Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • samanost/sicom_image_analysis_project
  • gerayelk/sicom_image_analysis_project
  • jelassiy/sicom_image_analysis_project
  • chardoto/sicom_image_analysis_project
  • chaarim/sicom_image_analysis_project
  • domers/sicom_image_analysis_project
  • elmurrt/sicom_image_analysis_project
  • sadonest/sicom_image_analysis_project
  • kouddann/sicom_image_analysis_project
  • mirabitj/sicom-image-analysis-project-mirabito
  • plotj/sicom_image_analysis_project
  • torrem/sicom-image-analysis-project-maxime-torre
  • dzike/sicom_image_analysis_project
  • daip/sicom_image_analysis_project
  • casanovv/sicom_image_analysis_project
  • girmarti/sicom_image_analysis_project
  • lioretn/sicom_image_analysis_project
  • lemoinje/sicom_image_analysis_project
  • ouahmanf/sicom_image_analysis_project
  • vouilloa/sicom_image_analysis_project
  • diopb/sicom_image_analysis_project
  • davidale/sicom_image_analysis_project
  • enza/sicom_image_analysis_project
  • conversb/sicom_image_analysis_project
  • mullemat/sicom_image_analysis_project
25 results
Show changes
Commits on Source (85)
Showing
with 600 additions and 1 deletion
File mode changed from 100755 to 100644
File added
"""The main file for the reconstruction.
This file should NOT be modified except the body of the 'run_reconstruction' function.
Students can call their functions (declared in others files of src/methods/your_name).
import numpy as np
from src.forward_model import CFA
from src.methods.Chardon_tom.utils import *
import pywt
#!!!!!!!! It is normal that the reconstructions lasts several minutes (3min on my computer)
def run_reconstruction(y: np.ndarray, cfa: str) -> np.ndarray:
"""Performs demosaicking on y.
Args:
y (np.ndarray): Mosaicked image to be reconstructed.
cfa (str): Name of the CFA. Can be bayer or quad_bayer.
Returns:
np.ndarray: Demosaicked image.
# Define constants and operators
cfa_name = 'bayer' # bayer or quad_bayer
input_shape = (y.shape[0], y.shape[1], 3)
op = CFA(cfa_name, input_shape)
res = op.adjoint(y)
N,M = input_shape[0], input_shape[1]
#interpolating green channel
for i in range (N):
for j in range (M):
if res[i,j,1] ==0:
neighbors = get_neighbors(res,1,i,j,N,M)
weights = get_weights(res,i,j,1,N,M)
res[i,j,1] = interpolate_green(weights, neighbors)
#first intepolation of red channel
for i in range (1,N,2):
for j in range (0,M,2):
neighbors = get_neighbors(res,0,i,j,N,M)
neighbors_G = get_neighbors(res,1,i,j,N,M)
weights = get_weights(res,i,j,0,N,M)
res[i,j,0] = interpolate_red_blue(weights,neighbors, neighbors_G)
# second interpolation of red channel
for i in range (N):
for j in range (M):
if res[i,j,0] ==0:
res[i,j,0] = interpolate_green(weights, neighbors)
#first interpolation of blue channel
for i in range (0,N,2):
for j in range (1,M,2):
neighbors = get_neighbors(res,2,i,j,N,M)
weights = get_weights(res,i,j,2,N,M)
res[i,j,2] = interpolate_red_blue(weights, neighbors, neighbors_G)
#second interpolation of blue channel
for i in range (N):
for j in range (M):
if res[i,j,2] ==0:
res[i,j,2] = interpolate_green(weights,neighbors)
# k=0
# while k<2 :
# for i in range(input_shape[0]):
# for j in range(input_shape[1]):
# res[i][j][1] = correction_green(res,i,j,N,M)
# res[i][j][0] = correction_red(res,i,j,N,M)
# res[i][j][2] = correction_blue(res,i,j,N,M)
# k+=1
res[res>1] = 1
res[res<0] = 0
return res
import numpy as np
import pywt
def get_neighbors (img,channel,i,j,N,M):
P1 = img[(i-1)%N,(j-1)%M,channel]
P2 = img[(i-1)%N,j%M,channel]
P3 = img[(i-1)%N,(j+1)%M,channel]
P4 = img[i%N,(j-1)%M,channel]
P5 = img[i%N,j%M,channel]
P6 = img[i%N,(j+1)%M,channel]
P7 = img[(i+1)%N,(j-1)%M,channel]
P8 = img[(i+1)%N,j%M,channel]
P9 = img[(i+1)%N,(j+1)%M,channel]
return np.array([P1,P2,P3,P4,P5,P6,P7,P8,P9])
def get_derivatives(neighbors):
[P1, P2, P3, P4, P5, P6, P7, P8, P9] = neighbors
D_x = (P4 - P6)/2
D_y = (P2 - P8)/2
D_xd = (P3 - P7)/(2*np.sqrt(2))
D_yd = (P1 - P9)/(2*np.sqrt(2))
return ([D_x, D_y, D_xd, D_yd])
def get_weights(mosaic_image, i, j, channel, N, M):
derivatives_neigbors = []
for l in range(-1, 2):
for L in range(-1, 2):
derivatives_neigbors.append(get_derivatives(
get_neighbors(mosaic_image, channel, i+l, j+L, N, M)))
[Dx, Dy, Dxd, Dyd] = derivatives_neigbors[4]
E1 = 1/np.sqrt(1 + Dyd**2 + derivatives_neigbors[0][3]**2)
E2 = 1/np.sqrt(1 + Dy**2 + derivatives_neigbors[1][1]**2)
E3 = 1/np.sqrt(1 + Dxd**2 + derivatives_neigbors[2][2]**2)
E4 = 1/np.sqrt(1 + Dx**2 + derivatives_neigbors[3][0]**2)
E6 = 1/np.sqrt(1 + Dxd**2 + derivatives_neigbors[5][2]**2)
E7 = 1/np.sqrt(1 + Dy**2 + derivatives_neigbors[6][1]**2)
E8 = 1/np.sqrt(1 + Dyd**2 + derivatives_neigbors[7][3]**2)
E9 = 1/np.sqrt(1 + Dx**2 + derivatives_neigbors[8][0]**2)
E = [E1, E2, E3, E4, E6, E7, E8, E9]
return E
def interpolate_green(weights, neighbors):
[E1, E2, E3, E4, E6, E7, E8, E9] = weights
I5 = (E2*P2 + E4*P4 + E6*P6 + E8*P8)/(E2 + E4 + E6 + E8)
return (I5)
def interpolate_red_blue(weights, neighbors, green_neighbors):
[G1, G2, G3, G4, G5, G6, G7, G8, G9] = green_neighbors
I5 = G5*(E1*P1/G1 + E3*P3/G3 + E7*P7/G7 + E9*P9/G9)/(E1 + E3 + E7 + E9)
return (I5)
def correction_green(res,i,j,N,M):
[G1,G2,G3,G4,G5,G6,G7,G8,G9] = get_neighbors(res,1,i,j,N,M)
[R1,R2,R3,R4,R5,R6,R7,R8,R9] = get_neighbors(res,0,i,j,N,M)
[B1,B2,B3,B4,B5,B6,B7,B8,B9] = get_neighbors(res,2,i,j,N,M)
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,1,N,M)
Gb5 = R5*((E2*G2)/B2 + (E4*G4)/B4 + (E6*G6)/B6 + (E8*G8)/B8)/(E2 + E4 + E6 + E8)
Gr5 = B5*((E2*G2)/R2 + (E4*G4)/R4 + (E6*G6)/R6 + (E8*G8)/R8)/(E2 + E4 + E6 + E8)
G5 = (Gb5 + Gr5)/2
return G5
def correction_red(res,i,j,N,M) :
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,0,N,M)
R5 = G5*((E1*R1)/G1 + (E2*R2)/G2 + (E3*R3)/G3 + (E4*R4)/G4 + (E6*R6)/G6 + (E7*R7)/G7 + (E8*R8)/G8 + (E9*R9)/G9)/(E1 + E2 + E3 + E4 + E6 + E7 + E8 + E9)
return R5
def correction_blue(res,i,j,N,M) :
[E1,E2,E3,E4,E6,E7,E8,E9] = get_weights(res,i,j,2,N,M)
B5 = G5*((E1*B1)/G1 + (E2*B2)/G2 + (E3*B3)/G3 + (E4*B4)/G4 + (E6*B6)/G6 + (E7*B7)/G7 + (E8*B8)/G8 + (E9*B9)/G9)/(E1 + E2 + E3 + E4 + E6 + E7 + E8 + E9)
return B5
......@@ -7,7 +7,7 @@ Students can call their functions (declared in others files of src/methods/your_
import numpy as np
from src.methods.el_murr.malvar import malvar_he_cutler
from src.methods.EL_MURR_Theresa.malvar import malvar_he_cutler
# Importing libraries
import os
import colour
from colour_demosaicing import (
demosaicing_CFA_Bayer_bilinear,
demosaicing_CFA_Bayer_Malvar2004,
demosaicing_CFA_Bayer_Menon2007,
mosaicing_CFA_Bayer)
from src.utils import psnr,ssim
# Image path
image_pathes = ['images/img_1.png','images/img_2.png','images/img_3.png','images/img_4.png']
for i in image_pathes:
LIGHTHOUSE_IMAGE = colour.io.read_image(i)
img = LIGHTHOUSE_IMAGE
colour.plotting.plot_image(
colour.cctf_encoding(LIGHTHOUSE_IMAGE))
# Mosaicing
CFA = mosaicing_CFA_Bayer(LIGHTHOUSE_IMAGE)
colour.cctf_encoding(CFA),
text_kwargs={'text': 'Lighthouse - CFA - RGGB'})
colour.cctf_encoding(mosaicing_CFA_Bayer(LIGHTHOUSE_IMAGE, 'BGGR')),
text_kwargs={'text': 'Lighthouse - CFA - BGGR'});
# Demosaicing bilinear
colour.cctf_encoding(demosaicing_CFA_Bayer_bilinear(CFA)),
text_kwargs={'text': 'Demosaicing - Bilinear'});
recons_bilinear = colour.cctf_encoding(demosaicing_CFA_Bayer_bilinear(CFA))
# demosaicing Malvar
recons_malvar = colour.cctf_encoding(demosaicing_CFA_Bayer_Malvar2004(CFA))
colour.cctf_encoding(demosaicing_CFA_Bayer_Malvar2004(CFA)),
text_kwargs={'text': 'Demosaicing - Malvar (2004)'});
# demosaicing Menon
recons_menon = colour.cctf_encoding(demosaicing_CFA_Bayer_Menon2007(CFA))
colour.cctf_encoding(demosaicing_CFA_Bayer_Menon2007(CFA)),
text_kwargs={'text': 'Demosaicing - Menon (2007)'});
print('bilinear : ')
print(f'PSNR: {psnr(img, recons_bilinear):.2f}')
print(f'SSIM: {ssim(img, recons_bilinear):.4f}')
print('Malvar : ')
print(f'PSNR: {psnr(img, recons_malvar):.2f}')
print(f'SSIM: {ssim(img, recons_malvar):.4f}')
print('Menon')
print(f'PSNR: {psnr(img, recons_menon):.2f}')
print(f'SSIM: {ssim(img, recons_menon):.4f}')
\ No newline at end of file
File added
File added
import numpy as np
def clip_values(img: np.ndarray) -> np.ndarray:
"""Clip values of an image between 0 and 1
Args:
img (np.ndarray): image to clip
Returns:
np.ndarray: clipped image
# Clip values between 0 and 1
img[img < 0] = 0
img[img > 1] = 1
return img
import numpy as np
def find_direct_neighbors(neighbors: list) -> list:
Calculate the gradients in horizontal, vertical, and diagonal directions for a pixel
based on its neighboring pixels.
Args:
neighbors (list): The neighbors of a pixel in a 3x3 grid. The order of neighbors
is assumed to be [top-left, top, top-right, right, center, left,
bottom-left, bottom, bottom-right].
Returns:
list: The gradients [horizontal, vertical, diagonal-x, diagonal-y].
# Horizontal gradient: Difference between the right and left neighbors
horizontal_gradient = (neighbors[3] - neighbors[5]) / 2
# Vertical gradient: Difference between the top and bottom neighbors
vertical_gradient = (neighbors[1] - neighbors[7]) / 2
# Diagonal gradient along x-axis: Difference between top-right and bottom-left neighbors
diagonal_gradient_x = (neighbors[2] - neighbors[6]) / (2 * np.sqrt(2))
# Diagonal gradient along y-axis: Difference between top-left and bottom-right neighbors
diagonal_gradient_y = (neighbors[0] - neighbors[8]) / (2 * np.sqrt(2))
return [horizontal_gradient, vertical_gradient, diagonal_gradient_x, diagonal_gradient_y]
import numpy as np
def find_neighbors(img: np.ndarray, channel: int, i: int, j: int, N: int, M: int) -> list:
Retrieve the 3x3 neighborhood of a pixel in a specified channel of an image.
The function wraps around the image edges to handle border pixels.
Args:
img (np.ndarray): The image to process.
channel (int): The index of the channel to process.
i (int): The row index of the pixel.
j (int): The column index of the pixel.
N (int): Height of the image.
M (int): Width of the image.
Returns:
np.ndarray: An array of neighbor pixel values in the specified channel.
neighbors = []
for di in [-1, 0, 1]:
for dj in [-1, 0, 1]:
neighbor_i = (i + di) % N
neighbor_j = (j + dj) % M
neighbors.append(img[neighbor_i, neighbor_j, channel])
return np.array(neighbors)
import numpy as np
from .find_neighbors import find_neighbors
from .find_direct_neighbors import find_direct_neighbors
def find_weights(img: np.ndarray, direct_neighbors: list, channel: int, i: int, j: int, N: int, M: int) -> list:
Find the weights of the neighbors of a pixel in the image.
Args:
direct_neighbors (list): The list of direct neighbors of the pixel.
Returns:
list: The list of weights of the neighbors of the pixel.
[Dx, Dy, Dxx, Dyy] = direct_neighbors
E = []
c = 1
for k in [-1, 0, 1]:
for l in [-1, 0, 1]:
n = find_neighbors(img, channel, i + k, j + l, N, M)
dd = find_direct_neighbors(n)
sqrt_arguments = {
1: 1 + Dyy * 2 + dd[3] * 2,
3: 1 + Dxx * 2 + dd[2] * 2,
2: 1 + Dy * 2 + dd[1] * 2,
4: 1 + Dx * 2 + dd[0] * 2
value = sqrt_arguments.get(c, 1)
if value < 0:
E.append(0)
else:
E.append(1 / np.sqrt(value))
c += 1
return E
def interpolate(neighbors: list, weights: list) -> float:
Interpolate the pixel value.
Args:
neighbors (list): The neighbors of the pixel.
weights (list): The weights of the direct neighbors.
Returns:
float: The interpolated value.
return (weights[1] * neighbors[1] + weights[3] * neighbors[3] + weights[4] * neighbors[5] + weights[6] * neighbors[7]) / (weights[1] + weights[1] + weights[4] + weights[6])
def interpolate_neighboring(neighbors_0: list, neighbors_1: list, weights: list) -> float:
Interpolate the neighboring pixels.
Args:
neighbors_0 (list): The neighbors of the pixel in the channel to process.
neighbors_1 (list): The neighbors of the pixel in the green channel.
Returns:
return neighbors_1[4] * (((weights[0] * neighbors_0[0]) / neighbors_1[0]) + ((weights[2] * neighbors_0[2]) / neighbors_1[2]) + ((weights[5] * neighbors_0[6]) / neighbors_1[6]) + ((weights[7] * neighbors_0[8]) / neighbors_1[8])) / (weights[0] + weights[2] + weights[5] + weights[7])
## Main notebook for experimenting with the algorithms
Here is a simple notebook to test your code. You can modify it as you please.
Remember to restart the jupyter kernel each time you modify a file.
%% Cell type:code id: tags:
``` python
%%capture
%pip install -r requirements.txt
``` python
from src.utils import load_image, save_image, psnr, ssim
from src.methods.RHOUCH_Oussama.reconstruct import run_reconstruction
### Load the input image
``` python
image_path = 'images/img_4.png'
img = load_image(image_path)
``` python
# Shows some information on the image
plt.imshow(img)
plt.show()
print(f'Shape of the image: {img.shape}.')
### Definition of the forward model
To setup the forward operator we just need to instanciate the `CFA` class. This class needs two arguments: `cfa_name` being the kind of pattern (bayer or kodak), and `input_shape` the shape of the inputs of the operator.
This operation is linear and can be represented by a matrix $A$ but no direct access to this matrix is given (one can create it if needed). However the method `direct` allows to perform $A$'s operation. Likewise the method `adjoint` will perform the operation of $A^T$.
For example let $X \in \mathbb R^{M \times N \times 3}$ the input RGB image in natural shape. Then we got $x \in \mathbb R^{3MN}$ (vectorized version of $X$) and $A \in \mathbb R^{MN \times 3MN}$, leading to:
\begin{equation*}
y = Ax \in \mathbb R^{MN} \quad \text{and} \quad z = A^Ty \in \mathbb R^{3MN}
\end{equation*}
However thanks to `direct` and `adjoint` there is no need to work with vectorized images, except if it is interesting to create the matrix $A$ explicitly.
``` python
op = CFA(cfa_name, img.shape)
``` python
# Shows the mask
plt.imshow(op.mask[:10, :10])
plt.show()
print(f'Shape of the mask: {op.mask.shape}.')
``` python
# Applies the mask to the image
y = op.direct(img)
``` python
# Applies the adjoint operation to y
z = op.adjoint(y)
``` python
fig, axs = plt.subplots(2, 3, figsize=(15, 10))
axs[0, 0].imshow(img)
axs[0, 0].set_title('Input image')
axs[0, 1].imshow(y, cmap='gray')
axs[0, 1].set_title('Output image')
axs[0, 2].imshow(z)
axs[0, 2].set_title('Adjoint image')
axs[1, 0].imshow(img[800:864, 450:514])
axs[1, 0].set_title('Zoomed input image')
axs[1, 1].imshow(y[800:864, 450:514], cmap='gray')
axs[1, 1].set_title('Zoomed output image')
axs[1, 2].imshow(z[800:864, 450:514])
axs[1, 2].set_title('Zoomed adjoint image')
plt.show()
### Run the reconstruction
Here the goal is to reconstruct the image `img` using only `y` and `op` (using `img` is forbidden).
To run the reconstruction we simply call the function `run_reconstruction`. This function takes in argument the image to reconstruct and the kind of CFA used (bayer or kodak). All the parameters related to the reconstruction itself must be written inside `run_reconstruction`.
``` python
res = run_reconstruction(y, cfa_name)
``` python
# Prints some information on the reconstruction
print(f'Size of the reconstruction: {res.shape}.')
### Quantitative and qualitative results
``` python
fig, axs = plt.subplots(1, 2, figsize=(15, 15))
axs[0].imshow(img)
axs[0].set_title('Original image')
axs[1].imshow(res)
axs[1].set_title('Reconstructed image')
plt.show()
``` python
# Computes some metrics
print(f'PSNR: {psnr(img, res):.2f}')
print(f'SSIM: {ssim(img, res):.4f}')
``` python
reconstructed_path = 'output/reconstructed_image.png'
save_image(reconstructed_path, res)
``` python
