Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • samanost/sicom_image_analysis_project
  • gerayelk/sicom_image_analysis_project
  • jelassiy/sicom_image_analysis_project
  • chardoto/sicom_image_analysis_project
  • chaarim/sicom_image_analysis_project
  • domers/sicom_image_analysis_project
  • elmurrt/sicom_image_analysis_project
  • sadonest/sicom_image_analysis_project
  • kouddann/sicom_image_analysis_project
  • mirabitj/sicom-image-analysis-project-mirabito
  • plotj/sicom_image_analysis_project
  • torrem/sicom-image-analysis-project-maxime-torre
  • dzike/sicom_image_analysis_project
  • daip/sicom_image_analysis_project
  • casanovv/sicom_image_analysis_project
  • girmarti/sicom_image_analysis_project
  • lioretn/sicom_image_analysis_project
  • lemoinje/sicom_image_analysis_project
  • ouahmanf/sicom_image_analysis_project
  • vouilloa/sicom_image_analysis_project
  • diopb/sicom_image_analysis_project
  • davidale/sicom_image_analysis_project
  • enza/sicom_image_analysis_project
  • conversb/sicom_image_analysis_project
  • mullemat/sicom_image_analysis_project
25 results
Show changes
Commits on Source (130)
Showing
with 1270 additions and 0 deletions
File mode changed from 100755 to 100644
File added
This diff is collapsed.
Source diff could not be displayed: it is too large. Options to address this: view the blob.
"""The main file for the reconstruction.
This file should NOT be modified except the body of the 'run_reconstruction' function.
Students can call their functions (declared in others files of src/methods/your_name).
import numpy as np
import functions as fu
from src.forward_model import CFA
import importlib
importlib.reload(fu)
def run_reconstruction(y: np.ndarray, cfa: str) -> np.ndarray:
"""Performs demosaicking on y.
Args:
y (np.ndarray): Mosaicked image to be reconstructed.
cfa (str): Name of the CFA. Can be bayer or quad_bayer.
Returns:
np.ndarray: Demosaicked image.
# Performing the reconstruction.
# TODO
return fu.extrapolate_cfa(y,cfa)
File added
import numpy as np
from src.methods.Chardon_tom.utils import *
import pywt
#!!!!!!!! It is normal that the reconstructions lasts several minutes (3min on my computer)
Args:
Returns:
# Define constants and operators
cfa_name = 'bayer' # bayer or quad_bayer
input_shape = (y.shape[0], y.shape[1], 3)
op = CFA(cfa_name, input_shape)
res = op.adjoint(y)
N,M = input_shape[0], input_shape[1]
#interpolating green channel
for i in range (N):
for j in range (M):
if res[i,j,1] ==0:
neighbors = get_neighbors(res,1,i,j,N,M)
weights = get_weights(res,i,j,1,N,M)
res[i,j,1] = interpolate_green(weights, neighbors)
#first intepolation of red channel
for i in range (1,N,2):
for j in range (0,M,2):
neighbors = get_neighbors(res,0,i,j,N,M)
neighbors_G = get_neighbors(res,1,i,j,N,M)
weights = get_weights(res,i,j,0,N,M)
res[i,j,0] = interpolate_red_blue(weights,neighbors, neighbors_G)
# second interpolation of red channel
for i in range (N):
for j in range (M):
if res[i,j,0] ==0:
res[i,j,0] = interpolate_green(weights, neighbors)
#first interpolation of blue channel
for i in range (0,N,2):
for j in range (1,M,2):
neighbors = get_neighbors(res,2,i,j,N,M)
weights = get_weights(res,i,j,2,N,M)
res[i,j,2] = interpolate_red_blue(weights, neighbors, neighbors_G)
#second interpolation of blue channel
for i in range (N):
for j in range (M):
if res[i,j,2] ==0:
res[i,j,2] = interpolate_green(weights,neighbors)
# k=0
# while k<2 :
# for i in range(input_shape[0]):
# for j in range(input_shape[1]):
# res[i][j][1] = correction_green(res,i,j,N,M)
# res[i][j][0] = correction_red(res,i,j,N,M)
# res[i][j][2] = correction_blue(res,i,j,N,M)
# k+=1
res[res>1] = 1
res[res<0] = 0
return res
import numpy as np
import pywt
def get_neighbors (img,channel,i,j,N,M):
P1 = img[(i-1)%N,(j-1)%M,channel]
P2 = img[(i-1)%N,j%M,channel]
P3 = img[(i-1)%N,(j+1)%M,channel]
P4 = img[i%N,(j-1)%M,channel]
P5 = img[i%N,j%M,channel]
P6 = img[i%N,(j+1)%M,channel]
P7 = img[(i+1)%N,(j-1)%M,channel]
P8 = img[(i+1)%N,j%M,channel]
P9 = img[(i+1)%N,(j+1)%M,channel]
return np.array([P1,P2,P3,P4,P5,P6,P7,P8,P9])
def get_derivatives(neighbors):
[P1, P2, P3, P4, P5, P6, P7, P8, P9] = neighbors
D_x = (P4 - P6)/2
D_y = (P2 - P8)/2
D_xd = (P3 - P7)/(2*np.sqrt(2))
D_yd = (P1 - P9)/(2*np.sqrt(2))
return ([D_x, D_y, D_xd, D_yd])
def get_weights(mosaic_image, i, j, channel, N, M):
derivatives_neigbors = []
for l in range(-1, 2):
for L in range(-1, 2):
derivatives_neigbors.append(get_derivatives(
get_neighbors(mosaic_image, channel, i+l, j+L, N, M)))
[Dx, Dy, Dxd, Dyd] = derivatives_neigbors[4]
E1 = 1/np.sqrt(1 + Dyd**2 + derivatives_neigbors[0][3]**2)
E2 = 1/np.sqrt(1 + Dy**2 + derivatives_neigbors[1][1]**2)
E3 = 1/np.sqrt(1 + Dxd**2 + derivatives_neigbors[2][2]**2)
E4 = 1/np.sqrt(1 + Dx**2 + derivatives_neigbors[3][0]**2)
E6 = 1/np.sqrt(1 + Dxd**2 + derivatives_neigbors[5][2]**2)
E7 = 1/np.sqrt(1 + Dy**2 + derivatives_neigbors[6][1]**2)
E8 = 1/np.sqrt(1 + Dyd**2 + derivatives_neigbors[7][3]**2)
E9 = 1/np.sqrt(1 + Dx**2 + derivatives_neigbors[8][0]**2)
E = [E1, E2, E3, E4, E6, E7, E8, E9]
return E
def interpolate_green(weights, neighbors):
[E1, E2, E3, E4, E6, E7, E8, E9] = weights
I5 = (E2*P2 + E4*P4 + E6*P6 + E8*P8)/(E2 + E4 + E6 + E8)
return (I5)
def interpolate_red_blue(weights, neighbors, green_neighbors):
[G1, G2, G3, G4, G5, G6, G7, G8, G9] = green_neighbors
I5 = G5*(E1*P1/G1 + E3*P3/G3 + E7*P7/G7 + E9*P9/G9)/(E1 + E3 + E7 + E9)
return (I5)
def correction_green(res,i,j,N,M):
[G1,G2,G3,G4,G5,G6,G7,G8,G9] = get_neighbors(res,1,i,j,N,M)
[R1,R2,R3,R4,R5,R6,R7,R8,R9] = get_neighbors(res,0,i,j,N,M)
[B1,B2,B3,B4,B5,B6,B7,B8,B9] = get_neighbors(res,2,i,j,N,M)
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,1,N,M)
Gb5 = R5*((E2*G2)/B2 + (E4*G4)/B4 + (E6*G6)/B6 + (E8*G8)/B8)/(E2 + E4 + E6 + E8)
Gr5 = B5*((E2*G2)/R2 + (E4*G4)/R4 + (E6*G6)/R6 + (E8*G8)/R8)/(E2 + E4 + E6 + E8)
G5 = (Gb5 + Gr5)/2
return G5
def correction_red(res,i,j,N,M) :
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,0,N,M)
R5 = G5*((E1*R1)/G1 + (E2*R2)/G2 + (E3*R3)/G3 + (E4*R4)/G4 + (E6*R6)/G6 + (E7*R7)/G7 + (E8*R8)/G8 + (E9*R9)/G9)/(E1 + E2 + E3 + E4 + E6 + E7 + E8 + E9)
return R5
def correction_blue(res,i,j,N,M) :
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,2,N,M)
B5 = G5*((E1*B1)/G1 + (E2*B2)/G2 + (E3*B3)/G3 + (E4*B4)/G4 + (E6*B6)/G6 + (E7*B7)/G7 + (E8*B8)/G8 + (E9*B9)/G9)/(E1 + E2 + E3 + E4 + E6 + E7 + E8 + E9)
return B5
File added
import numpy as np
from scipy.signal import correlate2d
def malvar_he_cutler(y: np.ndarray, op: CFA ) -> np.ndarray:
"""Performs demosaicing using the malvar-he-cutler algorithm
Args:
op (CFA): CFA operator.
y (np.ndarray): Mosaicked image.
Returns:
red_mask, green_mask, blue_mask = [op.mask[:, :, 0], op.mask[:, :, 1], op.mask[:, :, 2]]
mosaicked_image = np.float32(y)
demosaicked_image = np.empty(op.input_shape)
if op.cfa == 'quad_bayer':
filters = get_quad_bayer_filters()
else:
filters = get_default_filters()
demosaicked_image = apply_demosaicking_filters(
mosaicked_image,demosaicked_image, red_mask, green_mask, blue_mask, filters
return demosaicked_image
def get_quad_bayer_filters():
coefficient_scale = 0.03125
return {
"G_at_R_and_B": np.array([
[0, 0, 0, 0, -1, -1, 0, 0, 0, 0],
[0, 0, 0, 0, 2, 2, 0, 0, 0, 0],
[-1, -1, 2, 2, 4, 4, 2, 2, -1, -1],
]) * coefficient_scale,
"R_at_GR_and_B_at_GB": np.array([
[0, 0, 0, 0, 0.5, 0.5, 0, 0, 0, 0],
[0, 0, -1, -1, 0, 0, -1, -1, 0, 0],
[-1, -1, 4, 4, 5, 5, 4, 4, -1, -1],
"R_at_GB_and_B_at_GR": np.array([
[0, 0, -1, -1, 4, 4, -1, -1, 0, 0],
[0.5, 0.5, 0, 0, 5, 5, 0, 0, 0.5, 0.5],
"R_at_B_and_B_at_R": np.array([
[0, 0, 0, 0, -1.5, -1.5, 0, 0, 0, 0],
[0, 0, 2, 2, 0, 0, 2, 2, 0, 0],
[-1.5, -1.5, 0, 0, 6, 6, 0, 0, -1.5, -1.5],
def get_default_filters():
coefficient_scale = 0.125
return {
[0, 0, -1, 0, 0],
[0, 0, 2, 0, 0],
[-1, 2, 4, 2, -1],
[0, 0, 2, 0, 0],
[0, 0, -1, 0, 0]
[0, 0, 0.5, 0, 0],
[0, -1, 0, -1, 0],
[-1, 4, 5, 4, -1],
[0, -1, 0, -1, 0],
[0, 0, 0.5, 0, 0]
[0, 0, -1, 0, 0],
[0, -1, 4, -1, 0],
[0.5, 0, 5, 0, 0.5],
[0, -1, 4, -1, 0],
[0, 0, -1, 0, 0]
[0, 0, -1.5, 0, 0],
[0, 2, 0, 2, 0],
[-1.5, 0, 6, 0, -1.5],
[0, 2, 0, 2, 0],
[0, 0, -1.5, 0, 0]
def apply_demosaicking_filters(image, res, red_mask, green_mask, blue_mask, filters):
red_channel = image * red_mask
green_channel = image * green_mask
blue_channel = image * blue_mask
# Create the green channel after applying a filter
green_channel = np.where(
np.logical_or(red_mask == 1, blue_mask == 1),
correlate2d(image, filters['G_at_R_and_B'], mode="same", boundary="symm"),
green_channel
# Define masks for extracting pixel values
red_row_mask = np.any(red_mask == 1, axis=1)[:, np.newaxis].astype(np.float32)
red_col_mask = np.any(red_mask == 1, axis=0)[np.newaxis].astype(np.float32)
blue_row_mask = np.any(blue_mask == 1, axis=1)[:, np.newaxis].astype(np.float32)
blue_col_mask = np.any(blue_mask == 1, axis=0)[np.newaxis].astype(np.float32)
def update_channel(channel, row_mask, col_mask, filter_key):
return np.where(
np.logical_and(row_mask == 1, col_mask == 1),
correlate2d(image, filters[filter_key], mode="same", boundary="symm"),
channel
# Update the red channel and blue channel
red_channel = update_channel(red_channel, red_row_mask, blue_col_mask, 'R_at_GR_and_B_at_GB')
red_channel = update_channel(red_channel, blue_row_mask, red_col_mask, 'R_at_GB_and_B_at_GR')
blue_channel = update_channel(blue_channel, blue_row_mask, red_col_mask, 'R_at_GR_and_B_at_GB')
blue_channel = update_channel(blue_channel, red_row_mask, blue_col_mask, 'R_at_GB_and_B_at_GR')
# Update R channel and B channel again
red_channel = update_channel(red_channel, blue_row_mask, blue_col_mask, 'R_at_B_and_B_at_R')
blue_channel = update_channel(blue_channel, red_row_mask, red_col_mask, 'R_at_B_and_B_at_R')
res[:, :, 0] = red_channel
res[:, :, 1] = green_channel
res[:, :, 2] = blue_channel
return res
\ No newline at end of file
import numpy as np
from src.methods.EL_MURR_Theresa.malvar import malvar_he_cutler
Args:
Returns:
op = CFA(cfa, input_shape)
res = malvar_he_cutler(y,op)
return res
# 2023
# Authors: Mauro Dalla Mura and Matthieu Muller
File added
import numpy as np
from scipy.signal import convolve2d
def malvar(y: np.ndarray, op: CFA) -> np.ndarray:
Malvar-He-Cutler demosaicing algorithm for Bayer pattern.
# Convert the mosaicked image to the initial estimated channels.
z = op.adjoint(y)
# Define convolution kernels
kernel_G_at_RB = np.array([[0, 0, -1, 0, 0], [0, 0, 2, 0, 0], [-1, 2, 4, 2, -1], [0, 0, 2, 0, 0], [0, 0, -1, 0, 0]]) / 8
kernel_RB_at_G = np.array([[0, 0, 0.5, 0, 0], [0, -1, 0, -1, 0], [-1, 4, 5, 4, -1], [0, -1, 0, -1, 0], [0, 0, 0.5, 0, 0]]) / 8
kernel_RB_at_RB = np.array([[0, 0, -1.5, 0, 0], [0, 2, 0, 2, 0], [-1.5, 0, 6, 0, -1.5], [0, 2, 0, 2, 0], [0, 0, -1.5, 0, 0]]) / 8
# Interpolate each channel
R = z[:, :, 0]
G = z[:, :, 1]
B = z[:, :, 2]
mask = op.mask
R_m, G_m, B_m = mask[:, :, 0], mask[:, :, 1], mask[:, :, 2]
# Interpolate G at R and B locations
G = np.where(np.logical_or(R_m == 1, B_m == 1), convolve2d(y, kernel_G_at_RB, mode='same'), G)
# Interpolate R at G and B locations, B at R and G locations
R = np.where(np.logical_or(G_m == 1, B_m == 1), convolve2d(y, kernel_RB_at_G, mode='same'), R)
B = np.where(np.logical_or(R_m == 1, G_m == 1), convolve2d(y, kernel_RB_at_G, mode='same'), B)
# Interpolate R at B locations and B at R locations
R = np.where(B_m == 1, convolve2d(y, kernel_RB_at_RB, mode='same'), R)
B = np.where(R_m == 1, convolve2d(y, kernel_RB_at_RB, mode='same'), B)
# Combine channels
return np.clip(np.stack((R, G, B), axis=-1), 0, 1)
# 2023
import numpy as np
from src.methods.Elmehdi_lahmar.malvar import malvar
Run the demosaicing process using Malvar-He-Cutler algorithm for Bayer pattern.
Args:
y (np.ndarray): The mosaicked image to be reconstructed.
cfa (str): Name of the CFA, expected to be 'bayer'.
Returns:
np.ndarray: The demosaicked image.
if cfa != 'bayer':
raise ValueError("Malvar-He-Cutler demosaicing only supports Bayer CFA pattern.")
return malvar(y, op)
# 2023
# Importing libraries
import os
import colour
from colour_demosaicing import (
demosaicing_CFA_Bayer_bilinear,
demosaicing_CFA_Bayer_Malvar2004,
demosaicing_CFA_Bayer_Menon2007,
mosaicing_CFA_Bayer)
from src.utils import psnr,ssim
# Image path
image_pathes = ['images/img_1.png','images/img_2.png','images/img_3.png','images/img_4.png']
for i in image_pathes:
LIGHTHOUSE_IMAGE = colour.io.read_image(i)
img = LIGHTHOUSE_IMAGE
colour.plotting.plot_image(
colour.cctf_encoding(LIGHTHOUSE_IMAGE))
# Mosaicing
CFA = mosaicing_CFA_Bayer(LIGHTHOUSE_IMAGE)
colour.cctf_encoding(CFA),
text_kwargs={'text': 'Lighthouse - CFA - RGGB'})
colour.cctf_encoding(mosaicing_CFA_Bayer(LIGHTHOUSE_IMAGE, 'BGGR')),
text_kwargs={'text': 'Lighthouse - CFA - BGGR'});
# Demosaicing bilinear
colour.cctf_encoding(demosaicing_CFA_Bayer_bilinear(CFA)),
text_kwargs={'text': 'Demosaicing - Bilinear'});
recons_bilinear = colour.cctf_encoding(demosaicing_CFA_Bayer_bilinear(CFA))
# demosaicing Malvar
recons_malvar = colour.cctf_encoding(demosaicing_CFA_Bayer_Malvar2004(CFA))
colour.cctf_encoding(demosaicing_CFA_Bayer_Malvar2004(CFA)),
text_kwargs={'text': 'Demosaicing - Malvar (2004)'});
# demosaicing Menon
recons_menon = colour.cctf_encoding(demosaicing_CFA_Bayer_Menon2007(CFA))
colour.cctf_encoding(demosaicing_CFA_Bayer_Menon2007(CFA)),
text_kwargs={'text': 'Demosaicing - Menon (2007)'});
print('bilinear : ')
print(f'PSNR: {psnr(img, recons_bilinear):.2f}')
print(f'SSIM: {ssim(img, recons_bilinear):.4f}')
print('Malvar : ')
print(f'PSNR: {psnr(img, recons_malvar):.2f}')
print(f'SSIM: {ssim(img, recons_malvar):.4f}')
print('Menon')
print(f'PSNR: {psnr(img, recons_menon):.2f}')
print(f'SSIM: {ssim(img, recons_menon):.4f}')
File added
File added
