| ... | ... | @@ -109,12 +109,19 @@ To delete data and notebooks: |
- delete the folder containing the datasets (probably `fidle-datasets`)
- delete the folder containing the notebooks (probably `fidle` ou `fidle-master`)
To remove the conda environment, use the following command :
For conda installed version (Linux) use the following command :
conda deactivate
conda env remove --name fidle
For pip installed version (Windows) use the following command :
deactivate
Remove the virtual env directory
...and think to remove your FIDLE_DATASET_DIR variable setting !
