| ... | @@ -13,22 +13,22 @@ |
### 1 - Get the Fidle Docker image
- Get Fidle image : ...it takes some time... (~5mn) and the image is quiet huge (~6.5 GB) <br>
`$ docker pull gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8`
`$ docker pull gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.7`
### 2 - Check the image has been pulled :<br>
- Have a look to your image:<br>
`$ docker images`<br>
On standard output, you should have a line of the form <br>
gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu python3.8 [...] 6.05GB
gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu python3.7 [...] 6.05GB
- You can test it :<br>
`$ docker run --rm gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8 fid check`<br>
`$ docker run --rm gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.7 fid check`<br>
You should see printed the following lines (version numbers may change) :
fid - Your favorite Fidle admin command :-) (v2.0b44)
fid - Your favorite Fidle admin command :-) (v2.0b47)
Notebooks and datasets can only be found if they are in/near the explored folder.
| ... | @@ -36,25 +36,26 @@ Explored directory is : /notebooks |
Datasets dir found :
//data/datasets-fidle (Datasets Fidle / 1.5b2)
//data/datasets-fidle (Datasets Fidle / 1.6)
The environment variable FIDLE_DATASETS_DIR is : /data/datasets-fidle
Notebooks dir found :
//notebooks/fidle-master (Notebooks Fidle / 2.2.0)
//notebooks/fidle-master (Notebooks Fidle / 2.2.2)
Check environment :
Check environment :
Fidle module : Ok (2.0b44)
Python : Ok (3.7.15)
Fidle module : Ok (2.0b47)
tensorflow : Ok (2.9.0)
tensorflow.keras : Ok (2.9.0)
numpy : Ok (1.23.4)
numpy : Ok (1.21.6)
sklearn : Ok (1.1.2)
sklearn : Ok (1.0.2)
skimage : Ok (0.19.3)
matplotlib : Ok (3.6.1)
matplotlib : Ok (3.5.3)
plotly : Ok (5.10.0)
pandas : Ok (1.5.0)
pandas : Ok (1.3.5)
jupyterlab : Ok (3.4.8)
torch : Ok (1.12.1+cu102)
torchvision : Ok (0.13.1+cu102)
| ... | @@ -63,7 +64,7 @@ Check environment : |
### 3 - Launch Fidle Jupyterlab
- Launch Jupyterlab for Fidle : <br>
`$ docker run -p 8888:8888 gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8`
`$ docker run -p 8888:8888 gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.7`
- Copy the URL printed on screen beginning with `http://127.0.0.1:8888/?token`...
- Open a Web Browser and paste the URL
