Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • daconcea/fidle
  • bossardl/fidle
  • Julie.Remenant/fidle
  • abijolao/fidle
  • monsimau/fidle
  • karkars/fidle
  • guilgautier/fidle
  • cailletr/fidle
  • talks/fidle
9 results
Show changes
Commits on Source (88)
Showing
with 9549 additions and 616 deletions
......@@ -2,5 +2,10 @@
*/.ipynb_checkpoints/*
__pycache__
*/__pycache__/*
/run/**
*/data/*
run/
GTSRB/data
IMDB/data
MNIST/data
VAE/data
BHPD/data/*
!BHPD/data/BostonHousing.csv
This diff is collapsed.
source diff could not be displayed: it is too large. Options to address this: view the blob.
German Traffic Sign Recognition Benchmark (GTSRB)
Introduction au Deep Learning (IDLE) - S. Arias, E. Maldonado, JL. Parouty - CNRS/SARI/DEVLOG - 2020
## Episode 2 : First Convolutions
Our main steps:
- Read H5 dataset
- Build a model
- Train the model
- Evaluate the model
## 1/ Import and init
%% Cell type:code id: tags:
``` python
import tensorflow as tf
from tensorflow import keras
from tensorflow.keras.callbacks import TensorBoard
import numpy as np
import h5py
import os,time,sys
from importlib import reload
sys.path.append('..')
import fidle.pwk as ooo
ooo.init()
## 2/ Load dataset
We're going to retrieve a previously recorded dataset.
For example: set-24x24-L
``` python
%%time
def read_dataset(name):
'''Reads h5 dataset from ./data
Arguments: dataset name, without .h5
Returns: x_train,y_train,x_test,y_test data'''
# ---- Read dataset
filename='./data/'+name+'.h5'
with h5py.File(filename) as f:
x_train = f['x_train'][:]
y_train = f['y_train'][:]
x_test = f['x_test'][:]
y_test = f['y_test'][:]
# ---- done
print('Dataset "{}" is loaded. ({:.1f} Mo)\n'.format(name,os.path.getsize(filename)/(1024*1024)))
x_train,y_train,x_test,y_test = read_dataset('set-24x24-L')
## 3/ Have a look to the dataset
We take a quick look as we go by...
``` python
print("x_train : ", x_train.shape)
print("y_train : ", y_train.shape)
print("x_test : ", x_test.shape)
print("y_test : ", y_test.shape)
ooo.plot_images(x_train, y_train, range(12), columns=6, x_size=2, y_size=2)
ooo.plot_images(x_train, y_train, range(36), columns=12, x_size=1, y_size=1)
## 4/ Create model
We will now build a model and train it...
Some models :
``` python
# A basic model
def get_model_v1(lx,ly,lz):
model = keras.models.Sequential()
model.add( keras.layers.Conv2D(96, (3,3), activation='relu', input_shape=(lx,ly,lz)))
model.add( keras.layers.MaxPooling2D((2, 2)))
model.add( keras.layers.Dropout(0.2))
model.add( keras.layers.Conv2D(192, (3, 3), activation='relu'))
model.add( keras.layers.Flatten())
model.add( keras.layers.Dense(1500, activation='relu'))
model.add( keras.layers.Dropout(0.5))
model.add( keras.layers.Dense(43, activation='softmax'))
return model
# A more sophisticated model
def get_model_v2(lx,ly,lz):
model.add( keras.layers.Conv2D(64, (3, 3), padding='same', input_shape=(lx,ly,lz), activation='relu'))
model.add( keras.layers.Conv2D(64, (3, 3), activation='relu'))
model.add( keras.layers.MaxPooling2D(pool_size=(2, 2)))
model.add( keras.layers.Conv2D(128, (3, 3), padding='same', activation='relu'))
model.add( keras.layers.Conv2D(128, (3, 3), activation='relu'))
model.add( keras.layers.Conv2D(256, (3, 3), padding='same',activation='relu'))
model.add( keras.layers.Conv2D(256, (3, 3), activation='relu'))
model.add( keras.layers.Dense(512, activation='relu'))
return model
# My sphisticated model, but small and fast
def get_model_v3(lx,ly,lz):
model.add( keras.layers.Conv2D(32, (3,3), activation='relu', input_shape=(lx,ly,lz)))
model.add( keras.layers.Dense(1152, activation='relu'))
return model
## 5/ Train the model
**Get the shape of my data :**
``` python
(n,lx,ly,lz) = x_train.shape
print("Images of the dataset have this folowing shape : ",(lx,ly,lz))
**Get and compile a model, with the data shape :**
``` python
model = get_model_v1(lx,ly,lz)
model.summary()
model.compile(optimizer = 'adam',
loss = 'sparse_categorical_crossentropy',
metrics = ['accuracy'])
**Train it :**
``` python
%%time
batch_size = 64
epochs = 5
# ---- Shuffle train data
x_train,y_train=ooo.shuffle_np_dataset(x_train,y_train)
# ---- Train
history = model.fit( x_train, y_train,
batch_size = batch_size,
epochs = epochs,
verbose = 1,
validation_data = (x_test, y_test))
**Evaluate it :**
``` python
max_val_accuracy = max(history.history["val_accuracy"])
print("Max validation accuracy is : {:.4f}".format(max_val_accuracy))
``` python
score = model.evaluate(x_test, y_test, verbose=0)
print('Test loss : {:5.4f}'.format(score[0]))
print('Test accuracy : {:5.4f}'.format(score[1]))
## Episode 3 : Tracking, visualizing and save models
Our main steps:
- Monitoring and understanding our model training
- Add recovery points
- Analyze the results
- Restore and run recovery pont
``` python
import numpy as np
import h5py
from sklearn.metrics import confusion_matrix
import seaborn as sn
import os, sys, time, random
ooo.init()
## 2/ Load dataset
Dataset is one of the saved dataset: RGB25, RGB35, L25, L35, etc.
First of all, we're going to use a smart dataset : **set-24x24-L**
(with a GPU, it only takes 35'' compared to more than 5' with a CPU !)
``` python
%%time
# ---- Read dataset
x_meta = f['x_meta'][:]
y_meta = f['y_meta'][:]
# ---- done
return x_train,y_train,x_test,y_test,x_meta,y_meta
x_train,y_train,x_test,y_test,x_meta,y_meta = read_dataset('set-24x24-L')
Note: Data must be reshape for matplotlib
``` python
## 4/ Create model
Some models...
``` python
# A basic model
return model
## 5/ Prepare callbacks
We will add 2 callbacks :
- **TensorBoard**
Training logs, which can be visualised with Tensorboard.
`#tensorboard --logdir ./run/logs`
IMPORTANT : Relancer tensorboard à chaque run
- **Model backup**
It is possible to save the model each xx epoch or at each improvement.
The model can be saved completely or partially (weight).
For full format, we can use HDF5 format.
%% Cell type:raw id: tags:
%%bash
# To clean old logs and saved model, run this cell
/bin/rm -r ./run/logs 2>/dev/null
/bin/rm -r ./run/models 2>/dev/null
/bin/mkdir -p -m 755 ./run/logs
/bin/mkdir -p -m 755 ./run/models
echo -e "Reset directories : ./run/logs and ./run/models ."
``` python
ooo.mkdir('./run/models')
ooo.mkdir('./run/logs')
# ---- Callback tensorboard
log_dir = "./run/logs/tb_" + ooo.tag_now()
tensorboard_callback = tf.keras.callbacks.TensorBoard(log_dir=log_dir, histogram_freq=1)
# ---- Callback ModelCheckpoint - Save best model
save_dir = "./run/models/best-model.h5"
bestmodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, monitor='accuracy', save_best_only=True)
# ---- Callback ModelCheckpoint - Save model each epochs
save_dir = "./run/models/model-{epoch:04d}.h5"
savemodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, save_freq=2000*5)
``` python
``` python
# model.summary()
model.compile(optimizer='adam',
loss='sparse_categorical_crossentropy',
metrics=['accuracy'])
**Train it :**
Note: The training curve is visible in real time with Tensorboard :
``` python
%%time
batch_size = 64
epochs = 30
# ---- Train
# Note: To be faster in our example, we can take only 2000 values
batch_size=batch_size,
epochs=epochs,
verbose=1,
validation_data=(x_test, y_test),
callbacks=[tensorboard_callback, bestmodel_callback, savemodel_callback] )
model.save('./run/models/last-model.h5')
**Evaluate it :**
``` python
``` python
## 6/ History
The return of model.fit() returns us the learning history
``` python
ooo.plot_history(history)
## 7/ Evaluation and confusion
``` python
y_pred = model.predict_classes(x_test)
conf_mat = confusion_matrix(y_test,y_pred, normalize="true", labels=range(43))
ooo.plot_confusion_matrix(conf_mat)
## 8/ Restore and evaluate
### 8.1/ List saved models :
``` python
!find ./run/models/
### 8.2/ Restore a model :
``` python
loaded_model = tf.keras.models.load_model('./run/models/best-model.h5')
# loaded_model.summary()
print("Loaded.")
### 8.3/ Evaluate it :
``` python
score = loaded_model.evaluate(x_test, y_test, verbose=0)
### 8.4/ Make a prediction :
``` python
# ---- Get a random image
i = random.randint(1,len(x_test))
x,y = x_test[i], y_test[i]
# ---- Do prediction
predictions = loaded_model.predict( np.array([x]) )
# ---- A prediction is just the output layer
print("\nOutput layer from model is (x100) :\n")
with np.printoptions(precision=2, suppress=True, linewidth=95):
print(predictions*100)
# ---- Graphic visualisation
print("\nGraphically :\n")
plt.figure(figsize=(12,2))
plt.bar(range(43), predictions[0], align='center', alpha=0.5)
plt.ylabel('Probability')
plt.ylim((0,1))
plt.xlabel('Class')
plt.title('Trafic Sign prediction')
plt.show()
# ---- Predict class
p = np.argmax(predictions)
# ---- Show result
print("\nPrediction on the left, real stuff on the right :\n")
ooo.plot_images([x,x_meta[y]], [p,y], range(2), columns=3, x_size=3, y_size=2)
if p==y:
print("YEEES ! that's right!")
else:
print("oups, that's wrong ;-(")
That's all folks !
``` python
## Episode 4 : Data augmentation
Our main steps:
- Increase and improve the learning dataset
``` python
import numpy as np
import h5py
ooo.init()
## 2/ Dataset loader
``` python
%%time
# ---- Read dataset
# ---- done
## 3/ Models
This is my model ;-)
``` python
# A basic model
return model
## 4/ Callbacks
We prepare 2 kind callbacks : TensorBoard and Model backup
``` python
%%bash
``` python
## 5/ Load and prepare dataset
### 5.1/ Load
``` python
x_train,y_train,x_test,y_test = read_dataset('set-48x48-L-LHE')
### 5.2/ Data augmentation
``` python
datagen = keras.preprocessing.image.ImageDataGenerator(featurewise_center=False,
featurewise_std_normalization=False,
width_shift_range=0.1,
height_shift_range=0.1,
zoom_range=0.2,
shear_range=0.1,
rotation_range=10.)
datagen.fit(x_train)
## 6/ Train the model
``` python
``` python
model = get_model_v3(lx,ly,lz)
# model.summary()
**Train it :**
Note : La courbe d'apprentissage est visible en temps réel avec Tensorboard :
``` python
%%time
batch_size = 64
epochs = 30
#x_train,y_train=ooo.shuffle_np_dataset(x_train,y_train)
# ---- Train
history = model.fit( datagen.flow(x_train, y_train, batch_size=batch_size),
steps_per_epoch = int(x_train.shape[0]/batch_size),
epochs=epochs,
verbose=1,
**Evaluate it :**
``` python
``` python
## 7/ History
``` python
## 8/ Evaluate best model
### 8.1/ Restore best model :
``` python
# best_model.summary()
print("Loaded.")
### 8.2/ Evaluate it :
``` python
**Plot confusion matrix**
``` python
That's all folks !
``` python
## Episode 5 : Full Convolutions
Our main steps:
- Try n models with n datasets
- Save a Pandas/h5 report
- Write to be run in batch mode
## 1/ Import
``` python
import numpy as np
import h5py
import os,time,json
import random
from IPython.display import display
VERSION='1.6'
## 2/ Init and start
``` python
# ---- Where I am ?
now = time.strftime("%A %d %B %Y - %Hh%Mm%Ss")
here = os.getcwd()
random.seed(time.time())
tag_id = '{:06}'.format(random.randint(0,99999))
# ---- Who I am ?
if 'OAR_JOB_ID' in os.environ:
oar_id=os.environ['OAR_JOB_ID']
else:
oar_id='???'
print('\nFull Convolutions Notebook')
print(' Version : {}'.format(VERSION))
print(' Now is : {}'.format(now))
print(' OAR id : {}'.format(oar_id))
print(' Tag id : {}'.format(tag_id))
print(' Working directory : {}'.format(here))
print(' TensorFlow version :',tf.__version__)
print(' Keras version :',tf.keras.__version__)
print(' for tensorboard : --logdir {}/run/logs_{}'.format(here,tag_id))
## 3/ Dataset loading
``` python
# ---- Read dataset
## 4/ Models collection
``` python
# A basic model
return model
return model
model.add(tf.keras.layers.Conv2D(32, (5, 5), padding='same', activation='relu', input_shape=(lx,ly,lz)))
model.add(tf.keras.layers.BatchNormalization(axis=-1))
model.add(tf.keras.layers.MaxPooling2D(pool_size=(2, 2)))
model.add(tf.keras.layers.Dropout(0.2))
model.add(tf.keras.layers.Conv2D(64, (5, 5), padding='same', activation='relu'))
model.add(tf.keras.layers.Conv2D(128, (5, 5), padding='same', activation='relu'))
model.add(tf.keras.layers.Flatten())
model.add(tf.keras.layers.Dense(512, activation='relu'))
model.add(tf.keras.layers.BatchNormalization())
model.add(tf.keras.layers.Dropout(0.4))
model.add(tf.keras.layers.Dense(43, activation='softmax'))
return model
## 5/ Multiple datasets, multiple models ;-)
``` python
def multi_run(datasets, models, datagen=None,
train_size=1, test_size=1, batch_size=64, epochs=16,
verbose=0, extension_dir='last'):
# ---- Logs and models dir
os.makedirs('./run/logs_{}'.format(extension_dir), mode=0o750, exist_ok=True)
os.makedirs('./run/models_{}'.format(extension_dir), mode=0o750, exist_ok=True)
# ---- Columns of output
output={}
output['Dataset']=[]
output['Size'] =[]
for m in models:
output[m+'_Accuracy'] = []
output[m+'_Duration'] = []
# ---- Let's go
for d_name in datasets:
print("\nDataset : ",d_name)
# ---- Read dataset
x_train,y_train,x_test,y_test = read_dataset(d_name)
d_size=os.path.getsize('./data/'+d_name+'.h5')/(1024*1024)
output['Dataset'].append(d_name)
output['Size'].append(d_size)
# ---- Get the shape
n_train = int(x_train.shape[0]*train_size)
n_test = int(x_test.shape[0]*test_size)
# ---- For each model
for m_name,m_function in models.items():
print(" Run model {} : ".format(m_name), end='')
# ---- get model
try:
model=m_function(lx,ly,lz)
# ---- Compile it
model.compile(optimizer='adam', loss='sparse_categorical_crossentropy', metrics=['accuracy'])
# ---- Callbacks tensorboard
log_dir = "./run/logs_{}/tb_{}_{}".format(extension_dir, d_name, m_name)
# ---- Callbacks bestmodel
save_dir = "./run/models_{}/model_{}_{}.h5".format(extension_dir, d_name, m_name)
# ---- Train
start_time = time.time()
if datagen==None:
# ---- No data augmentation (datagen=None) --------------------------------------
history = model.fit(x_train[:n_train], y_train[:n_train],
epochs = epochs,
verbose = verbose,
validation_data = (x_test[:n_test], y_test[:n_test]),
callbacks = [tensorboard_callback, bestmodel_callback])
else:
# ---- Data augmentation (datagen given) ----------------------------------------
history = model.fit(datagen.flow(x_train, y_train, batch_size=batch_size),
steps_per_epoch = int(n_train/batch_size),
epochs = epochs,
verbose = verbose,
# ---- Result
end_time = time.time()
duration = end_time-start_time
accuracy = max(history.history["val_accuracy"])*100
output[m_name+'_Accuracy'].append(accuracy)
output[m_name+'_Duration'].append(duration)
print("Accuracy={:.2f} and Duration={:.2f})".format(accuracy,duration))
except:
output[m_name+'_Accuracy'].append('0')
output[m_name+'_Duration'].append('999')
print('-')
return output
## 6/ Run !
``` python
print('\n---- Run','-'*50)
# --------- Datasets, models, and more.. -----------------------------------
# ---- For tests
# datasets = ['set-24x24-L', 'set-24x24-RGB']
# models = {'v1':get_model_v1, 'v4':get_model_v2}
# batch_size = 64
# epochs = 2
# train_size = 0.1
# test_size = 0.1
# with_datagen = False
# verbose = 0
# ---- All possibilities -> Run A
# datasets = ['set-24x24-L', 'set-24x24-RGB', 'set-48x48-L', 'set-48x48-RGB', 'set-24x24-L-LHE', 'set-24x24-RGB-HE', 'set-48x48-L-LHE', 'set-48x48-RGB-HE']
# models = {'v1':get_model_v1, 'v2':get_model_v2, 'v3':get_model_v3}
# batch_size = 64
# epochs = 16
# train_size = 1
# test_size = 1
# verbose = 0
# ---- Data augmentation -> Run B
datasets = ['set-48x48-RGB']
models = {'v2':get_model_v2}
batch_size = 64
epochs = 20
train_size = 1
test_size = 1
with_datagen = True
verbose = 0
if with_datagen :
zoom_range=0.2,
shear_range=0.1,
rotation_range=10.)
else:
datagen=None
# ---- Run
output = multi_run(datasets, models,
datagen=datagen,
train_size=train_size, test_size=test_size,
batch_size=batch_size, epochs=epochs,
verbose=verbose,
extension_dir=tag_id)
# ---- Save report
report={}
report['output']=output
report['description']='train_size={} test_size={} batch_size={} epochs={} data_aug={}'.format(train_size,test_size,batch_size,epochs,with_datagen)
report_name='./run/report_{}.json'.format(tag_id)
with open(report_name, 'w') as file:
json.dump(report, file)
print('\nReport saved as ',report_name)
print(f'Duration : {duration:.2f} s')
print('-'*59)
## 7/ That's all folks..
``` python
print('\n{}'.format(time.strftime("%A %-d %B %Y, %H:%M:%S")))
print("The work is done.\n")
``` python
## Episode 5.1 : Full Convolutions / run
Our main steps:
- Run Full-convolution.ipynb as a batch :
- Notebook mode
- Script mode
- Tensorboard follow up
## 1/ Run a notebook as a batch
To run a notebook :
```jupyter nbconvert --to notebook --execute <notebook>```
%%bash
# ---- This will execute and save a notebook
jupyter nbconvert --ExecutePreprocessor.timeout=-1 --to notebook --output='./run/full_convolutions' --execute '05-Full-convolutions.ipynb'
## 2/ Export as a script (better choice)
To export a notebook as a script :
```jupyter nbconvert --to script <notebook>```
To run the script :
```ipython <script>```
``` python
%%bash
# ---- This will convert a notebook to a notebook.py script
jupyter nbconvert --to script --output='./run/full_convolutions_B' '05-Full-convolutions.ipynb'
%% Output
[NbConvertApp] Converting notebook 05-Full-convolutions.ipynb to script
[NbConvertApp] Writing 11305 bytes to ./run/full_convolutions_B.py
``` python
!ls -l ./run/*.py
%% Output
-rw-r--r-- 1 pjluc pjluc 11305 Jan 21 00:13 ./run/full_convolutions_B.py
## 3/ Batch submission
Create batch script :
``` python
%%writefile "./run/batch_full_convolutions_B.sh"
#!/bin/bash
#OAR -n Full convolutions
#OAR -t gpu
#OAR -l /nodes=1/gpudevice=1,walltime=01:00:00
#OAR --stdout _batch/full_convolutions_%jobid%.out
#OAR --stderr _batch/full_convolutions_%jobid%.err
#OAR --project deeplearningshs
#---- For cpu
# use :
# OAR -l /nodes=1/core=32,walltime=01:00:00
# and add a 2>/dev/null to ipython xxx
# _ _ _
# | |__ __ _| |_ ___| |__
# | '_ \ / _` | __/ __| '_ \
# | |_) | (_| | || (__| | | |
# |_.__/ \__,_|\__\___|_| |_|
# Full convolutions
CONDA_ENV=deeplearning2
RUN_DIR=~/fidle/GTSRB
RUN_SCRIPT=./run/full_convolutions_B.py
# ---- Cuda Conda initialization
echo '------------------------------------------------------------'
echo "Start : $0"
source /applis/environments/cuda_env.sh dahu 10.0
source /applis/environments/conda.sh
conda activate "$CONDA_ENV"
# ---- Run it...
cd $RUN_DIR
ipython $RUN_SCRIPT
%% Output
Writing ./run/batch_full_convolutions_B.sh
``` python
%%bash
chmod 755 ./run/*.sh
chmod 755 ./run/*.py
ls -l ./run/*full_convolutions*
%% Output
-rwxr-xr-x 1 pjluc pjluc 1045 Jan 21 00:15 ./run/batch_full_convolutions_B.sh
-rwxr-xr-x 1 pjluc pjluc 611 Jan 19 15:53 ./run/batch_full_convolutions.sh
-rwxr-xr-x 1 pjluc pjluc 11305 Jan 21 00:13 ./run/full_convolutions_B.py
%%bash
``` python
Running Tensorboard from Jupyter lab
Vesion : 1.0
## 1/ Méthode 1 : Shell command
``` python
%%bash
tensorboard_start --logdir ./run/logs
``` python
%%bash
tensorboard_status
``` python
%%bash
tensorboard_stop
## Méthode 2 : Magic command
**Start**
``` python
%load_ext tensorboard
``` python
%tensorboard --port 21277 --host 0.0.0.0 --logdir ./run/logs
**Stop**
No way... use bash method
## Methode 3 : Tensorboard module
**Start**
``` python
import tensorboard.notebook as tsb
``` python
tsb.start('--port 21277 --host 0.0.0.0 --logdir ./run/logs')
**Check**
``` python
a=tsb.list()
%% Output
No known TensorBoard instances running.
**Stop**
``` python
!kill 214798
``` python
S. Aria, E. Maldonado, JL. Parouty
Objectives of this practical work
Traffic sign classification with **CNN**, using Tensorflow and **Keras**
About the dataset
Name : [German Traffic Sign Recognition Benchmark (GTSRB)](http://benchmark.ini.rub.de/?section=gtsrb)
Available [here](https://sid.erda.dk/public/archives/daaeac0d7ce1152aea9b61d9f1e19370/published-archive.html)
or on **[kaggle](https://www.kaggle.com/meowmeowmeowmeowmeow/gtsrb-german-traffic-sign)**
A nice example from : [Alex Staravoitau](https://navoshta.com/traffic-signs-classification/)
In few words :
- Images : Variable dimensions, rgb
- Train set : 39209 images
- Test set : 12630 images
- Classes : 0 to 42
Episodes
**[01 - Preparation of data](01-Preparation-of-data.ipynb)**
- Understanding the dataset
- Preparing and formatting data
- Organize and backup data
**[02 - First convolutions](02-First-convolutions.ipynb)**
- Read dataset
- Build a model
- Train the model
- Model evaluation
``` python
