... | @@ -90,7 +90,7 @@ You should have something like : |
fid - Your favorite Fidle admin command :-) (v2.2b6)
fid - Your favorite Fidle admin command :-) (v2.2b7)
Notebooks and datasets can only be found if they are in/near the explored folder.
... | @@ -98,33 +98,37 @@ Explored directory is : /home/dupont/fidle-tp |
Datasets dir found :
/home/dupont/fidle-tp/datasets-fidle (Datasets Fidle / 1.5b2)
/home/dupont/fidle-tp/datasets-fidle (Datasets Fidle / 1.6)
The environment variable FIDLE_DATASETS_DIR is : undefined
Notebooks dir found :
/home/dupont/fidle-tp/fidle (Notebooks Fidle / 2.1b6)
/home/dupont/fidle-tp/fidle (Notebooks Fidle / 2.2.4)
Check environment :
Check environment :
Python : Ok (3.8.10)
Fidle module : Ok (2.2b6)
Fidle module : Ok (2.2b7)
tensorflow : Ok (2.9.0)
tensorflow : Ok (2.12.0)
tensorflow.keras : Ok (2.9.0)
tensorflow.keras : Ok (2.12.0)
numpy : Ok (1.23.4)
numpy : Ok (1.23.5)
sklearn : Ok (1.1.2)
sklearn : Ok (1.3.1)
skimage : Ok (0.19.3)
yaml : Ok (6.0.1)
matplotlib : Ok (3.6.1)
skimage : Ok (0.21.0)
plotly : Ok (5.10.0)
matplotlib : Ok (3.7.1)
pandas : Ok (1.5.0)
plotly : Ok (5.18.0)
jupyterlab : Ok (3.4.8)
pandas : Ok (2.0.3)
torch : Ok (1.12.1+cu102)
jupyterlab : Ok (4.0.5)
torchvision : Ok (0.13.1+cu102)
torch : Ok (2.1.0+cu121)
torchvision : Ok (0.16.0+cu121)
lightning : Ok (2.1.0)
## 6 - Start Jupyter lab
Very easy :-)
Very easy :-)
From a terminal, go to your `fidle-tp` folder,
**From a terminal**, go to your `fidle-tp` folder,
activate the `fidle-env` environment and do a `jupyter lab`.
