19 +18,38 @@ mkdir -p $TMP ...@@ -18,19 +18,38 @@ mkdir -p $TMP
# 0. GetRecords from sedoo: # 0. GetRecords from sedoo:
if [ $DO_GET -eq 1 ] if [ $DO_GET -eq 1 ]
then then
for url in $(cat $INPUT/urls.txt)
# Prepare data access url mapping:
echo "# DOI_suffix;data_access_url" > $CONF/doi_url_data_access.csv
for row in $(cat $INPUT/doi_id.txt)
do do
doi=${row%;*}
id=${row#*;}
echo "doi: $doi"
# echo "id: $id"
url="http://mistrals.sedoo.fr/xml/bdToIso.php?datsId=$id"
if [ ${url:0:4} = "http" ]; then if [ ${url:0:4} = "http" ]; then
echo $url # echo $url
# wget -O $TMP/${doi}.xml $url
# cp $TMP/${doi}.xml $INPUT/mistrals/
# fix bad <xml> header (manual)
filename=$(basename $url) xsltproc -o $INPUT/${doi}.csv --stringparam DOI_SUFFIX_START "$PROJECT" --stringparam USE_END_DATE "true" $XSL/csw2txt_ohmcv.xsl $INPUT/mistrals/${doi}.xml
id=${filename##*id=}
echo $id # replace Hymex ID by DOI
EXPR="s/identifier:DOI;.*/identifier:DOI;10.5072\/${doi}/"
wget -O $TMP/$id.xml $url sed -i "$EXPR" $INPUT/${doi}.csv
xsltproc -o $INPUT/$id.csv --stringparam DOI_SUFFIX_START "$PROJECT" --stringparam USE_END_DATE "true" $XSL/csw2txt_ohmcv.xsl $TMP/$id.xml # add url data access:
url="http://www.ohmcv.fr/P000_download.php?fic=$id"
echo "${doi};$url" >> $CONF/doi_url_data_access.csv
if [ $? -ne 0 ]; then if [ $? -ne 0 ]; then
echo "xsltproc failed" echo "xsltproc failed"
#Name;affiliation;nameIdentifier:ORCID #Name;affiliation;nameIdentifier:ORCID
Christophe Peugeot;IRD/HSM;0000-0003-2161-125X Christophe Peugeot;IRD/HSM;0000-0003-2161-125X
Emmanuel Lawin;UAC/INE;0000-0003-4751-3439
Eric Mougin;CNRS/GET;0000-0002-7569-5906 Eric Mougin;CNRS/GET;0000-0002-7569-5906
Gérémy Panthou;UGA/IGE; Gérémy Panthou;UGA/IGE;
Ibrahim Bouzou Moussa;UAM/Dept Géographie;0000-0002-3140-8987 Ibrahim Bouzou Moussa;UAM/Dept Géographie;0000-0002-3140-8987
Jean-Martial Cohard;UGA/IGE; Jean-Martial Cohard;UGA/IGE;
Jérôme Demarty;IRD/HSM;0000-0001-5173-9030 Jérôme Demarty;IRD/HSM;0000-0001-5173-9030
Marielle Gosset;IRD/GET;0000-0003-1064-7003 Marielle Gosset;IRD/GET;0000-0003-1064-7003
Monique Oï;IRD/HSM;
Pierre Hiernaux;CNRS/GET;0000-0002-1764-9178 Pierre Hiernaux;CNRS/GET;0000-0002-1764-9178
Sylvie Galle;IRD/IGE;0000-0002-3100-8510 Sylvie Galle;IRD/IGE;0000-0002-3100-8510
Thierry Lebel;IRD/IGE;0000-0002-1297-6751 Thierry Lebel;IRD/IGE;0000-0002-1297-6751
<?xml version="1.0" encoding="utf-8"?> <?xml version="1.0" encoding="utf-8"?>
<html xmlns="http://www.w3.org/1999/xhtml"> <html xmlns="http://www.w3.org/1999/xhtml">
<body> <body>
Data is available online through the web portal http://www.ohmcv.fr/P400_bdd.html. The data can be accessed from the link on this page. You will then be directed to the OHMCV website and you will be asked for your e-mail address. A download link will then be sent to this e-mail address.
<br/>
To dowload a specific dataset:
<ol>
<li>TODO: describe how to ...</li>
</ol>
</body> </body>
</html> </html>
OHMCV.DSD.PVI.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=436
OHMCV.DSD.MRE.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=679
OHMCV.DSD.SEF.12-14.1;http://www.ohmcv.fr/P000_download.php?fic=744
OHMCV.DSD.VB1.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=680
OHMCV.DSD.VB2.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=681
OHMCV.DSD.VB3.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=682
OHMCV.RTS.AUZ.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=656
OHMCV.REA.CEV.07-14.1;http://www.ohmcv.fr/P000_download.php?fic=1183
OHMCV.HSS.CLA.11-14.1;http://www.ohmcv.fr/P000_download.php?fic=993
OHMCV.ADV.CLA.13-14.1;http://www.ohmcv.fr/P000_download.php?fic=1349
OHMCV.ERO.PRA.11-13.1;http://www.ohmcv.fr/P000_download.php?fic=1347
OHMCV.LIM.CLA.12-14.1;http://www.ohmcv.fr/P000_download.php?fic=994
OHMCV.SMO.CLA.13-14.1;http://www.ohmcv.fr/P000_download.php?fic=1350
# Generated by csw2txt.xsl; # Generated by csw2txt.xsl;
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-1349-ce3f5508acd9 # ID;74bbe692-584b-11e3-1349-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.1349 identifier:DOI;10.5072/OHMCV.ADV.CLA.13-14.1
title;Acoustic Doppler Velocimeter IQ Plus, Claduègne title;Acoustic Doppler Velocimeter IQ Plus, Claduègne
publicationYear;2013 publicationYear;2013
subject:main;Velocity profile subject:main;Surface Water
subject:main;Terrestrial Hydrosphere > Surface Water
subject:main;ADCP > Acoustic Doppler Current Profiler subject:main;ADCP > Acoustic Doppler Current Profiler
subject:main;Fixed Observation Stations subject:main;Fixed Observation Stations
contributorName:WorkPackageLeader;Nord Guillaume;affiliation;LTHE contributorName:WorkPackageLeader;Nord Guillaume;affiliation;LTHE
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0679-ce3f5508acd9 # ID;74bbe692-584b-11e3-0679-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.679 identifier:DOI;10.5072/OHMCV.DSD.MRE.11-14.1
title;DSD network, Mont-Redon title;DSD network, Mont-Redon
publicationYear;2011 publicationYear;2011
subject:main;Atmospheric conditions subject:main;Atmospheric conditions
subject:main;Fall Velocity subject:main;Precipitation
subject:main;Droplet size distribution subject:main;Precipitation Rate
subject:main;Atmosphere > Precipitation subject:main;Droplet Size
subject:main;Atmosphere > Precipitation > Droplet Size
subject:main;Atmosphere > Precipitation > Precipitation Rate
subject:main;DISDROMETERS subject:main;DISDROMETERS
subject:main;Ground networks
subject:main;Hydrometeorological sites
contributorName:WorkPackageLeader;Boudevillain Brice;affiliation;LTHE contributorName:WorkPackageLeader;Boudevillain Brice;affiliation;LTHE
date:Collected;2011-09-10/ date:Collected;2011-09-10/
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0436-ce3f5508acd9 # ID;74bbe692-584b-11e3-0436-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.436 identifier:DOI;10.5072/OHMCV.DSD.PVI.11-14.1
title;DSD network, Pradel-Vignes title;DSD network, Pradel-Vignes
publicationYear;2009 publicationYear;2009
subject:main;Atmosphere > Precipitation > Droplet Size subject:main;Droplet Size
date:Collected;2009-03-12/ date:Collected;2009-03-12/
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0744-ce3f5508acd9 # ID;74bbe692-584b-11e3-0744-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.744 identifier:DOI;10.5072/OHMCV.DSD.SEF.12-14.1
title;DSD network, Saint-Etienne-de-Fontbellon title;DSD network, Saint-Etienne-de-Fontbellon
publicationYear;2012 publicationYear;2012
date:Collected;2012-09-05/2015-12-31 date:Collected;2012-09-05/2015-12-31
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0680-ce3f5508acd9 # ID;74bbe692-584b-11e3-0680-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.680 identifier:DOI;10.5072/OHMCV.DSD.VB1.11-14.1
title;DSD network, Villeneuve-de-Berg-1 title;DSD network, Villeneuve-de-Berg-1
date:Collected;2011-11-24/ date:Collected;2011-11-24/
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0681-ce3f5508acd9 # ID;74bbe692-584b-11e3-0681-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.681 identifier:DOI;10.5072/OHMCV.DSD.VB2.11-14.1
title;DSD network, Villeneuve-de-Berg-2 title;DSD network, Villeneuve-de-Berg-2
subject:main;Droplet size distribution subject:main;Precipitation Amount
subject:main;Atmosphere > Precipitation > Droplet Size subject:main;Precipitation Rate
subject:main;Atmosphere > Precipitation > Precipitation Rate subject:main;Droplet Size
subject:main;Atmosphere > Precipitation > Precipitation Amount
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0682-ce3f5508acd9 # ID;74bbe692-584b-11e3-0682-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.682 identifier:DOI;10.5072/OHMCV.DSD.VB3.11-14.1
title;DSD network, Villeneuve-de-Berg-3 title;DSD network, Villeneuve-de-Berg-3
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-1347-ce3f5508acd9 # ID;74bbe692-584b-11e3-1347-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.1347 identifier:DOI;10.5072/OHMCV.ERO.PRA.11-13.1
title;Runoff and erosion plots, Pradel title;Runoff and erosion plots, Pradel
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Suspended Solids subject:main;Discharge/Flow
subject:main;Terrestrial Hydrosphere > Surface Water > Stage Height subject:main;Stage Height
subject:main;Terrestrial Hydrosphere > Surface Water > Discharge/Flow subject:main;Suspended Solids
subject:main;SEDIMENT METERS subject:main;SEDIMENT METERS
subject:main;WATER LEVEL GAUGES subject:main;WATER LEVEL GAUGES
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0993-ce3f5508acd9 # ID;74bbe692-584b-11e3-0993-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.993 identifier:DOI;10.5072/OHMCV.HSS.CLA.11-14.1
title;Gazel and Claduègne hydro-sedimentary stations title;Gazel and Claduègne hydro-sedimentary stations
subject:main;Surface velocity subject:main;Discharge/Flow
subject:main;Terrestrial Hydrosphere > Surface Water > Stage Height subject:main;Surface Water
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Water Temperature subject:main;Turbidity
subject:main;Terrestrial Hydrosphere > Surface Water > Discharge/Flow subject:main;Conductivity
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Conductivity subject:main;Stage Height
subject:main;Terrestrial Hydrosphere > Surface Water subject:main;Water Temperature
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Turbidity subject:main;Suspended Solids
subject:main;CONDUCTIVITY METERS
subject:main;RADAR > Radio Detection and Ranging
subject:main;Ground networks subject:main;Ground networks
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0994-ce3f5508acd9 # ID;74bbe692-584b-11e3-0994-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.994 identifier:DOI;10.5072/OHMCV.LIM.CLA.12-14.1
title;limnimeter network, Gazel and Claduègne catchments title;limnimeter network, Gazel and Claduègne catchments
subject:main;Terrestrial Hydrosphere > Surface Water > Water Pressure subject:main;Atmospheric Pressure Measurements
subject:main;Terrestrial Hydrosphere > Surface Water > Water Depth subject:main;Water Depth
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Water Temperature subject:main;Conductivity
subject:main;Terrestrial Hydrosphere > Water Quality/Water Chemistry > Conductivity subject:main;Water Pressure
subject:main;Atmosphere > Atmospheric Pressure > Atmospheric Pressure Measurements subject:main;Water Temperature
subject:main;Atmosphere > Atmospheric Temperature > Air Temperature subject:main;Air Temperature
subject:main;CTD > Conductivity, Temperature, Depth subject:main;CTD > Conductivity, Temperature, Depth
subject:main;PRESSURE SENSORS subject:main;PRESSURE SENSORS
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-1183-ce3f5508acd9 # ID;74bbe692-584b-11e3-1183-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.1183 identifier:DOI;10.5072/OHMCV.REA.CEV.07-14.1
title;Pluviometric reanalysis Cévennes-Vivarais title;Pluviometric reanalysis Cévennes-Vivarais
publicationYear;2007 publicationYear;2007
subject:main;Atmosphere > Precipitation > Rain subject:main;Rain
subject:main;Geographic Regions subject:main;Geographic Regions
subject:main;Value-added dataset subject:main;Value-added dataset
date:Collected;2007-01-22/2012-12-15 date:Collected;2007-01-22/2012-12-15
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-0656-ce3f5508acd9 # ID;74bbe692-584b-11e3-0656-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.656 identifier:DOI;10.5072/OHMCV.RTS.AUZ.11-14.1
title;Hpiconet rain gauge network title;Hpiconet rain gauge network
publicationYear;2010 publicationYear;2010
subject:main;Atmosphere > Precipitation > Precipitation Amount subject:main;Precipitation Amount
subject:main;RAIN GAUGES subject:main;RAIN GAUGES
contributorName:WorkPackageLeader;Molinié Gilles;affiliation;LTHE contributorName:WorkPackageLeader;Molinié Gilles;affiliation;LTHE
date:Collected;2010-10-09/2014-11-04 date:Collected;2010-10-09/2014-11-04
description:Abstract;"A report of the raingauge survey is available in the file tournee_etat_stations.xlsx
A interactive software based on R allows to interactively plot and extract the data to the EXCEL format.
(http://www.ohmcv.fr/plot_hpiconet_series.zip)"
description:SeriesInformation;The data provided are 5-min rainfall amounts at 19 raingauges situated in an area of about 7x5km^2. Rainfall data are provided only for rainfall events which are defined as a succession of rainy days during which at least 2 raingauges have recorded 10mm or more. description:SeriesInformation;The data provided are 5-min rainfall amounts at 19 raingauges situated in an area of about 7x5km^2. Rainfall data are provided only for rainfall events which are defined as a succession of rainy days during which at least 2 raingauges have recorded 10mm or more.
geoLocationPlace;Hpiconet
geoLocationBox;4.44838 44.54993 4.5148 44.6141 geoLocationBox;4.44838 44.54993 4.5148 44.6141
# END; # END;
# BEGIN; # BEGIN;
# ID;74bbe692-584b-11e3-1350-ce3f5508acd9 # ID;74bbe692-584b-11e3-1350-ce3f5508acd9
identifier:DOI;10.5072/OHMCV.1350 identifier:DOI;10.5072/OHMCV.SMO.CLA.13-14.1
title;Soil moisture sensor network, Gazel and Claduègne catchments title;Soil moisture sensor network, Gazel and Claduègne catchments
subject:main;Land Surface > Soils > Soil Moisture/Water Content subject:main;Soil Moisture/Water Content
subject:main;SOIL MOISTURE PROBE subject:main;SOIL MOISTURE PROBE
contributorName:WorkPackageLeader;Vandervaere Jean-pierre;affiliation;LTHE contributorName:WorkPackageLeader;Vandervaere Jean-pierre;affiliation;LTHE
0% Loading or .
Please register or to comment
