Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • daconcea/fidle
  • bossardl/fidle
  • Julie.Remenant/fidle
  • abijolao/fidle
  • monsimau/fidle
  • karkars/fidle
  • guilgautier/fidle
  • cailletr/fidle
  • talks/fidle
9 results
Show changes
Commits on Source (546)
Showing
with 3388 additions and 143 deletions
.ipynb_checkpoints .ipynb_checkpoints
.vscode
*/.ipynb_checkpoints/* */.ipynb_checkpoints/*
__pycache__ __pycache__
*/__pycache__/* */__pycache__/*
campains/
*==*==.ipynb
!*==done==.ipynb
stderr.txt
stdout.txt
debug.log
run/ run/
*/data/* figs/
!/GTSRB/data/dataset.tar.gz data/
!/BHPD/data/BostonHousing.csv GTSRB/data
GTSRB/05-full_convolutions.py
IMDB/data
MNIST/data
SYNOP/data
VAE/data
BHPD/data
AE/data
<img width="800px" src="../fidle/img/header.svg"></img>
# <!-- TITLE --> [K3AE1] - Prepare a noisy MNIST dataset
<!-- DESC --> Episode 1: Preparation of a noisy MNIST dataset
<!-- AUTHOR : Jean-Luc Parouty (CNRS/SIMaP) -->
## Objectives :
- Prepare a MNIST noisy dataset, usable with our denoiser autoencoder (duration : <50s)
## What we're going to do :
- Load original MNIST dataset
- Adding noise, a lot !
- Save it :-)
## Step 1 - Init and set parameters
### 1.1 - Init python
%% Cell type:code id: tags:
``` python
import os
os.environ['KERAS_BACKEND'] = 'torch'
import keras
import numpy as np
import sys
from skimage import io
from skimage.util import random_noise
import modules.MNIST
from modules.MNIST import MNIST
import fidle
# Init Fidle environment
run_id, run_dir, datasets_dir = fidle.init('K3AE1')
### 1.2 - Parameters
`prepared_dataset` : Filename of the future prepared dataset (example : ./data/mnist-noisy.h5)\
`scale` : Dataset scale. 1 mean 100% of the dataset - set 0.1 for tests\
`progress_verbosity`: Verbosity of progress bar: 0=silent, 1=progress bar, 2=One line
``` python
prepared_dataset = './data/mnist-noisy.h5'
scale = 1
progress_verbosity = 1
Override parameters (batch mode) - Just forget this cell
``` python
fidle.override('prepared_dataset', 'scale', 'progress_verbosity')
## Step 2 - Get original dataset
We load :
`clean_data` : Original and clean images - This is what we will want to ontain at the **output** of the AE
`class_data` : Image classes - Useless, because the training will be unsupervised
We'll build :
`noisy_data` : Noisy images - These are the images that we will give as **input** to our AE
``` python
clean_data, class_data = MNIST.get_origine(scale=scale)
## Step 3 - Add noise
We add noise to the original images (clean_data) to obtain noisy images (noisy_data)
Need 30-40 seconds
``` python
def noise_it(data):
new_data = np.copy(data)
for i,image in enumerate(new_data):
fidle.utils.update_progress('Add noise : ',i+1,len(data),verbosity=progress_verbosity)
image=random_noise(image, mode='gaussian', mean=0, var=0.3)
image=random_noise(image, mode='s&p', amount=0.2, salt_vs_pepper=0.5)
image=random_noise(image, mode='poisson')
image=random_noise(image, mode='speckle', mean=0, var=0.1)
new_data[i]=image
print('Done.')
return new_data
# ---- Add noise to input data : x_data
noisy_data = noise_it(clean_data)
## Step 4 - Have a look
``` python
print('Clean dataset (clean_data) : ',clean_data.shape)
print('Noisy dataset (noisy_data) : ',noisy_data.shape)
fidle.utils.subtitle("Noisy images we'll have in input (or x)")
fidle.scrawler.images(noisy_data[:5], None, indices='all', columns=5, x_size=3,y_size=3, interpolation=None, save_as='01-noisy')
fidle.utils.subtitle('Clean images we want to obtain (or y)')
fidle.scrawler.images(clean_data[:5], None, indices='all', columns=5, x_size=3,y_size=3, interpolation=None, save_as='02-original')
## Step 5 - Shuffle dataset
``` python
p = np.random.permutation(len(clean_data))
clean_data, noisy_data, class_data = clean_data[p], noisy_data[p], class_data[p]
print('Shuffled.')
## Step 6 - Save our prepared dataset
``` python
MNIST.save_prepared_dataset( clean_data, noisy_data, class_data, filename=prepared_dataset )
``` python
fidle.end()
<img width="80px" src="../fidle/img/logo-paysage.svg"></img>
# <!-- TITLE --> [K3AE2] - Building and training an AE denoiser model
<!-- DESC --> Episode 1 : Construction of a denoising autoencoder and training of it with a noisy MNIST dataset.
## Objectives :
- Understanding and implementing a denoizing **autoencoder** neurals network (AE)
- First overview or example of Keras procedural syntax
The calculation needs being important, it is preferable to use a very simple dataset such as MNIST.
The use of a GPU is often indispensable.
- Defining an AE model
- Build the model
- Train it
- Follow the learning process with Tensorboard
## Data Terminology :
- `clean_train`, `clean_test` for noiseless images
- `noisy_train`, `noisy_test` for noisy images
- `denoised_test` for denoised images at the output of the model
## Step 1 - Init python stuff
### 1.1 - Init
``` python
import os
import keras
import numpy as np
import random
from keras import layers
from keras.callbacks import ModelCheckpoint, TensorBoard
import os
from importlib import reload
from modules.ImagesCallback import ImagesCallback
import fidle
run_id, run_dir, datasets_dir = fidle.init('K3AE2')
`prepared_dataset` : Filename of the prepared dataset (Need 400 Mo, but can be in ./data)
`dataset_seed` : Random seed for shuffling dataset
`scale` : % of the dataset to use (1. for 100%)
`latent_dim` : Dimension of the latent space
`train_prop` : Percentage for train (the rest being for the test)
`batch_size` : Batch size
`epochs` : Nb of epochs for training\
`fit_verbosity` is the verbosity during training : 0 = silent, 1 = progress bar, 2 = one line per epoch
Note : scale=.2, epoch=20 => 3'30s on a laptop
``` python
dataset_seed = 123
scale = .1
latent_dim = 10
train_prop = .8
batch_size = 128
epochs = 20
fit_verbosity = 1
``` python
fidle.override('prepared_dataset', 'dataset_seed', 'scale', 'latent_dim')
fidle.override('train_prop', 'batch_size', 'epochs', 'fit_verbosity')
## Step 2 - Retrieve dataset
With our MNIST class, in one call, we can reload, rescale, shuffle and split our previously saved dataset :-)
``` python
clean_train,clean_test, noisy_train,noisy_test, _,_ = MNIST.reload_prepared_dataset(scale = scale,
train_prop = train_prop,
seed = dataset_seed,
shuffle = True,
## Step 3 - Build models
#### Encoder
``` python
inputs = keras.Input(shape=(28, 28, 1))
x = layers.Conv2D(32, 3, activation="relu", strides=2, padding="same")(inputs)
x = layers.Conv2D(64, 3, activation="relu", strides=2, padding="same")(x)
x = layers.Flatten()(x)
x = layers.Dense(16, activation="relu")(x)
z = layers.Dense(latent_dim)(x)
encoder = keras.Model(inputs, z, name="encoder")
# encoder.summary()
#### Decoder
``` python
inputs = keras.Input(shape=(latent_dim,))
x = layers.Dense(7 * 7 * 64, activation="relu")(inputs)
x = layers.Reshape((7, 7, 64))(x)
x = layers.Conv2DTranspose(64, 3, activation="relu", strides=2, padding="same")(x)
x = layers.Conv2DTranspose(32, 3, activation="relu", strides=2, padding="same")(x)
outputs = layers.Conv2DTranspose(1, 3, activation="sigmoid", padding="same")(x)
decoder = keras.Model(inputs, outputs, name="decoder")
# decoder.summary()
#### AE
``` python
latents = encoder(inputs)
outputs = decoder(latents)
ae = keras.Model(inputs,outputs, name="ae")
ae.compile(optimizer=keras.optimizers.Adam(), loss='binary_crossentropy')
## Step 4 - Train
20' on a CPU
1'12 on a GPU (V100, IDRIS)
``` python
# ---- Callback : Images
fidle.utils.mkdir( run_dir + '/images')
filename = run_dir + '/images/image-{epoch:03d}-{i:02d}.jpg'
callback_images = ImagesCallback(filename, x=clean_test[:5], encoder=encoder,decoder=decoder)
``` python
chrono = fidle.Chrono()
chrono.start()
history = ae.fit(noisy_train, clean_train,
batch_size = batch_size,
epochs = epochs,
verbose = fit_verbosity,
validation_data = (noisy_test, clean_test),
callbacks = [ callback_images ] )
chrono.show()
Save model
``` python
os.makedirs(f'{run_dir}/models', exist_ok=True)
encoder.save(f'{run_dir}/models/encoder.keras')
decoder.save(f'{run_dir}/models/decoder.keras')
## Step 5 - History
``` python
fidle.scrawler.history(history, plot={'loss':['loss','val_loss']}, save_as='01-history')
## Step 6 - Denoising progress
``` python
imgs=[]
for epoch in range(0,epochs,2):
for i in range(5):
filename = run_dir + '/images/image-{epoch:03d}-{i:02d}.jpg'.format(epoch=epoch, i=i)
img = io.imread(filename)
imgs.append(img)
fidle.utils.subtitle('Real images (clean_test) :')
fidle.scrawler.images(clean_test[:5], None, indices='all', columns=5, x_size=2,y_size=2, interpolation=None, save_as='02-original-real')
fidle.utils.subtitle('Noisy images (noisy_test) :')
fidle.scrawler.images(noisy_test[:5], None, indices='all', columns=5, x_size=2,y_size=2, interpolation=None, save_as='03-original-noisy')
fidle.utils.subtitle('Evolution during the training period (denoised_test) :')
fidle.scrawler.images(imgs, None, indices='all', columns=5, x_size=2,y_size=2, interpolation=None, y_padding=0.1, save_as='04-learning')
fidle.scrawler.images(noisy_test[:5], None, indices='all', columns=5, x_size=2,y_size=2, interpolation=None, save_as=None)
fidle.scrawler.images(clean_test[:5], None, indices='all', columns=5, x_size=2,y_size=2, interpolation=None, save_as=None)
## Step 7 - Evaluation
**Note :** We will use the following data:\
`clean_train`, `clean_test` for noiseless images \
`noisy_train`, `noisy_test` for noisy images\
### 7.1 - Reload model
``` python
encoder = keras.models.load_model(f'{run_dir}/models/encoder.keras')
decoder = keras.models.load_model(f'{run_dir}/models/decoder.keras')
ae_reloaded = keras.Model(inputs,outputs, name="ae")
### 7.2 - Let's make a prediction
``` python
denoised_test = ae_reloaded.predict(noisy_test, verbose=0)
print('Denoised images (denoised_test) shape : ',denoised_test.shape)
### 7.3 - Denoised images
``` python
i=random.randint(0,len(denoised_test)-8)
j=i+8
fidle.utils.subtitle('Noisy test images (input):')
fidle.scrawler.images(noisy_test[i:j], None, indices='all', columns=8, x_size=2,y_size=2, interpolation=None, save_as='05-test-noisy')
fidle.utils.subtitle('Denoised images (output):')
fidle.scrawler.images(denoised_test[i:j], None, indices='all', columns=8, x_size=2,y_size=2, interpolation=None, save_as='06-test-predict')
fidle.utils.subtitle('Real test images :')
fidle.scrawler.images(clean_test[i:j], None, indices='all', columns=8, x_size=2,y_size=2, interpolation=None, save_as='07-test-real')
``` python
fidle.end()
# <!-- TITLE --> [K3AE3] - Playing with our denoiser model
<!-- DESC --> Episode 2 : Using the previously trained autoencoder to denoise data
## Objectives :
- Retrieve and use our denoiser model
- Reload our dataset and saved best model
- Encode/decode some test images (neved used, never seen by the model)
### 1.1 - Init
``` python
import os
import keras
import numpy as np
import random
import fidle
run_id, run_dir, datasets_dir = fidle.init('K3AE3')
These **parameters must be identical** to those used during the training in order to have the **same dataset**.\
``` python
saved_models = './run/K3AE2/models'
dataset_seed = 123
scale = 1
train_prop = .8
``` python
fidle.override('prepared_dataset', 'dataset_seed', 'scale', 'train_prop')
**Important :** Make sure that the **digest is identical** to the one used during the training !\
See : [AE2 / Step 2 - Retrieve dataset](./02-AE-with-MNIST.ipynb#Step-2---Retrieve-dataset)
``` python
shuffle = True,
## Step 3 - Evaluation
### 3.1 - Reload our best model
``` python
# model = keras.models.load_model(f'{saved_models}/model.keras')
encoder = keras.models.load_model(f'{saved_models}/encoder.keras')
decoder = keras.models.load_model(f'{saved_models}/decoder.keras')
model = keras.Model(inputs,outputs, name="ae")
### 3.2 - Let's make a prediction
``` python
from tabnanny import verbose
denoised_test = model.predict(noisy_test,verbose=0)
### 3.3 - Denoised images
``` python
j=i+8
## Step 4 - Looking at the latent space
### 4.1 - Getting clean data and class
``` python
clean_data,_, _,_, class_data,_ = MNIST.reload_prepared_dataset(scale = 1,
train_prop = 1,
shuffle = False,
filename = prepared_dataset )
### 4.2 - Retrieve encoder
``` python
encoder=model.get_layer('encoder')
### 4.3 Showing latent space
Here is the digit distribution in the latent space
``` python
n_show = min( 20000, len(clean_data) )
# ---- Select images
x_show, y_show = fidle.utils.pick_dataset(clean_data, class_data, n=n_show)
# ---- Get latent points
z = encoder.predict(x_show)
# ---- Show them
fig = plt.figure(figsize=(14, 10))
plt.scatter(z[:, 0] , z[:, 1], c=y_show, cmap= 'tab10', alpha=0.5, s=30)
plt.colorbar()
fidle.scrawler.save_fig('08-Latent-space')
plt.show()
``` python
fidle.end()
# <!-- TITLE --> [K3AE4] - Denoiser and classifier model
<!-- DESC --> Episode 4 : Construction of a denoiser and classifier model
## Objectives :
- Building a multiple output model, able to **denoise** and **classify**
- Understanding a more **advanced programming model**
- Defining a multiple output model using Keras procedural programing model
- Build the model
- Train it
- `class_train`, `class_test` for the classes to which the images belong
- `classcat_test` for class prediction in model output (is a softmax)
- `classid_test` class prediction (ie: argmax of classcat_test)
### 1.1 - Init
``` python
import os
import keras
import numpy as np
import random
from modules.AE4_builder import AE4_builder
import fidle
run_id, run_dir, datasets_dir = fidle.init('K3AE4')
`dataset_seed` : Random seed for shuffling dataset. 'None' mean using /dev/urandom
scale=0.1, epochs=20 => 2' on a laptop
``` python
dataset_seed = None
scale = .1
train_prop = .8
batch_size = 128
epochs = 10
fit_verbosity = 1
``` python
fidle.override('prepared_dataset', 'dataset_seed', 'scale')
``` python
clean_train,clean_test, noisy_train,noisy_test, class_train,class_test = MNIST.reload_prepared_dataset(
scale = scale,
shuffle = True,
``` python
builder = AE4_builder( ae={ 'latent_dim':10 }, cnn = { 'lc1':8, 'lc2':16, 'ld':100 } )
model = builder.create_model()
``` python
model.compile(optimizer='rmsprop',
loss={'ae':'binary_crossentropy', 'classifier':'sparse_categorical_crossentropy'},
loss_weights={'ae':1., 'classifier':1.},
metrics={'classifier':'accuracy'} )
``` python
# keras.utils.plot_model(model, "multi_input_and_output_model.png", show_shapes=True)
## Step 4 - Train
20' on a CPU
``` python
encoder = model.get_layer('ae').get_layer('encoder')
decoder = model.get_layer('ae').get_layer('decoder')
``` python
chrono.start()
history = model.fit(noisy_train, [clean_train, class_train],
epochs = epochs,
validation_data = (noisy_test, [clean_test, class_test]),
chrono.show()
Save model weights
``` python
model.save_weights(f'{run_dir}/models/model.weights.h5')
## Step 5 - History
``` python
fidle.scrawler.history(history, plot={'Loss':['loss', 'val_loss'],
'Accuracy':['classifier_accuracy','val_classifier_accuracy']}, save_as='01-history')
``` python
imgs=[]
for epoch in range(0,epochs,4):
for i in range(5):
imgs.append(img)
`class_train`, `class_test` for the classes to which the images belong \
`denoised_test` for denoised images at the output of the model\
`classcat_test` for class prediction in model output (is a softmax)\
### 7.1 - Reload our model (weights)
``` python
model.load_weights(f'{run_dir}/models/model.weights.h5')
Note that our model will returns 2 outputs : **denoised images** from output 1 and **class prediction** from output 2
``` python
outputs = model.predict(noisy_test, verbose=0)
denoised = outputs['ae']
classcat = outputs['classifier']
print('Denoised images (denoised_test) shape : ', denoised.shape)
print('Predicted classes (classcat_test) shape : ', classcat.shape)
``` python
i=random.randint(0,len(denoised)-8)
j=i+8
fidle.scrawler.images(denoised[i:j], None, indices='all', columns=8, x_size=2,y_size=2, interpolation=None, save_as='06-test-predict')
### 7.4 - Class prediction
Note: The evaluation requires the noisy images as input (noisy_test) and the 2 expected outputs:
- the images without noise (clean_test)
- the classes (class_test)
``` python
# We need to (re)compile our resurrected model (to specify loss and metrics)
# Get an evaluation
score = model.evaluate(noisy_test, [clean_test, class_test], verbose=0)
# And show results
fidle.utils.subtitle("Accuracy :")
print(f'Classification accuracy : {score[1]:4.4f}')
fidle.utils.subtitle("Few examples :")
classid_test = np.argmax(classcat, axis=-1)
fidle.scrawler.images(noisy_test, class_test, range(0,200), columns=12, x_size=1, y_size=1, y_pred=classid_test, save_as='04-predictions')
``` python
fidle.end()
# <!-- TITLE --> [K3AE5] - Advanced denoiser and classifier model
<!-- DESC --> Episode 5 : Construction of an advanced denoiser and classifier model
## Objectives :
- Understanding a more complex **advanced programming model**
- Build the model
- Train it
### 1.1 - Init
``` python
import os
import keras
import numpy as np
import random
from modules.AE5_builder import AE5_builder
import fidle
run_id, run_dir, datasets_dir = fidle.init('K3AE5')
``` python
dataset_seed = None
scale = .1
train_prop = .8
batch_size = 128
epochs = 10
fit_verbosity = 1
``` python
``` python
scale = scale,
shuffle = True,
``` python
builder = AE5_builder( ae = { 'latent_dim':10 },
cnn1 = { 'lc1':8, 'lc2':16, 'ld':100 },
cnn2 = { 'lc1':32, 'lc2':64, 'ld':50 } )
``` python
## Step 4 - Train
20' on a CPU
1'30 on a GPU (V100, IDRIS)
``` python
``` python
chrono.start()
epochs = epochs,
chrono.show()
Save model weights
``` python
## Step 5 - History
``` python
``` python
imgs=[]
for i in range(5):
imgs.append(img)
### 7.1 - Reload our best model
``` python
``` python
``` python
j=i+8
``` python
# Get an evaluation
# And show results
``` python
fidle.end()
# _____ _ _ _
# | ___(_) __| | | ___
# | |_ | |/ _` | |/ _ \
# | _| | | (_| | | __/
# |_| |_|\__,_|_|\___|
# Formation Introduction au Deep Learning (FIDLE)
# CNRS/MIAI 2024 - JL. Parouty
import os
import keras
import keras.layers as layers
# A usefull class to manage our AE model
class AE4_builder():
version = '0.1'
def __init__(self, ae = { 'latent_dim':16 },
self.ae = ae
self.cnn = cnn
def create_encoder(self):
latent_dim = self.ae['latent_dim']
inputs = keras.Input(shape=(28,28,1))
z = layers.Dense(latent_dim, name='latent')(x)
return encoder
def create_decoder(self):
outputs = layers.Conv2DTranspose(1, 3, activation="sigmoid", padding="same", name='denoiser')(x)
return decoder
def create_cnn(self):
lc1 = self.cnn['lc1']
lc2 = self.cnn['lc2']
ld = self.cnn['ld']
x = keras.layers.Conv2D(lc1, (3,3), activation='relu')(inputs)
x = keras.layers.MaxPooling2D((2,2))(x)
x = keras.layers.Dropout(0.2)(x)
x = keras.layers.Conv2D(lc2, (3,3), activation='relu')(x)
x = keras.layers.Flatten()(x)
x = keras.layers.Dense(ld, activation='relu')(x)
x = keras.layers.Dropout(0.5)(x)
outputs = keras.layers.Dense(10, activation='softmax', name='cnn')(x)
cnn = keras.Model(inputs, outputs, name='classifier')
return cnn
def create_model(self):
# ---- Recover all elementary bricks
encoder = self.create_encoder()
decoder = self.create_decoder()
cnn = self.create_cnn()
# ---- Build ae
ae = keras.Model(inputs,outputs, name='ae')
# ---- Assembling final model
denoised = ae(inputs)
classcat = cnn(inputs)
model = keras.Model(inputs, outputs={ 'ae':denoised, 'classifier':classcat})
return model
\ No newline at end of file
# _____ _ _ _
import os
import keras
class AE5_builder():
version = '0.1'
self.ae = ae
self.cnn1 = cnn1
self.cnn2 = cnn2
return encoder
return decoder
def create_cnn1(self):
lc1 = self.cnn1['lc1']
lc2 = self.cnn1['lc2']
ld = self.cnn1['ld']
outputs = keras.layers.Dense(10, activation='softmax', name='classifier')(x)
cnn = keras.Model(inputs, outputs, name='cnn')
return cnn
def create_cnn2(self):
lc1 = self.cnn2['lc1']
lc2 = self.cnn2['lc2']
ld = self.cnn2['ld']
x = keras.layers.Conv2D(lc1, (5,5), activation='relu')(inputs)
x = keras.layers.Dropout(0.3)(x)
x = keras.layers.Conv2D(lc2, (5,5), activation='relu')(x)
outputs = keras.layers.Dropout(0.3)(x)
cnn2 = keras.Model(inputs, outputs, name='cnn2')
return cnn2
cnn1 = self.create_cnn1()
cnn2 = self.create_cnn2()
# ---- Build ae
# ---- Build classifier
branch_1 = cnn1(inputs)
branch_2 = cnn2(inputs)
x = keras.layers.concatenate([branch_1,branch_2], axis=1)
outputs = keras.layers.Dense(10, activation='softmax')(x)
classifier = keras.Model(inputs,outputs, name='classifier')
classcat = classifier(inputs)
return model
from keras.callbacks import Callback
import numpy as np
class ImagesCallback(Callback):
def __init__(self, filename='image-{epoch:03d}-{i:02d}.jpg',
x=None,
encoder=None, decoder=None):
self.filename = filename
self.x = x
self.encoder = encoder
self.decoder = decoder
if len(x)>100:
print('***Warning : The number of images is reduced to 100')
self.x=x[:100]
def on_epoch_end(self, epoch, logs={}):
z_new = self.encoder.predict(self.x)
# ---- Predict an image
images = self.decoder.predict(np.array(z_new))
# ---- Save images
for i,image in enumerate(images):
# ---- Squeeze it if monochrome : (lx,ly,1) -> (lx,ly)
image = image.squeeze()
# ---- Save it
filename = self.filename.format(epoch=epoch,i=i)
if len(image.shape) == 2:
plt.imsave(filename, image, cmap='gray_r')
else:
plt.imsave(filename, image)
# _____ _ _ _
# CNRS/SARI/DEVLOG 2020 - S. Arias, E. Maldonado, JL. Parouty
# 2.0 version by JL Parouty, feb 2021
import h5py
import os
import numpy as np
from hashlib import blake2b
import keras
import keras.datasets.mnist as mnist
# A usefull class to manage our MNIST dataset
# This class allows to manage datasets derived from the original MNIST
class MNIST():
version = '0.1'
def __init__(self):
pass
@classmethod
def get_origine(cls, scale=1, normalize=True, expand=True, concatenate=True):
Return original MNIST dataset
args:
scale : Proportion of the requested dataset
normalize : Normalize dataset or not (True)
expand : Reshape images as (28,28,1) instead (28,28) (True)
concatenate : Concatenate train and test sets (True)
returns:
x_data,y_data if concatenate is False
x_train,y_train,x_test,y_test if concatenate is True
# ---- Get data
(x_train, y_train), (x_test, y_test) = mnist.load_data()
print('Dataset loaded.')
# ---- Normalization
if normalize:
x_train = x_train.astype('float32') / 255.
x_test = x_test.astype( 'float32') / 255.
print('Normalized.')
# ---- Reshape : (28,28) -> (28,28,1)
if expand:
x_train = np.expand_dims(x_train, axis=-1)
x_test = np.expand_dims(x_test, axis=-1)
print('Reshaped.')
# ---- scale
n1 = int(len(x_train)*scale)
n2 = int(len(x_test)*scale)
x_train = x_train[:n1]
y_train = y_train[:n1]
x_test = x_test[:n2]
y_test = y_test[:n2]
# ---- Concatenate
if concatenate:
x_data = np.concatenate([x_train, x_test], axis=0)
y_data = np.concatenate([y_train, y_test])
print('Concatenate.')
print('x shape :', x_data.shape)
print('y shape :', y_data.shape)
return x_data,y_data
else:
print('x_train shape :', x_train.shape)
print('y_train shape :', y_train.shape)
print('x_test shape :', x_test.shape)
print('y_test shape :', y_test.shape)
@classmethod
def save_prepared_dataset(cls, clean_data, noisy_data, class_data, filename='./data/mnist-noisy.h5'):
Save a prepared dataset in a h5 file
args:
clean_data, noisy_data, class_data : clean, noisy and class dataset
filename : filename
return:
None
path=os.path.dirname(filename)
os.makedirs(path, mode=0o750, exist_ok=True)
with h5py.File(filename, "w") as f:
f.create_dataset("clean_data", data=clean_data)
f.create_dataset("noisy_data", data=noisy_data)
f.create_dataset("class_data", data=class_data)
print('Saved.')
print('clean_data shape is : ',clean_data.shape)
print('noisy_data shape is : ',noisy_data.shape)
print('class_data shape is : ',class_data.shape)
@classmethod
def reload_prepared_dataset(cls, scale=1., train_prop=0.8, shuffle=True, seed=False, filename='./data/mnist-noisy.h5'):
Reload a saved dataset
args:
scale : Scale of dataset to use. 1. mean 100% (1.)
train_prop : Ratio of train/test
shuffle : Shuffle data if True
seed : Random seed value. False mean no seed, None mean using /dev/urandom (None)
filename : filename of the prepared dataset
returns:
# ---- Load saved dataset
clean_data = f['clean_data'][:]
noisy_data = f['noisy_data'][:]
class_data = f['class_data'][:]
print('Loaded.')
# ---- Rescale
n = int(scale*len(clean_data))
clean_data, noisy_data, class_data = clean_data[:n], noisy_data[:n], class_data[:n]
print(f'rescaled ({scale}).')
# ---- Seed
if seed is not False:
np.random.seed(seed)
print(f'Seeded ({seed})')
# ---- Shuffle
if shuffle:
print('Shuffled.')
# ---- Split
n=int(len(clean_data)*train_prop)
clean_train, clean_test = clean_data[:n], clean_data[n:]
noisy_train, noisy_test = noisy_data[:n], noisy_data[n:]
class_train, class_test = class_data[:n], class_data[n:]
print(f'splited ({train_prop}).')
# ---- Hash
h = blake2b(digest_size=10)
for a in [clean_train,clean_test, noisy_train,noisy_test, class_train,class_test]:
h.update(a)
print('clean_train shape is : ', clean_train.shape)
print('clean_test shape is : ', clean_test.shape)
print('noisy_train shape is : ', noisy_train.shape)
print('noisy_test shape is : ', noisy_test.shape)
print('class_train shape is : ', class_train.shape)
print('class_test shape is : ', class_test.shape)
print('Blake2b digest is : ', h.hexdigest())
return clean_train,clean_test, noisy_train,noisy_test, class_train,class_test
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
Deep Neural Network (DNN) - BHPD dataset <img width="800px" src="../fidle/img/header.svg"></img>
Introduction au Deep Learning (IDLE) - S. Arias, E. Maldonado, JL. Parouty - CNRS/SARI/DEVLOG - 2020
## A very simple example of **regression** :
Objective is to predicts **housing prices** from a set of house features.
The **[Boston Housing Dataset](https://www.cs.toronto.edu/~delve/data/boston/bostonDetail.html)** consists of price of houses in various places in Boston. # <!-- TITLE --> [K3BHPD1] - Regression with a Dense Network (DNN)
Alongside with price, the dataset also provide information such as Crime, areas of non-retail business in the town, <!-- DESC --> Simple example of a regression with the dataset Boston Housing Prices Dataset (BHPD)
age of people who own the house and many other attributes... <!-- AUTHOR : Jean-Luc Parouty (CNRS/SIMaP) -->
## Objectives :
- Predicts **housing prices** from a set of house features.
- Understanding the **principle** and the **architecture** of a regression with a **dense neural network**
The **[Boston Housing Prices Dataset](https://www.cs.toronto.edu/~delve/data/boston/bostonDetail.html)** consists of price of houses in various places in Boston.
Alongside with price, the dataset also provide theses informations :
- CRIM: This is the per capita crime rate by town
- ZN: This is the proportion of residential land zoned for lots larger than 25,000 sq.ft
- INDUS: This is the proportion of non-retail business acres per town
- CHAS: This is the Charles River dummy variable (this is equal to 1 if tract bounds river; 0 otherwise)
- NOX: This is the nitric oxides concentration (parts per 10 million)
- RM: This is the average number of rooms per dwelling
- AGE: This is the proportion of owner-occupied units built prior to 1940
- DIS: This is the weighted distances to five Boston employment centers
- RAD: This is the index of accessibility to radial highways
- TAX: This is the full-value property-tax rate per 10,000 dollars
- PTRATIO: This is the pupil-teacher ratio by town
- B: This is calculated as 1000(Bk — 0.63)^2, where Bk is the proportion of people of African American descent by town
- LSTAT: This is the percentage lower status of the population
- MEDV: This is the median value of owner-occupied homes in 1000 dollars
What we're going to do: ## What we're going to do :
- Retrieve data - Retrieve data
- Preparing the data - Preparing the data
- Build a model - Build a model
- Train the model - Train the model
- Evaluate the result - Evaluate the result
## 1/ Init python stuff ## Step 1 - Import and init
You can also adjust the verbosity by changing the value of TF_CPP_MIN_LOG_LEVEL :
- 0 = all messages are logged (default)
- 1 = INFO messages are not printed.
- 2 = INFO and WARNING messages are not printed.
- 3 = INFO , WARNING and ERROR messages are not printed.
%% Cell type:code id: tags: %% Cell type:code id: tags:
``` python ``` python
import tensorflow as tf import os
from tensorflow import keras os.environ['KERAS_BACKEND'] = 'torch'
import keras
import numpy as np import numpy as np
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
import pandas as pd import pandas as pd
import os,sys import os,sys
from IPython.display import display, Markdown import fidle
run_id, run_dir, datasets_dir = fidle.init('K3BHPD1')
Verbosity during training :
- 0 = silent
- 1 = progress bar
- 2 = one line per epoch
sys.path.append('..') %% Cell type:code id: tags:
import fidle.pwk as ooo
ooo.init() ``` python
fit_verbosity = 1
%% Output %% Cell type:markdown id: tags:
IDLE 2020 - Practical Work Module %% Cell type:code id: tags:
Version : 0.2.4
Run time : Sunday 2 February 2020, 15:17:29 ``` python
Matplotlib style : ../fidle/talk.mplstyle fidle.override('fit_verbosity')
TensorFlow version : 2.0.0 ```
Keras version : 2.2.4-tf
## 2/ Retrieve data ## Step 2 - Retrieve data
**From Keras :** ### 2.1 - Option 1 : From Keras
Boston housing is a famous historic dataset, so we can get it directly from [Keras datasets](https://www.tensorflow.org/api_docs/python/tf/keras/datasets) Boston housing is a famous historic dataset, so we can get it directly from [Keras datasets](https://keras.io/api/datasets)
%% Cell type:raw id: tags: %% Cell type:code id: tags:
(x_train, y_train), (x_test, y_test) = keras.datasets.boston_housing.load_data(test_split=0.2, seed=113) ``` python
# (x_train, y_train), (x_test, y_test) = keras.datasets.boston_housing.load_data(test_split=0.2, seed=113)
**From a csv file :** ### 2.2 - Option 2 : From a csv file
More fun ! More fun !
data = pd.read_csv('./data/BostonHousing.csv', header=0) data = pd.read_csv(f'{datasets_dir}/BHPD/origine/BostonHousing.csv', header=0)
display(data.head(5).style.format("{0:.2f}")) display(data.head(5).style.format("{0:.2f}").set_caption("Few lines of the dataset :"))
print('Données manquantes : ',data.isna().sum().sum(), ' Shape is : ', data.shape) print('Missing Data : ',data.isna().sum().sum(), ' Shape is : ', data.shape)
## 3/ Preparing the data ## Step 3 - Preparing the data
### 3.1/ Split data ### 3.1 - Split data
We will use 70% of the data for training and 30% for validation. We will use 70% of the data for training and 30% for validation.
The dataset is **shuffled** and shared between **learning** and **testing**.
x will be input data and y the expected output x will be input data and y the expected output
# ---- Split => train, test # ---- Shuffle and Split => train, test
data = data.sample(frac=1., axis=0)
data_train = data.sample(frac=0.7, axis=0) data_train = data.sample(frac=0.7, axis=0)
data_test = data.drop(data_train.index) data_test = data.drop(data_train.index)
# ---- Split => x,y (medv is price) # ---- Split => x,y (medv is price)
x_train = data_train.drop('medv', axis=1) x_train = data_train.drop('medv', axis=1)
y_train = data_train['medv'] y_train = data_train['medv']
x_test = data_test.drop('medv', axis=1) x_test = data_test.drop('medv', axis=1)
y_test = data_test['medv'] y_test = data_test['medv']
print('Original data shape was : ',data.shape) print('Original data shape was : ',data.shape)
print('x_train : ',x_train.shape, 'y_train : ',y_train.shape) print('x_train : ',x_train.shape, 'y_train : ',y_train.shape)
print('x_test : ',x_test.shape, 'y_test : ',y_test.shape) print('x_test : ',x_test.shape, 'y_test : ',y_test.shape)
### 3.2/ Data normalization ### 3.2 - Data normalization
**Note :** **Note :**
- All input data must be normalized, train and test. - All input data must be normalized, train and test.
- To do this we will subtract the mean and divide by the standard deviation. - To do this we will **subtract the mean** and **divide by the standard deviation**.
- But test data should not be used in any way, even for normalization. - But test data should not be used in any way, even for normalization.
- The mean and the standard deviation will therefore only be calculated with the train data. - The mean and the standard deviation will therefore only be calculated with the train data.
display(x_train.describe().style.format("{0:.2f}").set_caption("Before normalization :")) display(x_train.describe().style.format("{0:.2f}").set_caption("Before normalization :"))
mean = x_train.mean() mean = x_train.mean()
std = x_train.std() std = x_train.std()
x_train = (x_train - mean) / std x_train = (x_train - mean) / std
x_test = (x_test - mean) / std x_test = (x_test - mean) / std
display(x_train.describe().style.format("{0:.2f}").set_caption("After normalization :")) display(x_train.describe().style.format("{0:.2f}").set_caption("After normalization :"))
display(x_train.head(5).style.format("{0:.2f}").set_caption("Few lines of the dataset :"))
x_train, y_train = np.array(x_train), np.array(y_train) x_train, y_train = np.array(x_train), np.array(y_train)
x_test, y_test = np.array(x_test), np.array(y_test) x_test, y_test = np.array(x_test), np.array(y_test)
## 4/ Build a model ## Step 4 - Build a model
About informations about : About informations about :
- [Optimizer](https://www.tensorflow.org/api_docs/python/tf/keras/optimizers) - [Optimizer](https://keras.io/api/optimizers)
- [Activation](https://www.tensorflow.org/api_docs/python/tf/keras/activations) - [Activation](https://keras.io/api/layers/activations)
- [Loss](https://www.tensorflow.org/api_docs/python/tf/keras/losses) - [Loss](https://keras.io/api/losses)
- [Metrics](https://www.tensorflow.org/api_docs/python/tf/keras/metrics) - [Metrics](https://keras.io/api/metrics)
def get_model_v1(shape): def get_model_v1(shape):
model = keras.models.Sequential() model = keras.models.Sequential()
model.add(keras.layers.Dense(64, activation='relu', input_shape=shape)) model.add(keras.layers.Input(shape, name="InputLayer"))
model.add(keras.layers.Dense(64, activation='relu')) model.add(keras.layers.Dense(32, activation='relu', name='Dense_n1'))
model.add(keras.layers.Dense(1)) model.add(keras.layers.Dense(64, activation='relu', name='Dense_n2'))
model.add(keras.layers.Dense(32, activation='relu', name='Dense_n3'))
model.add(keras.layers.Dense(1, name='Output'))
model.compile(optimizer = 'rmsprop', model.compile(optimizer = 'adam',
loss = 'mse', loss = 'mse',
metrics = ['mae', 'mse'] ) metrics = ['mae', 'mse'] )
return model return model
## 5/ Train the model ## Step 5 - Train the model
### 5.1 - Get it
model=get_model_v1( (13,) ) model=get_model_v1( (13,) )
model.summary() model.summary()
# img=keras.utils.plot_model( model, to_file='./run/model.png', show_shapes=True, show_layer_names=True, dpi=96)
# display(img)
**Let's go :** ### 5.2 - Train it
history = model.fit(x_train, history = model.fit(x_train,
y_train, y_train,
epochs = 100, epochs = 60,
batch_size = 10, batch_size = 10,
verbose = 1, verbose = fit_verbosity,
validation_data = (x_test, y_test)) validation_data = (x_test, y_test))
## 6/ Evaluate ## Step 6 - Evaluate
### 6.1/ Model evaluation ### 6.1 - Model evaluation
MAE = Mean Absolute Error (between the labels and predictions) MAE = Mean Absolute Error (between the labels and predictions)
A mae equal to 3 represents an average error in prediction of $3k. A mae equal to 3 represents an average error in prediction of $3k.
score = model.evaluate(x_test, y_test, verbose=0) score = model.evaluate(x_test, y_test, verbose=0)
print('x_test / loss : {:5.4f}'.format(score[0])) print('x_test / loss : {:5.4f}'.format(score[0]))
print('x_test / mae : {:5.4f}'.format(score[1])) print('x_test / mae : {:5.4f}'.format(score[1]))
print('x_test / mse : {:5.4f}'.format(score[2])) print('x_test / mse : {:5.4f}'.format(score[2]))
### 6.2/ Training history ### 6.2 - Training history
What was the best result during our training ? What was the best result during our training ?
df=pd.DataFrame(data=history.history) df=pd.DataFrame(data=history.history)
df.describe() display(df)
print("min( val_mae ) : {:.4f}".format( min(history.history["val_mae"]) ) ) print("min( val_mae ) : {:.4f}".format( min(history.history["val_mae"]) ) )
ooo.plot_history(history, plot={'MSE' :['mse', 'val_mse'], fidle.scrawler.history( history, plot={'MSE' :['mse', 'val_mse'],
'MAE' :['mae', 'val_mae'], 'MAE' :['mae', 'val_mae'],
'LOSS':['loss','val_loss']}) 'LOSS':['loss','val_loss']}, save_as='01-history')
## Step 7 - Make a prediction ## Step 7 - Make a prediction
The data must be normalized with the parameters (mean, std) previously used.
my_data = [ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745, my_data = [ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745,
-2.14308942, 1.13489104, -1.06802005, 1.71189006, 1.57042287, -2.14308942, 1.13489104, -1.06802005, 1.71189006, 1.57042287,
0.77859951, 0.14769795, 2.7585581 ] 0.77859951, 0.14769795, 2.7585581 ]
real_price = 10.4 real_price = 10.4
my_data=np.array(my_data).reshape(1,13) my_data=np.array(my_data).reshape(1,13)
predictions = model.predict( my_data ) predictions = model.predict( my_data, verbose=fit_verbosity )
print("Prédiction : {:.2f} K$".format(predictions[0][0])) print("Prediction : {:.2f} K$".format(predictions[0][0]))
print("Reality : {:.2f} K$".format(real_price)) print("Reality : {:.2f} K$".format(real_price))
``` python
fidle.end()
That's all folks ! <img width="80px" src="../fidle/img/logo-paysage.svg"></img>
## A very simple example of **regression** (Premium edition):
Objective is to predicts **housing prices** from a set of house features. # <!-- TITLE --> [K3BHPD2] - Regression with a Dense Network (DNN) - Advanced code
<!-- DESC --> A more advanced implementation of the precedent example, using Keras3
## Objectives :
- Understanding the principle and the architecture of a regression with a dense neural network with backup and restore of the trained model.
Alongside with price, the dataset also provide these information :
The **[Boston Housing Dataset](https://www.cs.toronto.edu/~delve/data/boston/bostonDetail.html)** consists of price of houses in various places in Boston. ## What we're going to do :
- (Retrieve data) - (Retrieve data)
- (Preparing the data) - (Preparing the data)
- (Build a model) - (Build a model)
- Train and save the model - Train and save the model
- Restore saved model - Restore saved model
- Evaluate the model - Evaluate the model
- Make some predictions - Make some predictions
import keras
from IPython.display import display, Markdown from IPython.display import Markdown
from importlib import reload from importlib import reload
sys.path.append('..') import fidle
run_id, run_dir, datasets_dir = fidle.init('K3BHPD2')
- 0 = silent
- 1 = progress bar
``` python
fit_verbosity = 1
display(data.head(5).style.format("{0:.2f}")) display(data.head(5).style.format("{0:.2f}"))
We will use 80% of the data for training and 20% for validation. We will use 80% of the data for training and 20% for validation.
# ---- Split => train, test # ---- Split => train, test
- To do this we will subtract the mean and divide by the standard deviation. - To do this we will subtract the mean and divide by the standard deviation.
More informations about : More informations about :
model.add(keras.layers.Dense(64, activation='relu')) model.add(keras.layers.Dense(64, activation='relu', name='Dense_n1'))
model.compile(optimizer = 'rmsprop', model.compile(optimizer = 'rmsprop',
## 5/ Train the model ## 5 - Train the model
### 5.1/ Get it ### 5.1 - Get it
### 5.2/ Add callback ### 5.2 - Add callback
os.makedirs('./run/models', mode=0o750, exist_ok=True) os.makedirs(f'{run_dir}/models', mode=0o750, exist_ok=True)
save_dir = "./run/models/best_model.h5" save_dir = f'{run_dir}/models/best_model.keras'
savemodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, save_best_only=True)
savemodel_callback = keras.callbacks.ModelCheckpoint( filepath=save_dir, monitor='val_mae', mode='max', save_best_only=True)
### 5.3/ Train it ### 5.3 - Train it
y_train, y_train,
epochs = 100, epochs = 50,
verbose = 0, verbose = fit_verbosity,
validation_data = (x_test, y_test), validation_data = (x_test, y_test),
callbacks = [savemodel_callback]) callbacks = [savemodel_callback])
reload(ooo) fidle.scrawler.history( history, plot={'MSE' :['mse', 'val_mse'],
ooo.plot_history(history, plot={'MSE' :['mse', 'val_mse'], 'MAE' :['mae', 'val_mae'],
'MAE' :['mae', 'val_mae'], 'LOSS':['loss','val_loss']}, save_as='01-history')
## 7/ Restore a model : ## Step 7 - Restore a model :
### 7.1/ Reload model ### 7.1 - Reload model
loaded_model = tf.keras.models.load_model('./run/models/best_model.h5') loaded_model = keras.models.load_model(f'{run_dir}/models/best_model.keras')
loaded_model.summary() loaded_model.summary()
print("Loaded.") print("Loaded.")
### 7.2/ Evaluate it : ### 7.2 - Evaluate it :
score = loaded_model.evaluate(x_test, y_test, verbose=0) score = loaded_model.evaluate(x_test, y_test, verbose=0)
### 7.3/ Make a prediction ### 7.3 - Make a prediction
mon_test=[ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745, my_data = [ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745,
real_price = 10.4
mon_test=np.array(mon_test).reshape(1,13) my_data=np.array(my_data).reshape(1,13)
predictions = loaded_model.predict( my_data, verbose=fit_verbosity )
print("Prediction : {:.2f} K$ Reality : {:.2f} K$".format(predictions[0][0], real_price))
predictions = loaded_model.predict( mon_test ) %% Cell type:code id: tags:
print("Prédiction : {:.2f} K$ Reality : {:.2f} K$".format(predictions[0][0], y_train[13]))
``` python
fidle.end()
# <!-- TITLE --> [PBHPD1] - Regression with a Dense Network (DNN)
<!-- DESC --> A Simple regression with a Dense Neural Network (DNN) using Pytorch - BHPD dataset
<!-- AUTHOR : Jean-Luc Parouty (CNRS/SIMaP), Laurent Risser (CNRS/IMT) -->
## Objectives :
- Retrieve data
- Build a model
- Train the model
``` python
import torch
import torch.nn as nn
import torch.nn.functional as F
from torch.autograd import Variable
import numpy as np
import sys,os
import pandas as pd
from modules.fidle_pwk_additional import convergence_history_MSELoss
import fidle
run_id, run_dir, datasets_dir = fidle.init('PBHPD1')
Boston housing is a famous historic dataset, which can be get here: [Boston housing datasets](https://www.kaggle.com/puxama/bostoncsv)
``` python
data = pd.read_csv('./BostonHousing.csv', header=0)
``` python
**Note :**
``` python
std = x_train.std()
- [Optimizer](https://pytorch.org/docs/stable/optim.html)
- [Basic neural-network blocks](https://pytorch.org/docs/stable/nn.html)
- [Loss](https://pytorch.org/docs/stable/nn.html#loss-functions)
``` python
class model_v1(nn.Module):
Basic fully connected neural-network for tabular data
def __init__(self,num_vars):
super(model_v1, self).__init__()
self.num_vars=num_vars
self.hidden1 = nn.Linear(self.num_vars, 64)
self.hidden2 = nn.Linear(64, 64)
self.hidden3 = nn.Linear(64, 1)
def forward(self, x):
x = x.view(-1,self.num_vars) #flatten the observation before using fully-connected layers
x = self.hidden1(x)
x = F.relu(x)
x = self.hidden2(x)
x = F.relu(x)
x = self.hidden3(x)
return x
### 5.1 - Stochastic gradient descent strategy to fit the model
``` python
def fit(model,X_train,Y_train,X_test,Y_test, EPOCHS = 5, BATCH_SIZE = 32):
loss = nn.MSELoss()
optimizer = torch.optim.Adam(model.parameters(),lr=1e-3) #lr is the learning rate
model.train()
history=convergence_history_MSELoss()
history.update(model,X_train,Y_train,X_test,Y_test)
n=X_train.shape[0] #number of observations in the training data
#stochastic gradient descent
for epoch in range(EPOCHS):
batch_start=0
epoch_shuffler=np.arange(n)
np.random.shuffle(epoch_shuffler) #remark that 'utilsData.DataLoader' could be used instead
while batch_start+BATCH_SIZE < n:
#get mini-batch observation
mini_batch_observations = epoch_shuffler[batch_start:batch_start+BATCH_SIZE]
var_X_batch = Variable(X_train[mini_batch_observations,:]).float()
var_Y_batch = Variable(Y_train[mini_batch_observations]).float()
#gradient descent step
optimizer.zero_grad() #set the parameters gradients to 0
Y_pred_batch = model(var_X_batch) #predict y with the current NN parameters
curr_loss = loss(Y_pred_batch.view(-1), var_Y_batch.view(-1)) #compute the current loss
curr_loss.backward() #compute the loss gradient w.r.t. all NN parameters
optimizer.step() #update the NN parameters
#prepare the next mini-batch of the epoch
batch_start+=BATCH_SIZE
return history
#### 5.2 - Get the model
``` python
model=model_v1( x_train[0,:].shape[0] )
print(model)
#### 5.3 - Train the model
``` python
torch_x_train=torch.from_numpy(x_train)
torch_y_train=torch.from_numpy(y_train)
torch_x_test=torch.from_numpy(x_test)
torch_y_test=torch.from_numpy(y_test)
batch_size = 10
epochs = 100
history=fit(model,torch_x_train,torch_y_train,torch_x_test,torch_y_test,EPOCHS=epochs,BATCH_SIZE = batch_size)
``` python
var_x_test = Variable(torch_x_test).float()
var_y_test = Variable(torch_y_test).float()
y_pred = model(var_x_test)
nn_loss = nn.MSELoss()
nn_MAE_loss = nn.L1Loss()
print('x_test / loss : {:5.4f}'.format(nn_loss(y_pred.view(-1), var_y_test.view(-1)).item()))
print('x_test / mae : {:5.4f}'.format(nn_MAE_loss(y_pred.view(-1), var_y_test.view(-1)).item()))
``` python
df.describe()
``` python
``` python
fidle.scrawler.history(history, plot={'MAE' :['mae', 'val_mae'],
``` python
real_price = 10.4
``` python
torch_my_data=torch.from_numpy(my_data)
var_my_data = Variable(torch_my_data).float()
predictions = model( var_my_data )
File moved
import torch
import numpy as np
class convergence_history_CrossEntropyLoss:
def __init__(self):
Class to save the training converge properties
self.loss=nn.CrossEntropyLoss()
self.history={} #Save convergence measures in the end of each epoch
self.history['loss']=[] #value of the cost function on training data
self.history['accuracy']=[] #percentage of correctly classified instances on training data (if classification)
self.history['val_loss']=[] #value of the cost function on validation data
self.history['val_accuracy']=[] #percentage of correctly classified instances on validation data (if classification)
def update(self,current_model,xtrain,ytrain,xtest,ytest):
#convergence information on the training data
nb_training_obs=xtrain.shape[0]
if nb_training_obs>xtest.shape[0]:
nb_training_obs=xtest.shape[0]
epoch_shuffler=np.arange(xtrain.shape[0])
mini_batch_observations = epoch_shuffler[:nb_training_obs]
var_X_batch = Variable(xtrain[mini_batch_observations,:]).float()
var_y_batch = Variable(ytrain[mini_batch_observations])
y_pred_batch = current_model(var_X_batch)
curr_loss = self.loss(y_pred_batch, var_y_batch)
self.history['loss'].append(curr_loss.item())
self.history['accuracy'].append( float( (torch.argmax(y_pred_batch, dim= 1) == var_y_batch).float().mean()) )
#convergence information on the test data
var_X_batch = Variable(xtest[:,:]).float()
var_y_batch = Variable(ytest[:])
self.history['val_loss'].append(curr_loss.item())
self.history['val_accuracy'].append( float( (torch.argmax(y_pred_batch, dim= 1) == var_y_batch).float().mean()) )
class convergence_history_MSELoss:
def __init__(self):
self.loss = nn.MSELoss()
self.MAE_loss = nn.L1Loss()
self.history['mae']=[] #mean absolute error on training data
self.history['val_mae']=[] #mean absolute error on validation data
var_y_batch = Variable(ytrain[mini_batch_observations]).float()
curr_loss = self.loss(y_pred_batch.view(-1), var_y_batch.view(-1))
self.history['mae'].append(self.MAE_loss(y_pred_batch.view(-1), var_y_batch.view(-1)).item())
var_y_batch = Variable(ytest[:]).float()
self.history['val_mae'].append(self.MAE_loss(y_pred_batch.view(-1), var_y_batch.view(-1)).item())
# <!-- TITLE --> [PLSHEEP3] - A DCGAN to Draw a Sheep, using Pytorch Lightning
<!-- DESC --> "Draw me a sheep", revisited with a DCGAN, using Pytorch Lightning
## Objectives :
- Build and train a DCGAN model with the Quick Draw dataset
- Understanding DCGAN
The [Quick draw dataset](https://quickdraw.withgoogle.com/data) contains about 50.000.000 drawings, made by real people...
We are using a subset of 117.555 of Sheep drawings
To get the dataset : [https://github.com/googlecreativelab/quickdraw-dataset](https://github.com/googlecreativelab/quickdraw-dataset)
Datasets in numpy bitmap file : [https://console.cloud.google.com/storage/quickdraw_dataset/full/numpy_bitmap](https://console.cloud.google.com/storage/quickdraw_dataset/full/numpy_bitmap)
Sheep dataset : [https://storage.googleapis.com/quickdraw_dataset/full/numpy_bitmap/sheep.npy](https://storage.googleapis.com/quickdraw_dataset/full/numpy_bitmap/sheep.npy) (94.3 Mo)
- Have a look to the dataset
- Defining a GAN model
- Build the model
- Train it
- Have a look of the results
## Step 1 - Init and parameters
#### Python init
``` python
import os
import sys
import shutil
import numpy as np
import torch
from lightning import Trainer
from lightning.pytorch.callbacks import ModelCheckpoint
from lightning.pytorch.loggers.tensorboard import TensorBoardLogger
import fidle
from modules.QuickDrawDataModule import QuickDrawDataModule
from modules.GAN import GAN
from modules.WGANGP import WGANGP
from modules.Generators import *
from modules.Discriminators import *
run_id, run_dir, datasets_dir = fidle.init('PLSHEEP3')
#### Few parameters
scale=1, epochs=20 : Need 22' on a V100
``` python
latent_dim = 128
gan_name = 'WGANGP'
generator_name = 'Generator_2'
discriminator_name = 'Discriminator_3'
scale = 0.001
epochs = 4
num_workers = 2
lr = 0.0001
b1 = 0.5
b2 = 0.999
lambda_gp = 10
batch_size = 64
num_img = 48
fit_verbosity = 2
dataset_file = datasets_dir+'/QuickDraw/origine/sheep.npy'
data_shape = (28,28,1)
``` python
fidle.override('latent_dim', 'gan_name', 'generator_name', 'discriminator_name')
fidle.override('epochs', 'lr', 'b1', 'b2', 'batch_size', 'num_img', 'fit_verbosity')
fidle.override('dataset_file', 'data_shape', 'scale', 'num_workers' )
#### Cleaning
``` python
# You can comment these lines to keep each run...
shutil.rmtree(f'{run_dir}/figs', ignore_errors=True)
shutil.rmtree(f'{run_dir}/models', ignore_errors=True)
shutil.rmtree(f'{run_dir}/tb_logs', ignore_errors=True)
## Step 2 - Get some nice data
#### Get a Nice DataModule
Our DataModule is defined in [./modules/QuickDrawDataModule.py](./modules/QuickDrawDataModule.py)
This is a [LightningDataModule](https://pytorch-lightning.readthedocs.io/en/stable/data/datamodule.html)
``` python
dm = QuickDrawDataModule(dataset_file, scale, batch_size, num_workers=num_workers)
dm.setup()
#### Have a look
``` python
dl = dm.train_dataloader()
batch_data = next(iter(dl))
fidle.scrawler.images( batch_data.reshape(-1,28,28), indices=range(batch_size), columns=12, x_size=1, y_size=1,
y_padding=0,spines_alpha=0, save_as='01-Sheeps')
## Step 3 - Get a nice GAN model
Our Generators are defined in [./modules/Generators.py](./modules/Generators.py)
Our Discriminators are defined in [./modules/Discriminators.py](./modules/Discriminators.py)
Our GANs are defined in :
- [./modules/GAN.py](./modules/GAN.py)
- [./modules/WGANGP.py](./modules/WGANGP.py)
#### Retrieve class by name
To be very flexible, we just specify class names as parameters.
The code below retrieves classes from their names.
``` python
module=sys.modules['__main__']
Generator_ = getattr(module, generator_name)
Discriminator_ = getattr(module, discriminator_name)
GAN_ = getattr(module, gan_name)
#### Basic test - Just to be sure it (could) works... ;-)
``` python
generator = Generator_( latent_dim=latent_dim, data_shape=data_shape )
discriminator = Discriminator_( latent_dim=latent_dim, data_shape=data_shape )
print('\nFew tests :\n')
z = torch.randn(batch_size, latent_dim)
print('z size : ',z.size())
fake_img = generator.forward(z)
print('fake_img : ', fake_img.size())
p = discriminator.forward(fake_img)
print('pred fake : ', p.size())
print('batch_data : ',batch_data.size())
p = discriminator.forward(batch_data)
print('pred real : ', p.size())
print('\nShow fake images :')
nimg = fake_img.detach().numpy()
fidle.scrawler.images( nimg.reshape(-1,28,28), indices=range(batch_size), columns=12, x_size=1, y_size=1,
``` python
print('Fake images : ', fake_img.size())
print('Batch size : ', batch_data.size())
e = torch.distributions.uniform.Uniform(0, 1).sample([batch_size,1])
e = e[:None,None,None]
i = fake_img * e + (1-e)*batch_data
print('\ninterpolate images :')
nimg = i.detach().numpy()
#### GAN model
To simplify our code, the GAN class is defined separately in the module [./modules/GAN.py](./modules/GAN.py)
Passing the classe names for generator/discriminator by parameter allows to stay modular and to use the PL checkpoints.
``` python
gan = GAN_( data_shape = data_shape,
lr = lr,
b1 = b1,
b2 = b2,
lambda_gp = lambda_gp,
latent_dim = latent_dim,
generator_name = generator_name,
discriminator_name = discriminator_name)
## Step 5 - Train it !
#### Instantiate Callbacks, Logger & co.
More about :
- [Checkpoints](https://pytorch-lightning.readthedocs.io/en/stable/common/checkpointing_basic.html)
- [modelCheckpoint](https://pytorch-lightning.readthedocs.io/en/stable/api/pytorch_lightning.callbacks.ModelCheckpoint.html#pytorch_lightning.callbacks.ModelCheckpoint)
``` python
# ---- for tensorboard logs
logger = TensorBoardLogger( save_dir = f'{run_dir}',
name = 'tb_logs' )
log_dir = os.path.abspath(f'{run_dir}/tb_logs')
print('To access the logs with tensorboard, use this command line :')
print(f'tensorboard --logdir {log_dir}')
# ---- To save checkpoints
callback_checkpoints = ModelCheckpoint( dirpath = f'{run_dir}/models',
filename = 'bestModel',
save_top_k = 1,
save_last = True,
every_n_epochs = 1,
monitor = "g_loss")
#### Train it
``` python
trainer = Trainer(
accelerator = "auto",
max_epochs = epochs,
callbacks = [callback_checkpoints],
log_every_n_steps = batch_size,
logger = logger
trainer.fit(gan, dm)
## Step 6 - Reload our best model
Note :
``` python
gan = GAN.load_from_checkpoint(f'{run_dir}/models/bestModel.ckpt')
``` python
nb_images = 96
z = torch.randn(nb_images, latent_dim)
if torch.cuda.is_available(): z=z.cuda()
fake_img = gan.generator.forward(z)
nimg = fake_img.cpu().detach().numpy()
fidle.scrawler.images( nimg.reshape(-1,28,28), indices=range(nb_images), columns=12, x_size=1, y_size=1,
``` python
fidle.end()
# _____ _ _ _
# |_| |_|\__,_|_|\___| GAN / Generators
# CNRS/MIAI - https://fidle.cnrs.fr
# JL Parouty (Mars 2024)
import numpy as np
# -- Discriminator n°1
class Discriminator_1(nn.Module):
A basic DNN discriminator, usable with classic GAN
def __init__(self, latent_dim=None, data_shape=None):
super().__init__()
self.img_shape = data_shape
print('init discriminator 1 : ',data_shape,' to sigmoid')
self.model = nn.Sequential(
nn.Flatten(),
nn.Linear(int(np.prod(data_shape)), 512),
nn.ReLU(),
nn.Linear(512, 256),
nn.ReLU(),
nn.Linear(256, 1),
nn.Sigmoid(),
def forward(self, img):
validity = self.model(img)
return validity
# -- Discriminator n°2
class Discriminator_2(nn.Module):
A more efficient discriminator,based on CNN, usable with classic GAN
super().__init__()
print('init discriminator 2 : ',data_shape,' to sigmoid')
nn.Conv2d(1, 32, kernel_size = 3, stride = 2, padding = 1),
nn.ReLU(),
nn.BatchNorm2d(32),
nn.Dropout2d(0.25),
nn.Conv2d(32, 64, kernel_size = 3, stride = 1, padding = 1),
nn.ReLU(),
nn.BatchNorm2d(64),
nn.Dropout2d(0.25),
nn.Conv2d(64, 128, kernel_size = 3, stride = 1, padding = 1),
nn.ReLU(),
nn.BatchNorm2d(128),
nn.Dropout2d(0.25),
nn.Conv2d(128, 256, kernel_size = 3, stride = 2, padding = 1),
nn.ReLU(),
nn.BatchNorm2d(256),
nn.Dropout2d(0.25),
nn.Flatten(),
nn.Linear(12544, 1),
nn.Sigmoid(),
img_nchw = img.permute(0, 3, 1, 2) # reformat from NHWC to NCHW
validity = self.model(img_nchw)
return validity
# -- Discriminator n°3
class Discriminator_3(nn.Module):
A CNN discriminator, usable with a WGANGP.
This discriminator has no sigmoid and returns a critical and not a probability
super().__init__()
print('init discriminator 3 : ',data_shape,' to sigmoid')
nn.ReLU(),
nn.BatchNorm2d(32),
nn.Dropout2d(0.25),
nn.ReLU(),
nn.BatchNorm2d(64),
nn.Dropout2d(0.25),
nn.ReLU(),
nn.Dropout2d(0.25),
nn.ReLU(),
nn.Dropout2d(0.25),
nn.Flatten(),
nn.Sigmoid(),
return validity
# _____ _ _ _
# |_| |_|\__,_|_|\___| Basic GAN LigthningModule
import sys
import numpy as np
import torch
import torchvision
from lightning import LightningModule
class GAN(LightningModule):
# Init
def __init__(
self,
data_shape = (None,None,None),
latent_dim = None,
lr = 0.0002,
b1 = 0.5,
b2 = 0.999,
batch_size = 64,
generator_name = None,
discriminator_name = None,
**kwargs,
super().__init__()
print('\n---- GAN initialization --------------------------------------------')
# ---- Hyperparameters
# Enable Lightning to store all the provided arguments under the self.hparams attribute.
# These hyperparameters will also be stored within the model checkpoint.
self.save_hyperparameters()
print('Hyperarameters are :')
for name,value in self.hparams.items():
print(f'{name:24s} : {value}')
# ---- Because we have more than one optimizer
self.automatic_optimization = False
# ---- Generator/Discriminator instantiation
print('Submodels :')
class_g = getattr(module, generator_name)
class_d = getattr(module, discriminator_name)
self.generator = class_g( latent_dim=latent_dim, data_shape=data_shape)
self.discriminator = class_d( latent_dim=latent_dim, data_shape=data_shape)
# ---- Validation and example data
self.validation_z = torch.randn(8, self.hparams.latent_dim)
self.example_input_array = torch.zeros(2, self.hparams.latent_dim)
def forward(self, z):
return self.generator(z)
def adversarial_loss(self, y_hat, y):
return F.binary_cross_entropy(y_hat, y)
def training_step(self, batch, batch_idx):
imgs = batch
batch_size = batch.size(0)
optimizer_g, optimizer_d = self.optimizers()
# ---- Get some latent space vectors
# We use type_as() to make sure we initialize z on the right device (GPU/CPU).
z = torch.randn(batch_size, self.hparams.latent_dim)
z = z.type_as(imgs)
# ---- Train generator ------------------------------------------------
# Generator use optimizer #0
# We try to generate false images that could mislead the discriminator
self.toggle_optimizer(optimizer_g)
# Generate fake images
self.fake_imgs = self.generator.forward(z)
# Assemble labels that say all images are real, yes it's a lie ;-)
# put on GPU because we created this tensor inside training_loop
misleading_labels = torch.ones(batch_size, 1)
misleading_labels = misleading_labels.type_as(imgs)
# Adversarial loss is binary cross-entropy
y_hat = self.discriminator.forward(self.fake_imgs)
# print(y_hat)
g_loss = self.adversarial_loss(self.discriminator.forward(self.fake_imgs), misleading_labels)
self.log("g_loss", g_loss, prog_bar=True)
# Backward loss
self.manual_backward(g_loss)
optimizer_g.step()
optimizer_g.zero_grad()
self.untoggle_optimizer(optimizer_g)
# ---- Train discriminator --------------------------------------------
# Discriminator use optimizer #1
# We try to make the difference between fake images and real ones
self.toggle_optimizer(optimizer_d)
# These images are reals
real_labels = torch.ones(batch_size, 1)
real_labels = real_labels.type_as(imgs)
pred_labels = self.discriminator.forward(imgs)
real_loss = self.adversarial_loss(pred_labels, real_labels)
# These images are fake
fake_labels = torch.zeros(batch_size, 1)
fake_labels = fake_labels.type_as(imgs)
fake_loss = self.adversarial_loss(self.discriminator(fake_imgs.detach()), fake_labels)
# Discriminator loss is the average
d_loss = (real_loss + fake_loss) / 2
self.log("d_loss", d_loss, prog_bar=True)
# Backward
self.manual_backward(d_loss)
optimizer_d.step()
optimizer_d.zero_grad()
self.untoggle_optimizer(optimizer_d)
def configure_optimizers(self):
lr = self.hparams.lr
b1 = self.hparams.b1
b2 = self.hparams.b2
# With a GAN, we need 2 separate optimizer.
# opt_g = torch.optim.Adam(self.generator.parameters(), lr=lr, betas=(b1, b2))
# opt_d = torch.optim.Adam(self.discriminator.parameters(), lr=lr, betas=(b1, b2),)
opt_g = torch.optim.Adam(self.generator.parameters(), lr=lr)
opt_d = torch.optim.Adam(self.discriminator.parameters(), lr=lr)
return [opt_g, opt_d], []
def on_train_epoch_end(self):
# ---- Log Graph
if(self.current_epoch==1):
sampleImg=torch.rand((1,28,28,1))
sampleImg=sampleImg.type_as(self.generator.model[0].weight)
self.logger.experiment.add_graph(self.discriminator,sampleImg)
# ---- Log some of these images
z = torch.randn(self.hparams.batch_size, self.hparams.latent_dim)
z = z.type_as(self.generator.model[0].weight)
sample_imgs = self.generator(z)
sample_imgs = sample_imgs.permute(0, 3, 1, 2) # from NHWC to NCHW
grid = torchvision.utils.make_grid(tensor=sample_imgs, nrow=12, )
self.logger.experiment.add_image(f"Generated images", grid,self.current_epoch)
# _____ _ _ _
import numpy as np
# -- Generator n°1
class Generator_1(nn.Module):
super().__init__()
self.latent_dim = latent_dim
print('init generator 1 : ',latent_dim,' to ',data_shape)
nn.Linear(latent_dim, 128),
nn.ReLU(),
nn.Linear(128,256),
nn.BatchNorm1d(256, 0.8),
nn.ReLU(),
nn.Linear(256, 512),
nn.BatchNorm1d(512, 0.8),
nn.ReLU(),
nn.Linear(512, 1024),
nn.BatchNorm1d(1024, 0.8),
nn.ReLU(),
nn.Linear(1024, int(np.prod(data_shape))),
nn.Sigmoid()
img = self.model(z)
img = img.view(img.size(0), *self.img_shape)
return img
# -- Generator n°1
class Generator_2(nn.Module):
super().__init__()
print('init generator 2 : ',latent_dim,' to ',data_shape)
nn.Linear(latent_dim, 7*7*64),
nn.Unflatten(1, (64,7,7)),
# nn.UpsamplingNearest2d( scale_factor=2 ),
nn.UpsamplingBilinear2d( scale_factor=2 ),
nn.Conv2d( 64,128, (3,3), stride=(1,1), padding=(1,1) ),
nn.ReLU(),
nn.Conv2d( 128,256, (3,3), stride=(1,1), padding=(1,1)),
nn.ReLU(),
nn.Conv2d( 256,1, (5,5), stride=(1,1), padding=(2,2)),
nn.Sigmoid()
img_nchw = self.model(z)
img_nhwc = img_nchw.permute(0, 2, 3, 1) # reformat from NCHW to NHWC
# img = img.view(img.size(0), *self.img_shape) # reformat from NCHW to NHWC
return img_nhwc
# _____ _ _ _
# |_| |_|\__,_|_|\___| GAN / QuickDrawDataModule
import numpy as np
import torch
from lightning import LightningDataModule
from torch.utils.data import DataLoader
class QuickDrawDataModule(LightningDataModule):
def __init__( self, dataset_file='./sheep.npy', scale=1., batch_size=64, num_workers=4 ):
super().__init__()
print('\n---- QuickDrawDataModule initialization ----------------------------')
print(f'with : scale={scale} batch size={batch_size}')
self.scale = scale
self.dataset_file = dataset_file
self.batch_size = batch_size
self.num_workers = num_workers
self.dims = (28, 28, 1)
self.num_classes = 10
def prepare_data(self):
pass
def setup(self, stage=None):
print('\nDataModule Setup :')
# Load dataset
# Called at the beginning of each stage (train,val,test)
# Here, whatever the stage value, we'll have only one set.
data = np.load(self.dataset_file)
print('Original dataset shape : ',data.shape)
# Rescale
n=int(self.scale*len(data))
data = data[:n]
print('Rescaled dataset shape : ',data.shape)
# Normalize, reshape and shuffle
data = data/255
data = data.reshape(-1,28,28,1)
data = torch.from_numpy(data).float()
print('Final dataset shape : ',data.shape)
print('Dataset loaded and ready.')
self.data_train = data
def train_dataloader(self):
# Note : Numpy ndarray is Dataset compliant
# Have map-style interface. See https://pytorch.org/docs/stable/data.html
return DataLoader( self.data_train, batch_size=self.batch_size, num_workers=self.num_workers )
