Skip to content
Snippets Groups Projects
Commit 0c082433 authored by bourgesl's avatar bourgesl
Browse files
last minute corrections for CRYOBSCLIM_CDP
parent c7113ccd
No related branches found
No related tags found
No related merge requests found
......@@ -18,18 +18,18 @@ contributorName:WorkPackageLeader;"Erwan Le Gac";;;;
contributorName:WorkPackageLeader;"Marie Dumont";;;;
date:Collected;1993-08-01/2017-07-31;;;;
format;netCDF;;;;
description:SeriesInformation;"This dataset contains the hourly measured meteorological properties in netCDF format. The dataset contains the following variables as a function of time (UTC) :
- flag (in situ flag, value = 1 for in situ measurement, 0 for SAFRAN reanalysis)
- ZREF (reference height for temperature measurements, m)
- UREF (reference height for wind measurements, m)
- Tair (near surface air temperature, K)
- Qair (near surface air specific humidity, kg/kg)
- Wind (wind speed, m s-1)
- ZREF (reference height for air temperature measurements, m)
- UREF (reference height for Wind measurements, m)
- Tair (air temperature at ZREF, K)
- Qair (air specific humidity at ZREF, kg/kg)
- Wind (wind speed at UREF, m s-1)
- Rainf (rainfall rate, kg m-2 s-1)
- Snowf (snowfall rate, kg m-2 s-1)
- LWdown (surface incident longwave radiation, W m-2)
- SCA_SWdown ( surface incident diffuse shortwave radiation, W m-2)
- DIR_SWdown ( surface incident direct shortwave radiation, W m-2)
- Psurf ( surface pressure, Pa climatological value)
- SCA_SWdown (surface incident diffuse shortwave radiation, W m-2)
- DIR_SWdown (surface incident direct shortwave radiation, W m-2)
- Psurf (surface pressure, Pa, climatological value)
- NEB (nebulosity between 0 and 1, no unit)
A full description of the data and of the sensors location is available in Lejeune et al. (ESSD, 2018).";;;;
......@@ -16,7 +16,7 @@ contributorName:WorkPackageLeader;"Erwan Le Gac";;;;
date:Collected;1960-08-01/2017-07-31;;;;
format;netCDF;;;;
description:SeriesInformation;"This dataset contains the daily measured meteorological and snow properties in netCDF format. The dataset contains the following variables as a function of time (UTC) :
- snow_depth_auto (m)
- snow_depth_pit (m)
- snow_depth_pit_south (m)
......@@ -27,7 +27,7 @@ description:SeriesInformation;"This dataset contains the daily measured meteorol
- swe_pit_north (kg m-2)
- Tmin (K, minimum air temperature)
- Tmax (K, maximum air temperature)
- total_precipitation (kg m-2)
- total_precipitation (kg m-2 , uncorrected for wind effects)
- rain (kg m-2)
- snow (kg m-2)
- albedo_daily (no unit)
......@@ -23,7 +23,7 @@ relatedIdentifier:Cites:URL;https://www.umr-cnrm.fr/spip.php?rubrique218&lang=en
relatedIdentifier:IsPartOf:DOI;10.5072/CRYOBSCLIM.CDP.2018;;;;
rights;"Data access and use are ruled by the CRYOBS-CLIM data policy.";;;;
rights;"Always quote below citation to Lejeune et al. (2018) when using data.
Lejeune, Y., Dumont, M., Panel J.-M., Lafaysse, M., Lapalus, P., Le Gac, E., Lesaffre, B. and Morin, S., 57 years (1960-2017) of snow and meteorological observations from a mid-altitude mountain site (Col de Porte, France, 1325 m alt.), Earth System Science Data, X(X), X-X, doi:X/essd-X. The following acknowledging sentence should appear in publications using Cryobs-Clim-CDP data and products: ""Cryobs-Clim Col de Porte is funded by Meteo France,, the Institut National des Sciences de l’Univers (INSU/CNRS), and the Observatoire des Sciences de l’Univers de Grenoble (OSUG / Université Grenoble Alpes)”. You are invited to contact the PI(s) or lead scientist for more information about the data and to include the acknowledgement sentence in any publication using the data.";;;;
Lejeune, Y., Dumont, M., Panel J.-M., Lafaysse, M., Lapalus, P., Le Gac, E., Lesaffre, B. and Morin, S., 57 years (1960-2017) of snow and meteorological observations from a mid-altitude mountain site (Col de Porte, France, 1325 m alt.), Earth System Science Data, X(X), X-X, doi:X/essd-X. The following acknowledging sentence should appear in publications using Cryobs-Clim-CDP data and products: ""Cryobs-Clim Col de Porte is funded by Meteo France, the Institut National des Sciences de l’Univers (INSU/CNRS), and the Observatoire des Sciences de l’Univers de Grenoble (OSUG / Université Grenoble Alpes)”. You are invited to contact the PI(s) or lead scientist for more information about the data and to include the acknowledgement sentence in any publication using the data.";;;;
description:Abstract;"This dataset is part of the Cryobs-Clim-CDP (CRYosphere, an OBServatory of the CLIMate – Col de Porte) observatory";;;;
geoLocationPlace;"Col de Porte Observatory";;;;
geoLocationPoint;"45.30 5.77";;;;
0% Loading or .
Please register or to comment
