Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • chetouae/open-research-data-monitor-back
  • mlarrieu/open-research-data-monitor-back
2 results
Show changes
Commits on Source (82)
Showing
with 14217 additions and 66 deletions
...@@ -25,7 +25,7 @@ actualisation_dois: ...@@ -25,7 +25,7 @@ actualisation_dois:
- git config user.name "${GITLAB_USER_NAME}" - git config user.name "${GITLAB_USER_NAME}"
- git config user.email "${GITLAB_USER_EMAIL}" - git config user.email "${GITLAB_USER_EMAIL}"
- git remote set-url --push origin "https://PUSH_TOKEN:${ACCESS_TOKEN}@gricad-gitlab.univ-grenoble-alpes.fr/${CI_PROJECT_PATH}.git" - git remote set-url --push origin "https://PUSH_TOKEN:${ACCESS_TOKEN}@gricad-gitlab.univ-grenoble-alpes.fr/${CI_PROJECT_PATH}.git"
- git add -f dois-uga.csv 2-produce-graph/hist-evol-datasets-per-repo.png 2-produce-graph/hist-quantity-year-type.png 2-produce-graph/pie--datacite-client.png 2-produce-graph/pie--datacite-type.png 2-produce-graph/hist-last-datasets-by-client.png 1-enrich-with-datacite/all_datacite_clients_for_uga.csv 1-enrich-with-datacite/nb-dois.txt - git add -f dois-uga.csv dois-uga--last-500.csv 2-produce-graph/hist-evol-datasets-per-repo.png 2-produce-graph/hist-quantity-year-type.png 2-produce-graph/pie--datacite-client.png 2-produce-graph/pie--datacite-type.png 2-produce-graph/hist-last-datasets-by-client.png 1-enrich-with-datacite/all_datacite_clients_for_uga.csv 1-enrich-with-datacite/nb-dois.txt
- git commit -m "Execution du pipeline. Actualisation des dois et des graphes." - git commit -m "Execution du pipeline. Actualisation des dois et des graphes."
- git push origin HEAD:${CI_COMMIT_REF_NAME} - git push origin HEAD:${CI_COMMIT_REF_NAME}
...@@ -49,6 +49,7 @@ actualisation_dois: ...@@ -49,6 +49,7 @@ actualisation_dois:
# ajout des fichiers du dépôt qui ont été modifiés, au cas où un problème serait survenu dans "after_script" # ajout des fichiers du dépôt qui ont été modifiés, au cas où un problème serait survenu dans "after_script"
paths: paths:
- dois-uga.csv - dois-uga.csv
- dois-uga--last-500.csv
- 2-produce-graph/hist-evol-datasets-per-repo.png - 2-produce-graph/hist-evol-datasets-per-repo.png
- 2-produce-graph/hist-quantity-year-type.png - 2-produce-graph/hist-quantity-year-type.png
- 2-produce-graph/pie--datacite-client.png - 2-produce-graph/pie--datacite-client.png
...@@ -17,4 +17,18 @@ mbeligne ...@@ -17,4 +17,18 @@ mbeligne
acarbonnelle acarbonnelle
annegf annegf
tleduc tleduc
abey abey
\ No newline at end of file mbarletta
lmaritaud
jbeaureder
kboczon
llacoste
fcorsi
ecarlier
lvanbogaert
nrousselot
jlevy1
mflecheux
pbai
ymonnier
slecuyerchardevel
...@@ -22,15 +22,15 @@ urls = [ ...@@ -22,15 +22,15 @@ urls = [
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=producerAffiliation%3AUGA', 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=producerAffiliation%3AUGA',
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=contributorAffiliation%3AUGA', 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=contributorAffiliation%3AUGA',
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=datasetContactAffiliation%3A(Grenoble AND Alpes)', 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=datasetContactAffiliation%3A(Grenoble AND Alpes)',
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=authorAffiliation%3AGrenoble(Grenoble AND Alpes)', 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=authorAffiliation%3A(Grenoble AND Alpes)',
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=producerAffiliation%3AGrenoble(Grenoble AND Alpes)', 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=producerAffiliation%3A(Grenoble AND Alpes)',
'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=contributorAffiliation%3AGrenoble(Grenoble AND Alpes)' 'https://entrepot.recherche.data.gouv.fr/api/search?q=*&fq=contributorAffiliation%3A(Grenoble AND Alpes)'
# possiblilité d'ajouter d'autres requêtes # possiblilité d'ajouter d'autres requêtes
# on définit une fonction pour la lancer la requete avec chaque url pour les différentes affiliations # on définit une fonction pour la lancer la requete avec chaque url pour les différentes affiliations
def get_results(url): def get_results(url):
req = requests.get(url) req = requests.get(url+"&type=dataset")
#print(req.url) #print(req.url)
results = [req.json()] results = [req.json()]
...@@ -39,7 +39,7 @@ def get_results(url): ...@@ -39,7 +39,7 @@ def get_results(url):
count = nb_res count = nb_res
page = 1 page = 1
while(nb_res > 0): while(nb_res > 0):
newurl = url+"&start="+str(count) newurl = url+"&type=dataset"+"&start="+str(count)
req = requests.get(newurl) req = requests.get(newurl)
results.append(req.json()) results.append(req.json())
nb_res = results[page]["data"]["count_in_response"] nb_res = results[page]["data"]["count_in_response"]
...@@ -59,7 +59,7 @@ def get_dois(results): ...@@ -59,7 +59,7 @@ def get_dois(results):
nb_dois += len(num_dois) nb_dois += len(num_dois)
for item in num_dois : for item in num_dois :
dois.append(item["global_id"]) dois.append(item.get("global_id"))
print("\tnb DOIs\t\t" + str(nb_dois)) print("\tnb DOIs\t\t" + str(nb_dois))
return dois return dois
client,count,name,year,url client,count,name,year,url
cern.zenodo,730,Zenodo,2013,https://zenodo.org/ cern.zenodo,885,Zenodo,2013,https://zenodo.org/
inist.sshade,471,Solid Spectroscopy Hosting Architecture of Databases and Expertise,2019,https://www.sshade.eu/ inist.sshade,522,Solid Spectroscopy Hosting Architecture of Databases and Expertise,2019,https://www.sshade.eu/
inist.osug,238,Observatoire des Sciences de l'Univers de Grenoble,2014,http://doi.osug.fr figshare.ars,380,figshare Academic Research System,2016,http://figshare.com/
figshare.ars,232,figshare Academic Research System,2016,http://figshare.com/ inist.osug,275,Observatoire des Sciences de l'Univers de Grenoble,2014,http://doi.osug.fr
dryad.dryad,156,DRYAD,2018,https://datadryad.org dryad.dryad,168,DRYAD,2018,https://datadryad.org
inist.resif,79,Réseau sismologique et géodésique français,2014,https://www.resif.fr/ inist.resif,99,Réseau sismologique et géodésique français,2014,https://www.resif.fr/
inist.persyval,55,PERSYVAL-Lab : Pervasive Systems and Algorithms Lab,2016, rdg.prod,81,Recherche Data Gouv France,2022,https://recherche.data.gouv.fr/en
rdg.prod,43,Recherche Data Gouv France,2022,https://recherche.data.gouv.fr/en inist.humanum,75,NAKALA,2020,https://nakala.fr
inist.persyval,64,PERSYVAL-Lab : Pervasive Systems and Algorithms Lab,2016,
fmsh.prod,28,Fondation Maison des sciences de l'homme,2023, fmsh.prod,28,Fondation Maison des sciences de l'homme,2023,
inist.humanum,28,Huma-Num,2020,https://nakala.fr inist.ccj,22,Centre Camille Jullian – UMR 7299,2020,
figshare.sage,14,figshare SAGE Publications,2018, pangaea.repository,18,PANGAEA,2020,https://www.pangaea.de/
mcdy.dohrmi,12,dggv-e-publications,2020,https://www.dggv.de/publikationen/dggv-e-publikationen.html mcdy.dohrmi,14,dggv-e-publications,2020,https://www.dggv.de/publikationen/dggv-e-publikationen.html
tib.gfzbib,3,GFZpublic,2011,https://gfzpublic.gfz-potsdam.de inist.cirm,7,Centre International de Rencontres Mathématiques,2017,
figshare.sage,6,figshare SAGE Publications,2018,
iris.iris,5,NSF Seismological Facility for the Advancement of Geoscience (SAGE),2018,http://www.iris.edu/hq/
vqpf.dris,3,Direction des ressources et de l'information scientifique,2021, vqpf.dris,3,Direction des ressources et de l'information scientifique,2021,
tib.repod,3,RepOD,2015, tib.gfzbib,3,GFZpublic,2011,https://gfzpublic.gfz-potsdam.de
iris.iris,3,Incorporated Research Institutions for Seismology,2018,http://www.iris.edu/hq/ tib.repod,3,RepOD,2015,https://repod.icm.edu.pl/
ugraz.unipub,2,unipub,2019,http://unipub.uni-graz.at cnic.sciencedb,3,ScienceDB,2022,https://www.scidb.cn/en
inist.eost,2,Ecole et Observatoire des Sciences de la Terre,2017,https://eost.unistra.fr/en/
tib.gfz,2,GFZ Data Services,2011,https://dataservices.gfz-potsdam.de/portal/
bl.mendeley,2,Mendeley Data,2015,https://data.mendeley.com/
bl.nerc,2,NERC Environmental Data Service,2011,https://eds.ukri.org bl.nerc,2,NERC Environmental Data Service,2011,https://eds.ukri.org
crui.ingv,1,Istituto Nazionale di Geofisica e Vulcanologia (INGV),2013,http://data.ingv.it/ tug.openlib,2,TU Graz OPEN Library,2020,https://openlib.tugraz.at/
estdoi.ttu,1,TalTech,2019,https://digikogu.taltech.ee crui.ingv,2,Istituto Nazionale di Geofisica e Vulcanologia (INGV),2013,http://data.ingv.it/
ardcx.nci,1,National Computational Infrastructure,2020, ugraz.unipub,2,unipub,2019,http://unipub.uni-graz.at
umass.uma,1,University of Massachusetts (UMass) Amherst,2018,https://scholarworks.umass.edu/ ethz.sed,2,"Swiss Seismological Service, national earthquake monitoring and hazard center",2013,http://www.seismo.ethz.ch
bl.mendeley,1,Mendeley Data,2015,https://data.mendeley.com/
inist.eost,1,Ecole et Observatoire des Sciences de la Terre,2017,https://eost.unistra.fr/en/
bl.iita,1,International Institute of Tropical Agriculture datasets,2017,http://data.iita.org/
inist.opgc,1,Observatoire de Physique du Globe de Clermont-Ferrand,2017, inist.opgc,1,Observatoire de Physique du Globe de Clermont-Ferrand,2017,
ethz.da-rd,1,ETHZ Data Archive - Research Data,2013,http://data-archive.ethz.ch
ethz.zora,1,"Universität Zürich, ZORA",2013,https://www.zora.uzh.ch/
repod.dbuw,1,University of Warsaw Research Data Repository,2023,https://danebadawcze.uw.edu.pl/
inist.ird,1,IRD,2016,
inist.omp,1,Observatoire Midi-Pyrénées,2011, inist.omp,1,Observatoire Midi-Pyrénées,2011,
tug.openlib,1,TU Graz OPEN Library,2020,https://openlib.tugraz.at/ umass.uma,1,University of Massachusetts (UMass) Amherst,2018,https://scholarworks.umass.edu/
tib.gfz,1,GFZ Data Services,2011,https://dataservices.gfz-potsdam.de/portal/
edi.edi,1,Environmental Data Initiative,2017,https://portal.edirepository.org/nis/home.jsp edi.edi,1,Environmental Data Initiative,2017,https://portal.edirepository.org/nis/home.jsp
ihumi.pub,1,IHU Méditerranée Infection,2020, ihumi.pub,1,IHU Méditerranée Infection,2020,
ethz.zora,1,"Universität Zürich, ZORA",2013,https://www.zora.uzh.ch/ inist.inrap,1,Institut national de recherches archéologiques préventives,2019,
inist.ird,1,IRD,2016, tib.mpdl,1,Max Planck Digital Library,2015,
tudublin.arrow,1,ARROW@TU Dublin,2020,https://arrow.dit.ie/
...@@ -56,14 +56,24 @@ for doi in dois : #[:300] ...@@ -56,14 +56,24 @@ for doi in dois : #[:300]
## if new datasets has been founded ## if new datasets has been founded
if temp_rows : if temp_rows :
df_fresh = pd.DataFrame(temp_rows) df_fresh = pd.DataFrame(temp_rows)
dois_added = list(df_old["doi"])
to_del = []
for i in range(0, len(df_fresh)): for i in range(0, len(df_fresh)):
result = my_functions.get_origin_version(df_fresh.loc[df_fresh.index[i], "doi"]) result = my_functions.get_origin_version(df_fresh.loc[i, "doi"])
if result[0] is in df_old["doi"]: df_fresh.drop(df_fresh.index[i]) if result[0] not in dois_added:
dois_added.append(result[0])
df_fresh.loc[i, "doi"] = result[0]
if str(result[1]) != "[]": df_fresh.loc[i, "traveled_dois"] = str(result[1])
else: df_fresh.loc[i, "traveled_dois"] = ""
if str(result[2]) != "[]": df_fresh.loc[i, "all_relations"] = str(result[2])
else: df_fresh.loc[i, "all_relations"] = ""
else: else:
df_fresh.loc[df_fresh.index[i], "doi"] = result[0] to_del.append(i)
df_fresh.loc[df_fresh.index[i], "relation_nbInstances"] = result[1]
df_fresh.loc[df_fresh.index[i], "relation_nbCitation"] = result[2] df_fresh.drop(to_del, inplace=True)
print("Nombre de dois supprimés : " + str(len(to_del)))
print("Nb dois a garder : " + str(len(dois_added)))
df_concat = pd.concat([df_old, df_fresh], ignore_index=True) df_concat = pd.concat([df_old, df_fresh], ignore_index=True)
...@@ -77,10 +87,18 @@ if temp_rows : ...@@ -77,10 +87,18 @@ if temp_rows :
df_out.to_csv("../dois-uga.csv", index = False) df_out.to_csv("../dois-uga.csv", index = False)
print(f"\n\nnb of doi exported \t{len(df_out)}") print(f"\n\nnb of doi exported \t{len(df_out)}")
# write the number of dois found in a file to display on the website # write the number of dois found in a file to display on the website
with open("nb-dois.txt", 'w') as outf : with open("nb-dois.txt", 'w') as outf :
outf.write(str(len(df_out))) outf.write(str(len(df_out)))
## output last 500 DOIs to make it easier to open in web tools
df_last_dois = df_out.sort_values(by = "created", ascending = False, inplace = False)[:500]
df_last_dois["created"] = df_last_dois["created"].str[:10]
df_last_dois[["doi", "client", "resourceTypeGeneral", "created", "publisher", "rights", "sizes"]].to_csv("../dois-uga--last-500.csv", index = False)
## for the website : output another csv with datacite client and number of datasets ## for the website : output another csv with datacite client and number of datasets
df_client_raw = df_out["client"].value_counts().to_frame() df_client_raw = df_out["client"].value_counts().to_frame()
2117 2692
\ No newline at end of file \ No newline at end of file
import requests, json import requests, json
def get_origin_version(doi, count=0, cited=0): # Fonction pour éviter la redondance des données associées à des DOIs différents mais pointant vers les mêmes fichiers :
cited = 0 # Dans Zenodo par exemple, il y a un DOI associé à chaque version d'un dépôt et il faut remonter au DOI "chapeau"
# Si le DOI "chapeau" obtenu ou un "is_identical_to" fait référence à un DOI déjà existant dans le csv, il doit être ignoré.
def get_origin_version(doi, history=[], first=True):
if first: history=[] # ligne ajoutée pour éviter certains soucis de cache où history n'est pas vide au premier appel de la fonction
req = requests.get( f"https://api.datacite.org/dois/{doi}" ) req = requests.get( f"https://api.datacite.org/dois/{doi}" )
res = req.json() res = req.json()
result = (doi, count, cited) final = []
result = (doi, history, final) # doi est le DOI qui sera ajouté au csv, history retrace les dois et les relations ayant permis les recherches et final enregistre les relations du doi final ajouté au csv
try: try:
related = res["data"]["attributes"]["relatedIdentifiers"] related = res["data"]["attributes"]["relatedIdentifiers"] # test si des relations existent pour le doi courant
except: except:
pass pass # si pas de relation, on renvoie le doi courant
else: else:
ignore = False ignore = False # ignore correspond à un doi ayant une version "chapeau" qui doit être trouvée. Le doi courant doit donc être ignoré
duplicate = False duplicate = False # duplicate correspond à un doi étant identique à un autre
for i in related: for i in related:
if i["relationType"] == "IsVersionOf" and i.get("relatedIdentifierType") == "DOI": final.append(i.get("relationType"))
if i.get("relationType") == "IsVersionOf" and i.get("relatedIdentifierType") == "DOI":
ignore = True ignore = True
elem_to_save_i = i["relatedIdentifier"] elem_to_save_i = i.get("relatedIdentifier")
# supprimer le doi courant s'il apparait dans la liste history.append([i.get("relationType"), i.get("relatedIdentifier")])
if i["relationType"] == "isCitedBy" and i.get("relatedIdentifierType") == "DOI": cited += 1 if i.get("relationType") == "IsIdenticalTo" and i.get("relatedIdentifierType") == "DOI":
if i["relationType"] == "IsIdenticalTo" and i.get("relatedIdentifierType") == "DOI":
duplicate = True duplicate = True
elem_to_save_d = i["relatedIdentifier"] elem_to_save_d = i.get("relatedIdentifier") # pas de symétrie pour les is_identical_to, donc il suffit de prendre l'autre (pas le doi courant) pour éviter les doublons
if duplicate and not(ignore): if duplicate and not(ignore):
result = (elem_to_save_d, count, cited) result = (elem_to_save_d, history, final) # si identique mais pas de version chapeau on peut s'arrêter
if ignore: result = get_origin_version(elem_to_save_i, count+1, cited) if ignore: result = get_origin_version(elem_to_save_i, history, False) # si version chapeau, on avance sans regarder les identiques
return result return result
def get_md_from_datacite( doi ) : def get_md_from_datacite( doi ) :
74.5 KiB | W: 0px | H: 0px
72.4 KiB | W: 0px | H: 0px
  • 2-up
  • Swipe
  • Onion skin
48.5 KiB | W: 0px | H: 0px
57.2 KiB | W: 0px | H: 0px
  • 2-up
  • Swipe
  • Onion skin
54.8 KiB | W: 0px | H: 0px
61.8 KiB | W: 0px | H: 0px
  • 2-up
  • Swipe
  • Onion skin
62 KiB | W: 0px | H: 0px
65.8 KiB | W: 0px | H: 0px
  • 2-up
  • Swipe
  • Onion skin
55.3 KiB | W: 0px | H: 0px
64.9 KiB | W: 0px | H: 0px
  • 2-up
  • Swipe
  • Onion skin
# Codes for the UGA Open research data monitor # Scripts & codes for the UGA Open research data monitor
View contextualized results on the website : [mlarrieu.gricad-pages.univ-grenoble-alpes.fr/open-research-data-monitor](https://mlarrieu.gricad-pages.univ-grenoble-alpes.fr/open-research-data-monitor) See contextualized results on the website : [mlarrieu.gricad-pages.univ-grenoble-alpes.fr/open-research-data-monitor](https://mlarrieu.gricad-pages.univ-grenoble-alpes.fr/open-research-data-monitor)
<br /> <br />
<br /> <br />
...@@ -11,8 +11,6 @@ View contextualized results on the website : [mlarrieu.gricad-pages.univ-grenobl ...@@ -11,8 +11,6 @@ View contextualized results on the website : [mlarrieu.gricad-pages.univ-grenobl
- Recherche en format texte de `UGA` et `grenoble AND alpes` dans les champs suivants : `author`, `contributor`, `datasetContactAffiliation`, `producerAffiliation` - Recherche en format texte de `UGA` et `grenoble AND alpes` dans les champs suivants : `author`, `contributor`, `datasetContactAffiliation`, `producerAffiliation`
### DataCite ### DataCite
- recherche avec les clients Datacite de l'UGA : `inist.osug`, `client.uid:inist.sshade`, `client.uid:inist.resif`, `client_id:inist.persyval` - recherche avec les clients Datacite de l'UGA : `inist.osug`, `client.uid:inist.sshade`, `client.uid:inist.resif`, `client_id:inist.persyval`
...@@ -42,18 +40,35 @@ View contextualized results on the website : [mlarrieu.gricad-pages.univ-grenobl ...@@ -42,18 +40,35 @@ View contextualized results on the website : [mlarrieu.gricad-pages.univ-grenobl
- récupérer la liste de publications, filter sur celles où des jeux de données ont été produits - récupérer la liste de publications, filter sur celles où des jeux de données ont été produits
- passer par HAL pour retrouver les DOI de ces jeux de données (champs `researchData_s`) - passer par HAL pour retrouver les DOI de ces jeux de données (champs `researchData_s`)
## Filters
- we remove the following datacite types `["Book", "ConferencePaper", "ConferenceProceeding", "JournalArticle", "BookChapter", "Service", "Preprint"]`
- we remove the following datacite clients `["rg.rg", "inist.epure"]`
## Comment sont comptées les données de la recherche ?
Le monitor prend en compte les données dotées d'un DOI de l'agence DataCite, c'est-à-dire qu'elles sont Findable. Un dépôt de données comprend des métadonnées conformes au schéma de données DataCite et un ou plusieurs fichiers pouvant être organisés en arborescence. Ce sont les dépôts qui sont comptés et non les fichiers intégrés aux dépôts : un DOI compte donc pour une donnée de recherche.
Le schéma de Datacite permet de déclarer des relations entre DOI, ce que nous utilisons pour gérer les versions ou les doublons de données.
Afin d'éviter de compter deux pour un même dépôt, ou bien pour un dépôt mis à jour, le monitor est doté d'une fonction qui navigue entre les DOIs dont la relation est de type `isVersionOf` ou `isIdenticalTo`. Dans le premier cas, la fonction "remonte" les versions jusqu'à la version parente, c'est-à-dire un DOI stable qui redirige vers la version la plus récente.
Dans le deuxième cas, la fonction garde simplement la version signalée comme étant identique. Cette relation n'étant pas symétrique, le DOI conservé n'aura pas de relation "isIdenticalTo" et la redondance est évitée.
<br /> <br />
<br /> <br />
## Filters
- we removethe following datacite types `["Book", "ConferencePaper", "ConferenceProceeding", "JournalArticle", "BookChapter", "Service", "Preprint"]`
## Data schema
Les champs du tableau produit reprennent ceux du schéma de données de DataCite (cf. https://datacite-metadata-schema.readthedocs.io/en/4.5/), auquel deux champs sont ajoutés :
- `all_relation`
toutes les relations attachées au DOI identifié.
- `traveled_dois`
liste des DOIs parcourus par le script pour obtenir le DOI de concept
<br /> <br />
<br /> <br />
## Credits ## Credits
* Élias Chetouane: collecting data, program automation * Élias Chetouane: collecting data, program automation
This diff is collapsed.
...@@ -13,5 +13,3 @@ https://indico.math.cnrs.fr/event/10998/page/779-journees-mathrice-a-grenoble-le ...@@ -13,5 +13,3 @@ https://indico.math.cnrs.fr/event/10998/page/779-journees-mathrice-a-grenoble-le
- nous faut il répliquer nos DOI dans Recherche Data Gouv pour plus de visibilité ? - nous faut il répliquer nos DOI dans Recherche Data Gouv pour plus de visibilité ?
2024-03-xx Software Heritage
