Commit 21b82a82 authored by erwan's avatar erwan
Doc: add a section for the run/in statement
parent 5fc14d2d
LUTINSRC=../../lutin/src LUTINSRC=../../lutin/src
LUT2TEX= $(LURETTE_PATH)/utils/lutintolatex LUT2TEX=~/rdbg/utils/lutintolatex
SRCS=./commands.tex \ SRCS=./commands.tex \
./language.tex \ ./language.tex \
./objs/lutin.tex ./objs/gnuplotrif.tex ./objs/checkrif.tex \ ./objs/lutin.tex ./objs/gnuplotrif.tex ./objs/checkrif.tex \
...@@ -33,13 +33,13 @@ lutin-man.pdf: objs/main.pdf ...@@ -33,13 +33,13 @@ lutin-man.pdf: objs/main.pdf
# XXX ecrire un filtre pour rajouter de la coloration syntaxique !! # XXX ecrire un filtre pour rajouter de la coloration syntaxique !!
./objs/foo.c.tex: ./objs/foo.c.tex:
cat ../../examples/lutin/external_code/foo.c > ./objs/foo.c.tex cat ../../examples/external_code/foo.c > ./objs/foo.c.tex
# XXX idem # XXX idem
./objs/call_external_c_code.lut.tex:../../examples/lutin/external_code/call_external_c_code.lut ./objs/call_external_c_code.lut.tex:../../examples/external_code/call_external_c_code.lut
$(LUT2TEX) ../../examples/lutin/external_code/call_external_c_code.lut > ./objs/call_external_c_code.lut.tex $(LUT2TEX) ../../examples/external_*sccode/call_external_c_code.lut > ./objs/call_external_c_code.lut.tex
D=../../examples/lutin/up_and_down/$(shell ocamlc -version) D=../../examples/up_and_down/$(shell ocamlc -version)
objs/ud.rif: $(D)/test.rif.exp objs/ud.rif: $(D)/test.rif.exp
cp $< $@ cp $< $@
...@@ -49,13 +49,13 @@ objs/ud.rif: $(D)/test.rif.exp ...@@ -49,13 +49,13 @@ objs/ud.rif: $(D)/test.rif.exp
./objs/polar.lut.tex: ./objs/polar.lut.tex:
$(LUT2TEX) ../../examples/lutin/external_code/polar.lut > ./objs/polar.lut.tex $(LUT2TEX) ../../examples/external_code/polar.lut > ./objs/polar.lut.tex
./objs/ud.lut.tex: ./objs/ud.lut.tex:
$(LUT2TEX) ../../examples/lutin/up_and_down/ud.lut > ./objs/ud.lut.tex $(LUT2TEX) ../../examples/up_and_down/ud.lut > ./objs/ud.lut.tex
./objs/rabbit.lut.tex: ./objs/rabbit.lut.tex:
$(LUT2TEX) ../../examples/lutin/crazy-rabbit/rabbit.lut > ./objs/rabbit.lut.tex $(LUT2TEX) ../../examples/crazy-rabbit/rabbit.lut > ./objs/rabbit.lut.tex
./objs/gnuplotrif.tex:objs ./objs/gnuplotrif.tex:objs
...@@ -277,6 +277,8 @@ execution. This is the solution adopted in the operational semantics ...@@ -277,6 +277,8 @@ execution. This is the solution adopted in the operational semantics
\subsection{Exceptions} \subsection{Exceptions}
...@@ -335,6 +337,8 @@ start; this is the {\em reactivity principle}. ...@@ -335,6 +337,8 @@ start; this is the {\em reactivity principle}.
\subsection{Parallel composition} \subsection{Parallel composition}
\subsubsection{The \ES\ operator}
In order to put in parallel several statements, one can write:\\ In order to put in parallel several statements, one can write:\\
\OB \ES \syn{st1} \ES ... \ES \syn{stn} \CB\\ \OB \ES \syn{st1} \ES ... \ES \syn{stn} \CB\\
where the first \ES\ can be omitted. where the first \ES\ can be omitted.
...@@ -351,11 +355,13 @@ If (at least) one branch raises an exception, the whole statement ...@@ -351,11 +355,13 @@ If (at least) one branch raises an exception, the whole statement
raises the exception. raises the exception.
\paragraph{Parallelism vs stockastic directives} \subsubsection{Parallelism versus stockastic directives}
It is impossible to define a parallel composition which is fair It is impossible to define a parallel composition which is fair
according to the stockastic directive. according to the stockastic directive.
\begin{example} \begin{example}
Consider the statement:\\ Consider the statement:\\
\OB~\OB \BAR 1000: \syn{X} \BAR \syn{Y} \CB \OB~\OB \BAR 1000: \syn{X} \BAR \syn{Y} \CB
...@@ -399,6 +405,65 @@ raising are, like stockastic directives, treated in sequence from ...@@ -399,6 +405,65 @@ raising are, like stockastic directives, treated in sequence from
left to right. left to right.
\subsection{Calling nodes from nodes: a cheap parallel composition mechanism}
The \key{run}/\key{:=}/\key{in} construct is another way of executing
code in parallel. It is actually the only way of calling Lutin nodes
from other nodes. Nodes are executed, and the result of this
execution is re-injected in the calling nodes (as if an external call
is made).
Let i1, ...., im be m uncontrollable variables, and
o1, ..., on be n controllable ones, then
\key{run} (o1, ..., on) \key{:=} a\_node(i1, ...., im) \key{in} \syn{st}
will execute the node a\_node, and compute values for o1, ..., on that
will be substituted in \syn{st}. In \syn{st} o1, ..., om are therefore
uncontrollable.
Follows a working example that makes use of \key{run} statements:
\begin{example}
\begin{program}
\key{node} N() \key{returns} (\key{y}:int) = y = 0 \key{fby} \key{loop} y = pre y+1 \\
\key{node} incr(x:int) returns (y:\key{int}) = \key{loop} y = x+1 \\
\key{node} use\_run() \key{returns}(x:\key{int}) = \\
~~~ \key{exist} a,b:\key{int in} \\
~~~ \key{run} a := N() \key{in} \\
~~~ \key{run} b := incr(a) \key{in} \\
~~~ \key{run} x := incr(b) \key{in} \\
~~~ \key{loop} true
\end{program}
\end{example}
If the chosen values during a run make a constraint unsatisfiable, no
backtracking occurs. For instance, the following expression is very
likely to deadlock:
\begin{example}
\begin{program}
\key{run} x := within(0,100) \key{in} x = 42
\end{program}
\end{example}
Indeed, if 42 is not chosen during the call to the \key{within} node
(which definition is obvious), the constraint x=42 will fail.
This form of parallelism is cheaper, because contraints are solved
locally. But of course it is less powerful: constraints are not
merged, but solved in sequence (no backtracking). More detail on the
\key{run} semantics is provided in Section~\ref{run-function}.
...@@ -85,7 +85,7 @@ set of constraints. ...@@ -85,7 +85,7 @@ set of constraints.
\subsection{The run function} \subsection{The run function}
\label{run-function}
The semantics of an execution step is given by a function The semantics of an execution step is given by a function
taking an environment $e$ and a (trace) expression $t$: taking an environment $e$ and a (trace) expression $t$:
$\RUN(e,t)$. $\RUN(e,t)$.
Markdown is supported
0%
or
Please register or to comment
