... | @@ -3,21 +3,26 @@ |
**- Prerequisites -**
* All notebooks can run on CPU or GPU
* All notebooks can run on a **classic CPU**, having a GPU can be nice, but is not essential.
* The software environment (conda) requires about 10G
* Original datasets require about 2.5G, but Consolidated datasets may require up to 150G depending on the tests you perform. **15GB** will probably be a minimum...
* Consolidated datasets may require up to 150G depending on the tests you perform... \
**- Important : -**
Anyway, 15GB will probably be a minimum...
You can install the Fidle environment via **Docker** or in a classic way. If you know how to use a Docker container, this is the best solution !
**- Contents -**
**- Contents -**
[[_TOC_]]
[[_TOC_]]
[<img width="350px" src="uploads/31d5ce29e91c44d33930aed9ef465559/InstallationFIDLE.png"></img>](https://www.youtube.com/watch?v=pw8x3D5IaQY&t=5s)
A small video presentation of the installation under Windows...
But everything is **precisely described below** ! ;-)
## 1 - Get Fidle repository of notebooks
## Step 0 - Create a main repository
The very first step will be to create a folder in which we will then install all the elements of Fidle, for example : `fidle-tp`
The next 3 steps will take place within this folder.
## Step 1 - Get Fidle repository of notebooks
The simplest and most conventional way is with **git** (200 MB):
... | @@ -30,7 +35,7 @@ However, a **[classic retrieval](https://fidle.cnrs.fr/notebooks)** (zip) is pos |
**Important :** The project is frequently updated and we encourage you to get the latest version.\
The version number is specified in the README of the repository.
## 2 - Get and install Datasets
## Step 2 - Get and install Datasets
**Get it**\
**Get it**\
The datasets used in the examples are **[available here ](https://fidle.cnrs.fr/fidle-datasets.tar)**.\
... | @@ -41,55 +46,17 @@ wget https://fidle.cnrs.fr/fidle-datasets.tar |
tar -xf fidle-datasets.tar
**Specify the location**\
You must then indicate the location of this folder with an environment variable.
* For computers under Linux, add the following line to your `.bashrc`, or \`.bash_profile, ...
```shell
export FIDLE_DATASETS_DIR=<the place of your datasets directory>
* For computers under Windows (and using a terminal that is NOT a powershell!)
```shell
set FIDLE_DATASETS_DIR=<the place of your datasets directory>
A complete description of the different datasets is available in Notebooks.
## 3 - Setup Python Environment
## Step 3 - Setup Python Environment
### Linux users
It is possible to install **conda** or **pip** :
**[Linux installation procedure, using conda](Using Fidle/Linux installation using conda)**
**[Linux installation procedure, using pip](Using-Fidle/Linux installation with pip)**
### Windows users
Choose the right procedure :
**[Windows installation procedure, using pip](/Using Fidle/Windows installation)**
- [Linux installation](/Using-Fidle/Linux installation with pip)
- [Windows installation](/Using Fidle/Windows installation)
- [Manual installation (MacOs ?)](/Using Fidle/Manual installation)
### Manual or MacOS installation
If you want to **check your tensorflow installation** (and check if it supports gpu), launch a python interpreter and use these instructions :
If you have difficulties or if you are under MacOS...
**[Try this this manual installation procedure](/Using Fidle/Manual installation)**
**NOTE:**
- If you are lucky enough to have an account at **IDRIS** or at your favorite **meso center**, pre-installed environments are already available !
- To avoid infos and warning messages from tensorflow, you can set an additional environment variable `TF_CPP_MIN_LOG_LEVEL` whose possible values are 0, 1, 2 or 3.\
(0: all msg, 1:hide infos, 2:hide infos+warnings, 3:hide info, warnings and errors)
That's all folks !!
## Annexe 2 - Test installations
### Check Tensorflow / Keras
If you want to check your **tensorflow installation** (and check if it supports gpu), launch a python interpreter and use these instructions :
```python
```python
import tensorflow as tf
... | @@ -98,30 +65,25 @@ print(tf.test.is_built_with_cuda()) |
print(tf.config.list_physical_devices('GPU'))
## Annexe 3 - Uninstall
Great, now you can **[run Jupyter Lab !](Using-Fidle/Running-Jupyter)**
To delete data and notebooks:
- delete the folder containing the datasets (probably `fidle-datasets`)
- delete the folder containing the notebooks (probably `fidle` ou `fidle-master`)
For **conda installed version (Linux)** use the following command :
## Annexe 1 : Hide warning messages
conda deactivate
conda env remove --name fidle
For **pip installed version (Windows)** use the following command :
deactivate
And remove the virtual env directory
...and think to remove your FIDLE_DATASET_DIR variable setting !
## Annexe 2 - Uninstall
To remove and delete all Fidle stuff :
- close terminals and remove python virtual env directory (probably `file-env`)
L'ancienne procédure est [accessible ici :-)](Using-Fidle/install%20fidle%20v1)
\ No newline at end of file |
