**Warning:** this project is quite recent, and the provided API is immature and might change somehow.
## Configuration
The configuration of QECE is managed through a `DynamicVar` named `QeceContext`, which wrap a `QeceConfig` class aggregating the different configuration aspects in the project (sources are in `src/main/scala/QeceContext.scala`).
Different helpers are available to load and update this variable (you can take a look at the **scaladoc** for both `QeceContext` and `QeceConfig`), so you can easily modify the default configuration.
More specifically, some helpers are based on functional programming, exposing functions to modify the different aspects of the configuration: for example, you can use `val customConfig = QeceContext.copy(parallel = _.copy(numThread = 8))` to update the `ParallelConfig` with a new level of parallelism, without modifying the other default values.
**Warning:** If you aim at defining your own entry points in QECE - as the API is currently quite open - do not forget to wrap your calls with the right `withValue(myConfig)` to use an actually updated version of the `QeceContext`, or the default configuration will be used.
Otherwise, the entry points of the API are managing this aspect for you.
## Entry Points
Currently, two main entry points are available in the library, for both **exploration** and **estimation** features.
### Exploration
#### Annotating your modules
The first thing to do run an exploration is to annotate the explored design with its design space.
<br/>
To do so, your chisel `Module` must implement the `qece.exploration.utils.WithExplorable` trait, and each parameter must be annotated with a set of possible values, using the annotations defined in `qece.exploration.annotations`.
For example, we can define a `DummyModule` as follow:
class DummyModule(
@pow2(1, 5) bitWidth: Int,
@linear(2, 5) unitNumber: Int
) extends MultiIOModule with WithExplorable
**N.B.:** For now, the parameters can only take integer values.
However, it can easily be mapped to any countable set of value.
#### Running explorations
The real entry point of QECE is based on the `StrategyBuilder` class (sources in `src/main/scala/exploration/strategies/StrategyBuilder`).
<br/>
It is a simple wrapper around the available basic strategies, which includes an user defined `QeceConfiguration` to easily override the default configuration.
Once you have defined your own `customConfig` (as shown above), you can call `val builder = StrategyBuilder(customConfig)` to create your custom `StrategyBuilder`.
The builder itself allows to compose sequential exploration steps, which are methods of the builder.
For each method, you can specify different parameters (including the `TransformSeq` to run), and you can redefine the parallelism level by specifying the `numThread` parameter for each step.
For example, a simple strategy operating on the previously defined `DummyModule` (to find the design using the more DSP units but still fitting the target board) could be:
val builder = StrategyBuilder(customConfig).withPath("dummyExploration")
val strategy = builder.buildStrategy(
builder.compose(
builder.prune[DummyModule](
tfs = TransformSeq.resources,
func = m => m("%dsp") > 1.0
builder.sort[DummyModule](
tfs = TransformSeq.synthesis,
func = _("%realDSP"),
cmp = (_ > _),
numThread = 4
strategy.explore[DummyModule]
strategy.writeBack("myResults.csv")
**N.B.:** You can use the helper `withPath(targetPath: String)` to specify the file emission path for the current exploration
### Estimation
The **estimation** of digital designs is mainly used in the **exploration** feature, and might be difficult to integrate on its own.
However, if you want to use it, consider implementing the `qece.estimation.WithTransform` trait, using the `estimate[T: TypeTag](transforms: TransformSeq, config: QeceConfig)(point: Point)` method to run the selected estimation transforms on a given implementation (represented as a `Point`)
### Defining your own transforms and strategies
At the moment of this writing, the only way to define your own estimation transforms and basic exploration strategies is to clone this project, and integrate your code in it.
<br/>
As this solution is quite incompatible with the goal of this project, we are working on a way to externally define your custom operations, and integrate them in the API.
<br/>
However, if you think that your custom transform/strategy would benefit to other users, do not hesitate to create a merge request !
**N.B.:** Some helpers are available for file usage and timing, in `src/main/scala/package.scala` and `src/main/scala/Utils.scala`.
Moreover, statistics helpers are available in `src/main/scala/estimation/qor`. |
\ No newline at end of file |
