... | @@ -12,26 +12,32 @@ This can be the case, for example under MacOS. |
## First install Tensorflow from the official install procedure
The easiest way is to follow the official procedure proposed on the Tensorflow website:
The easiest way is to follow the official procedure proposed on the Tensorflow and PyTorch web sites:
**https://www.tensorflow.org/install/pip?hl=fr**
- **https://www.tensorflow.org/install/pip?hl=fr**
- **https://pytorch.org/**
## Required additional packages for Fidle
Once Tensorflow is installed following the official procedure, you must install the following additional modules:
* Scikit-image
- Scikit-image
* Scikit-learn
- Scikit-learn
* Matplotlib
- Matplotlib
* Pandas
- plotly
* Pandoc
- barviz
* pyyaml
- Pandas
* Jupyter lab
- Pandoc
- pyyaml
- Jupyterlab
- fidle
If you have followed the official pip procedure, you should be able to install these modules with the command :
pip install Scikit-image Scikit-learn Matplotlib Pandas Pandoc pyyaml Jupyterlab
pip install Scikit-image Scikit-learn Matplotlib plotly barviz Pandas Pandoc pyyaml Jupyterlab fidle
[Back to the install procedure](Using Fidle/install fidle#linux-users) |
Once your Python environment is installed, **you should be able to follow the standard Linux** procedure **[from point 4)](Linux-installation-with-pip#4-install-notebooks-et-datasets)**
\ No newline at end of file |
[Back to the install procedure](Using Fidle/install fidle) |
