| ... | ... | @@ -48,7 +48,7 @@ Where: <br> `--name fidle` is used to give a name of your choice to your contain |
If you want to use tensoboard inside docker terminal use this command:
- tensorboard --logdir path/to/your/logs --bind_all
## 5 - To stop your jupyter, you can :**
## 5 - **To stop your jupyter, you can:**
- In Jupyter lab menu : "File"/"Shutdown"
- On the Unix console/Terminal you launched Fidle Jupyterlab: <br>
| ... | ... | @@ -56,7 +56,7 @@ If you want to use tensoboard inside docker terminal use this command: |
## 6 - To restart your fidle container where you leave your work
**you can Just type :**
**you can Just type:**
$ docker start -i fidle
