| ... | @@ -10,20 +10,22 @@ |
### Remark
### Remark
- All commands presented below and prefixed by `$` are to be launched on a terminal/unix console :smile:
### Get the Fidle Docker image
### 1 - Get the Fidle Docker image
- Get Fidle image : ...it takes some time... (~5mn) and the image is quiet huge (~6.5 GB) <br>
`$ docker pull gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8`
- Check the image has been pulled :<br>
### 2 - Check the image has been pulled :<br>
`$ docker images`
- Have a look to your image:<br>
`$ docker images`<br>
- On standard output, you should have a line of the form <br>
`gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu python3.8 [...] 6.05GB`
- You can test it :<br>
`$ docker run --rm gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8 fid check`
`$ docker run --rm gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8 fid check`<br>
- You should see printed the following lines (version numbers may change) :
fid - Your favorite Fidle admin command :-) (v2.0b44)
| ... | @@ -59,7 +61,7 @@ Check environment : |
### Launch Fidle Jupyterlab
### 3 - Launch Fidle Jupyterlab
- Launch Jupyterlab for Fidle : <br>
`$ docker run -p 8888:8888 gricad-registry.univ-grenoble-alpes.fr/talks/fidle/fidle_cpu:python3.8`
