| ... | @@ -37,6 +37,6 @@ If you have followed the official pip procedure, you should be able to install t |
pip install Scikit-image Scikit-learn Matplotlib plotly barviz Pandas Pandoc pyyaml Jupyterlab fidle
Once your Python environment is installed, **you should be able to follow the standard Linux** procedure **[from point 4)](Linux-installation-with-pip#4-install-notebooks-et-datasets)**
Once your Python environment is installed, **you should be able to follow the standard Linux** procedure **[from point 4)](Using-Fidle/Linux%20installation%20with%20pip#4-install-notebooks-et-datasets)**
[Back to the install procedure](Using Fidle/install fidle) |
\ No newline at end of file |
