... | @@ -5,7 +5,7 @@ This solution can be adapted if the procedure described above does not work.\ |
This can be the case, for example under MacOS.
Here you will find a list of installation recipes proposed by participants of Fidle who successfully managed to install an environment for Fidle on a Mac.
Here you will find a list of installation recipes proposed by participants of Fidle who successfully managed to install an environment for Fidle on a **Mac**.
Thanks a lot for these contributions !
... | @@ -13,7 +13,7 @@ Thanks a lot for these contributions ! |
**- Notes -**
**- Notes -**
From Kevin C. on nevember 2022<br>
From Kevin C. on november 2022<br>
For **Mac M1**, a conda installation is possible - see Annexe 1<br>
From Thierry G. on november 2022<br>
... | @@ -51,7 +51,7 @@ Thanks a lot for these contributions ! |
- Once your Python environment is installed, **you should be able to follow the standard Linux** procedure **[from point 4)](Using-Fidle/Linux%20installation%20with%20pip#4-install-notebooks-et-datasets)**
## Installation Feedbacks from Fidle participant
## Installation on MAC Feedbacks from Fidle participant
- November 2023 - For - Proposed by Pauline M.
- Setup: **MacBook Air M1**, version 13.6, **conda**
