| ... | @@ -16,7 +16,18 @@ |
The **installation** consists of **3 steps**:
[[_TOC_]]
* [1 - Get Fidle repository](#1-get-fidle-repository)
* [2 - Get and install Datasets](#2-get-and-install-datasets)
* [3 - Setup Python Environment](#3-setup-python-environment)
* [I just have a CPU :](#i-just-have-a-cpu-)
* [I have a nice GPU :](#i-have-a-nice-gpu-)
* [4 - Start Jupyter lab :](#4-start-jupyter-lab-)
* [Annexe 1 - Manual installation](#annexe-1-manual-installation)
* [I just have a CPU :](#i-just-have-a-cpu--1)
* [I have a nice GPU :](#i-have-a-nice-gpu--1)
* [Annexe 2 - Test installations](#annexe-2-test-installations)
* [Check Tensorflow / Keras](#check-tensorflow-keras)
* [Check Pytorch](#check-pytorch)
## 1 - Get Fidle repository
| ... | @@ -94,14 +105,12 @@ Very simply, as follows. |
Note : for Windows, use a Anaconda Prompt terminal to type these commands.
3. **Start** Jupyter lab
```plaintext
cd <PATH_TO_CLONED_FIDLE_REPO>
conda activate fidle-cpu
jupyter lab
jupyter lab
Note: replace `fidle-cpu `by `fidle-gpu` if needed ;-)
## Annexe 1 - Manual installation
This solution can be adapted if the procedure described above does not work.\
| ... | @@ -124,7 +133,7 @@ With conda you can use : |
* If no NVIDIA card is available on your computer or [NVIDIA card is not compliant with driver cuda 10.x](https://docs.nvidia.com/deploy/cuda-compatibility/index.html)
```plaintext
conda create --name fidle
conda install tensorflow>=2.4 numpy=1.19 keras scikit-learn scikit-image
| ... | @@ -167,6 +176,6 @@ print(torch.cuda.is_available()) |
print(torch.cuda.device_count())
L'ancienne procédure est [accessible ici :-)](Using-Fidle/install fidle v1)
L'ancienne procédure est [accessible ici :-)](Using-Fidle/install%20fidle%20v1)
\ No newline at end of file |
