| ... | @@ -20,7 +20,7 @@ |
- To see if your image is there:
$ docker images
$ docker images
On standard output, you should have a line of the form : miaiefelia/fidle latest [...] 6.32GB
On standard output, you should have a line of the form : <br> miaiefelia/fidle latest [...] 6.32GB
- You can also [check your image](Check-Docker-image)
| ... | @@ -30,7 +30,8 @@ |
- This instance is built from the loaded image and is called a **container**<br>
$ docker run -i --name fidle -p 8888:8888 miaiefelia/fidle:latest
```where `--name fidle` is used to give a name of your choice to your container
`-i` is used to stay in interactive mode (Keep STDIN open even if not attached)
`-p` Publish a container's port(s) to the host
