Skip to content
Snippets Groups Projects
Compare revisions
Source
Select target project
No results found
Target
  • daconcea/fidle
  • bossardl/fidle
  • Julie.Remenant/fidle
  • abijolao/fidle
  • monsimau/fidle
  • karkars/fidle
  • guilgautier/fidle
  • cailletr/fidle
  • talks/fidle
9 results
Show changes
Commits on Source (50)
Showing
with 5774 additions and 615 deletions
...@@ -2,5 +2,7 @@ ...@@ -2,5 +2,7 @@
*/.ipynb_checkpoints/* */.ipynb_checkpoints/*
__pycache__ __pycache__
*/__pycache__/* */__pycache__/*
/run/** run/
*/data/* */data/*
!/GTSRB/data/dataset.tar.gz
!/BHPD/data/BostonHousing.csv
Deep Neural Network (DNN) - BHPD dataset
Introduction au Deep Learning (IDLE) - S. Arias, E. Maldonado, JL. Parouty - CNRS/SARI/DEVLOG - 2020
## A very simple example of **regression** :
Objective is to predicts **housing prices** from a set of house features.
The **[Boston Housing Dataset](https://www.cs.toronto.edu/~delve/data/boston/bostonDetail.html)** consists of price of houses in various places in Boston.
Alongside with price, the dataset also provide information such as Crime, areas of non-retail business in the town,
age of people who own the house and many other attributes...
What we're going to do:
- Retrieve data
- Preparing the data
- Build a model
- Train the model
- Evaluate the result
## 1/ Init python stuff
%% Cell type:code id: tags:
``` python
import tensorflow as tf
from tensorflow import keras
import numpy as np
import pandas as pd
import os,sys
from IPython.display import display, Markdown
from importlib import reload
sys.path.append('..')
import fidle.pwk as ooo
ooo.init()
%% Output
IDLE 2020 - Practical Work Module
Version : 0.2.4
Run time : Sunday 2 February 2020, 15:17:29
Matplotlib style : ../fidle/talk.mplstyle
TensorFlow version : 2.0.0
Keras version : 2.2.4-tf
## 2/ Retrieve data
**From Keras :**
Boston housing is a famous historic dataset, so we can get it directly from [Keras datasets](https://www.tensorflow.org/api_docs/python/tf/keras/datasets)
%% Cell type:raw id: tags:
(x_train, y_train), (x_test, y_test) = keras.datasets.boston_housing.load_data(test_split=0.2, seed=113)
**From a csv file :**
More fun !
``` python
data = pd.read_csv('./data/BostonHousing.csv', header=0)
display(data.head(5).style.format("{0:.2f}"))
print('Données manquantes : ',data.isna().sum().sum(), ' Shape is : ', data.shape)
## 3/ Preparing the data
### 3.1/ Split data
We will use 70% of the data for training and 30% for validation.
x will be input data and y the expected output
``` python
# ---- Split => train, test
data_train = data.sample(frac=0.7, axis=0)
data_test = data.drop(data_train.index)
# ---- Split => x,y (medv is price)
x_train = data_train.drop('medv', axis=1)
y_train = data_train['medv']
x_test = data_test.drop('medv', axis=1)
y_test = data_test['medv']
print('Original data shape was : ',data.shape)
print('x_train : ',x_train.shape, 'y_train : ',y_train.shape)
print('x_test : ',x_test.shape, 'y_test : ',y_test.shape)
### 3.2/ Data normalization
**Note :**
- All input data must be normalized, train and test.
- To do this we will subtract the mean and divide by the standard deviation.
- But test data should not be used in any way, even for normalization.
- The mean and the standard deviation will therefore only be calculated with the train data.
``` python
display(x_train.describe().style.format("{0:.2f}").set_caption("Before normalization :"))
mean = x_train.mean()
std = x_train.std()
x_train = (x_train - mean) / std
x_test = (x_test - mean) / std
display(x_train.describe().style.format("{0:.2f}").set_caption("After normalization :"))
x_train, y_train = np.array(x_train), np.array(y_train)
x_test, y_test = np.array(x_test), np.array(y_test)
## 4/ Build a model
About informations about :
- [Optimizer](https://www.tensorflow.org/api_docs/python/tf/keras/optimizers)
- [Activation](https://www.tensorflow.org/api_docs/python/tf/keras/activations)
- [Loss](https://www.tensorflow.org/api_docs/python/tf/keras/losses)
- [Metrics](https://www.tensorflow.org/api_docs/python/tf/keras/metrics)
``` python
def get_model_v1(shape):
model = keras.models.Sequential()
model.add(keras.layers.Dense(64, activation='relu', input_shape=shape))
model.add(keras.layers.Dense(64, activation='relu'))
model.add(keras.layers.Dense(1))
model.compile(optimizer = 'rmsprop',
loss = 'mse',
metrics = ['mae', 'mse'] )
return model
## 5/ Train the model
``` python
model=get_model_v1( (13,) )
model.summary()
**Let's go :**
``` python
history = model.fit(x_train,
y_train,
epochs = 100,
batch_size = 10,
verbose = 1,
validation_data = (x_test, y_test))
## 6/ Evaluate
### 6.1/ Model evaluation
MAE = Mean Absolute Error (between the labels and predictions)
A mae equal to 3 represents an average error in prediction of $3k.
``` python
score = model.evaluate(x_test, y_test, verbose=0)
print('x_test / loss : {:5.4f}'.format(score[0]))
print('x_test / mae : {:5.4f}'.format(score[1]))
print('x_test / mse : {:5.4f}'.format(score[2]))
### 6.2/ Training history
What was the best result during our training ?
``` python
df=pd.DataFrame(data=history.history)
df.describe()
``` python
print("min( val_mae ) : {:.4f}".format( min(history.history["val_mae"]) ) )
``` python
ooo.plot_history(history, plot={'MSE' :['mse', 'val_mse'],
'MAE' :['mae', 'val_mae'],
'LOSS':['loss','val_loss']})
## Step 7 - Make a prediction
``` python
my_data = [ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745,
-2.14308942, 1.13489104, -1.06802005, 1.71189006, 1.57042287,
0.77859951, 0.14769795, 2.7585581 ]
real_price = 10.4
my_data=np.array(my_data).reshape(1,13)
``` python
predictions = model.predict( my_data )
print("Prédiction : {:.2f} K$".format(predictions[0][0]))
print("Reality : {:.2f} K$".format(real_price))
That's all folks !
## A very simple example of **regression** (Premium edition):
- (Retrieve data)
- (Preparing the data)
- (Build a model)
- Train and save the model
- Restore saved model
- Evaluate the model
- Make some predictions
``` python
import numpy as np
import pandas as pd
import os,sys
ooo.init()
## 2/ Retrieve data
**From Keras :**
More fun !
``` python
### 3.1/ Split data
We will use 80% of the data for training and 20% for validation.
``` python
**Note :**
``` python
std = x_train.std()
## 4/ Build a model
More informations about :
``` python
loss = 'mse',
return model
### 5.1/ Get it
``` python
model.summary()
### 5.2/ Add callback
``` python
os.makedirs('./run/models', mode=0o750, exist_ok=True)
save_dir = "./run/models/best_model.h5"
savemodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, save_best_only=True)
### 5.3/ Train it
``` python
y_train,
epochs = 100,
batch_size = 10,
verbose = 0,
validation_data = (x_test, y_test),
callbacks = [savemodel_callback])
## 6/ Evaluate
``` python
``` python
``` python
reload(ooo)
## 7/ Restore a model :
### 7.1/ Reload model
``` python
loaded_model = tf.keras.models.load_model('./run/models/best_model.h5')
loaded_model.summary()
print("Loaded.")
### 7.2/ Evaluate it :
``` python
score = loaded_model.evaluate(x_test, y_test, verbose=0)
### 7.3/ Make a prediction
``` python
mon_test=[ 1.26425925, -0.48522739, 1.0436489 , -0.23112788, 1.37120745,
mon_test=np.array(mon_test).reshape(1,13)
``` python
predictions = loaded_model.predict( mon_test )
print("Prédiction : {:.2f} K$ Reality : {:.2f} K$".format(predictions[0][0], y_train[13]))
That's all folks !
This diff is collapsed.
German Traffic Sign Recognition Benchmark (GTSRB)
## Episode 1 : Preparation of data
- Understanding the dataset
- Preparing and formatting enhanced data
- Save enhanced datasets in h5 file format
## 1/ Import and init
``` python
import os, time, sys
import csv
import math, random
import numpy as np
import h5py
from skimage.morphology import disk
from skimage.filters import rank
from skimage import io, color, exposure, transform
ooo.init()
## 2/ Read the dataset
Description is available there : http://benchmark.ini.rub.de/?section=gtsrb&subsection=dataset
- Each directory contains one CSV file with annotations ("GT-<ClassID>.csv") and the training images
- First line is fieldnames: Filename;Width;Height;Roi.X1;Roi.Y1;Roi.X2;Roi.Y2;ClassId
### 2.1/ Usefull functions
``` python
def read_dataset_dir(csv_filename):
'''Reads traffic sign data from German Traffic Sign Recognition Benchmark dataset.
Arguments: csv filename
Example /data/GTSRB/Train.csv
Returns: np array of images, np array of corresponding labels'''
# ---- csv filename and path
name=os.path.basename(csv_filename)
path=os.path.dirname(csv_filename)
# ---- Read csv file
f,x,y = [],[],[]
with open(csv_filename) as csv_file:
reader = csv.DictReader(csv_file, delimiter=',')
for row in reader:
f.append( path+'/'+row['Path'] )
y.append( int(row['ClassId']) )
csv_file.close()
nb_images = len(f)
# ---- Read images
for filename in f:
image=io.imread(filename)
x.append(image)
ooo.update_progress(name,len(x),nb_images)
# ---- Return
return np.array(x),np.array(y)
### 2.2/ Read the data
We will read the following datasets:
- **x_train, y_train** : Learning data
- **x_test, y_test** : Validation or test data
- x_meta, y_meta : Illustration data
The learning data will be randomly mixted and the illustration data sorted.
Will take about 2-3'
``` python
%%time
# ---- Read datasets
(x_train,y_train) = read_dataset_dir('./data/origine/Train.csv')
(x_test ,y_test) = read_dataset_dir('./data/origine/Test.csv')
(x_meta ,y_meta) = read_dataset_dir('./data/origine/Meta.csv')
# ---- Shuffle train set
combined = list(zip(x_train,y_train))
random.shuffle(combined)
x_train,y_train = zip(*combined)
# ---- Sort Meta
combined = list(zip(x_meta,y_meta))
combined.sort(key=lambda x: x[1])
x_meta,y_meta = zip(*combined)
## 3/ Few statistics about train dataset
We want to know if our images are homogeneous in terms of size, ratio, width or height.
### 3.1/ Do statistics
``` python
train_size = []
train_ratio = []
train_lx = []
train_ly = []
test_size = []
test_ratio = []
test_lx = []
test_ly = []
for image in x_train:
(lx,ly,lz) = image.shape
train_size.append(lx*ly/1024)
train_ratio.append(lx/ly)
train_lx.append(lx)
train_ly.append(ly)
for image in x_test:
test_size.append(lx*ly/1024)
test_ratio.append(lx/ly)
test_lx.append(lx)
test_ly.append(ly)
### 3.2/ Show statistics
``` python
# ------ Global stuff
print("x_train size : ",len(x_train))
print("y_train size : ",len(y_train))
print("x_test size : ",len(x_test))
print("y_test size : ",len(y_test))
# ------ Statistics / sizes
plt.figure(figsize=(16,6))
plt.hist([train_size,test_size], bins=100)
plt.gca().set(title='Sizes in Kpixels - Train=[{:5.2f}, {:5.2f}]'.format(min(train_size),max(train_size)),
ylabel='Population',
xlim=[0,30])
plt.legend(['Train','Test'])
plt.show()
# ------ Statistics / ratio lx/ly
plt.hist([train_ratio,test_ratio], bins=100)
plt.gca().set(title='Ratio lx/ly - Train=[{:5.2f}, {:5.2f}]'.format(min(train_ratio),max(train_ratio)),
xlim=[0.8,1.2])
plt.show()
# ------ Statistics / lx
plt.hist([train_lx,test_lx], bins=100)
plt.gca().set(title='Images lx - Train=[{:5.2f}, {:5.2f}]'.format(min(train_lx),max(train_lx)),
xlim=[20,150])
plt.show()
# ------ Statistics / ly
plt.hist([train_ly,test_ly], bins=100)
plt.gca().set(title='Images ly - Train=[{:5.2f}, {:5.2f}]'.format(min(train_ly),max(train_ly)),
xlim=[20,150])
plt.show()
# ------ Statistics / classId
plt.hist([y_train,y_test], bins=43)
plt.gca().set(title='ClassesId',
xlim=[0,43])
plt.show()
## 4/ List of classes
What are the 43 classes of our images...
``` python
ooo.plot_images(x_meta,y_meta, range(43), columns=8, x_size=2, y_size=2,
colorbar=False, y_pred=None, cm='binary')
## 5/ What does it really look like
``` python
# ---- Get and show few images
samples = [ random.randint(0,len(x_train)-1) for i in range(32)]
ooo.plot_images(x_train,y_train, samples, columns=8, x_size=2, y_size=2, colorbar=False, y_pred=None, cm='binary')
## 6/ dataset cooking...
Images must have the **same size** to match the size of the network.
It is possible to work on **rgb** or **monochrome** images and **equalize** the histograms.
The data must be **normalized**.
See : [Exposure with scikit-image](https://scikit-image.org/docs/dev/api/skimage.exposure.html)
See : [Local histogram equalization](https://scikit-image.org/docs/dev/api/skimage.filters.rank.html#skimage.filters.rank.equalize)
See : [Histogram equalization](https://scikit-image.org/docs/dev/api/skimage.exposure.html#skimage.exposure.equalize_hist)
### 6.1/ Enhancement cook
``` python
def images_enhancement(images, width=25, height=25, mode='RGB'):
Resize and convert images - doesn't change originals.
input images must be RGBA or RGB.
args:
images : images list
width,height : new images size (25,25)
mode : RGB | RGB-HE | L | L-HE | L-LHE | L-CLAHE
return:
numpy array of enhanced images
modes = { 'RGB':3, 'RGB-HE':3, 'L':1, 'L-HE':1, 'L-LHE':1, 'L-CLAHE':1}
lz=modes[mode]
out=[]
for img in images:
# ---- if RGBA, convert to RGB
if img.shape[2]==4:
img=color.rgba2rgb(img)
# ---- Resize
img = transform.resize(img, (width,height))
# ---- RGB / Histogram Equalization
if mode=='RGB-HE':
hsv = color.rgb2hsv(img.reshape(width,height,3))
hsv[:, :, 2] = exposure.equalize_hist(hsv[:, :, 2])
img = color.hsv2rgb(hsv)
# ---- Grayscale
if mode=='L':
img=color.rgb2gray(img)
# ---- Grayscale / Histogram Equalization
if mode=='L-HE':
img=exposure.equalize_hist(img)
# ---- Grayscale / Local Histogram Equalization
if mode=='L-LHE':
img=rank.equalize(img, disk(10))/255.
# ---- Grayscale / Contrast Limited Adaptive Histogram Equalization (CLAHE)
if mode=='L-CLAHE':
img=exposure.equalize_adapthist(img)
# ---- Add image in list of list
out.append(img)
ooo.update_progress('Enhancement: ',len(out),len(images))
# ---- Reshape images
# (-1, width,height,1) for L
# (-1, width,height,3) for RGB
out = np.array(out,dtype='float64')
out = out.reshape(-1,width,height,lz)
return out
### 6.2/ To get an idea of the different recipes
``` python
i=random.randint(0,len(x_train)-16)
x_samples = x_train[i:i+16]
y_samples = y_train[i:i+16]
datasets = {}
datasets['RGB'] = images_enhancement( x_samples, width=25, height=25, mode='RGB' )
datasets['RGB-HE'] = images_enhancement( x_samples, width=25, height=25, mode='RGB-HE' )
datasets['L'] = images_enhancement( x_samples, width=25, height=25, mode='L' )
datasets['L-HE'] = images_enhancement( x_samples, width=25, height=25, mode='L-HE' )
datasets['L-LHE'] = images_enhancement( x_samples, width=25, height=25, mode='L-LHE' )
datasets['L-CLAHE'] = images_enhancement( x_samples, width=25, height=25, mode='L-CLAHE' )
print('\nEXPECTED (Meta) :\n')
x_expected=[ x_meta[i] for i in y_samples]
ooo.plot_images(x_expected, y_samples, range(16), columns=16, x_size=1, y_size=1, colorbar=False, y_pred=None, cm='binary')
print('\nORIGINAL IMAGES :\n')
ooo.plot_images(x_samples, y_samples, range(16), columns=16, x_size=1, y_size=1, colorbar=False, y_pred=None, cm='binary')
print('\nENHANCED :\n')
for k,d in datasets.items():
print("dataset : {} min,max=[{:.3f},{:.3f}] shape={}".format(k,d.min(),d.max(), d.shape))
ooo.plot_images(d, y_samples, range(16), columns=16, x_size=1, y_size=1, colorbar=False, y_pred=None, cm='binary')
### 6.3/ Cook and save
A function to save a dataset
``` python
def save_h5_dataset(x_train, y_train, x_test, y_test, x_meta,y_meta, h5name):
# ---- Filename
filename='./data/'+h5name
# ---- Create h5 file
with h5py.File(filename, "w") as f:
f.create_dataset("x_train", data=x_train)
f.create_dataset("y_train", data=y_train)
f.create_dataset("x_test", data=x_test)
f.create_dataset("y_test", data=y_test)
f.create_dataset("x_meta", data=x_meta)
f.create_dataset("y_meta", data=y_meta)
# ---- done
size=os.path.getsize(filename)/(1024*1024)
print('Dataset : {:24s} shape : {:22s} size : {:6.1f} Mo (saved)\n'.format(filename, str(x_train.shape),size))
Create enhanced datasets, and save them...
Will take about 7-8'
``` python
%%time
for s in [24, 48]:
for m in ['RGB', 'RGB-HE', 'L', 'L-LHE']:
# ---- A nice dataset name
name='set-{}x{}-{}.h5'.format(s,s,m)
print("\nDataset : ",name)
# ---- Enhancement
x_train_new = images_enhancement( x_train, width=s, height=s, mode=m )
x_test_new = images_enhancement( x_test, width=s, height=s, mode=m )
x_meta_new = images_enhancement( x_meta, width=s, height=s, mode='RGB' )
# ---- Save
save_h5_dataset( x_train_new, y_train, x_test_new, y_test, x_meta_new,y_meta, name)
x_train_new,x_test_new=0,0
## 7/ Reload data to be sure ;-)
``` python
%%time
dataset='set-48x48-L'
samples=range(24)
with h5py.File('./data/'+dataset+'.h5') as f:
x_tmp = f['x_train'][:]
y_tmp = f['y_train'][:]
print("dataset loaded from h5 file.")
ooo.plot_images(x_tmp,y_tmp, samples, columns=8, x_size=2, y_size=2, colorbar=False, y_pred=None, cm='binary')
x_tmp,y_tmp=0,0
That's all folks !
## Episode 2 : First Convolutions
Our main steps:
- Read H5 dataset
- Build a model
- Train the model
``` python
from tensorflow.keras.callbacks import TensorBoard
import numpy as np
import h5py
import os,time,sys
ooo.init()
## 2/ Load dataset
We're going to retrieve a previously recorded dataset.
For example: set-24x24-L
``` python
%%time
def read_dataset(name):
'''Reads h5 dataset from ./data
Arguments: dataset name, without .h5
Returns: x_train,y_train,x_test,y_test data'''
# ---- Read dataset
filename='./data/'+name+'.h5'
with h5py.File(filename) as f:
x_train = f['x_train'][:]
y_train = f['y_train'][:]
x_test = f['x_test'][:]
y_test = f['y_test'][:]
# ---- done
print('Dataset "{}" is loaded. ({:.1f} Mo)\n'.format(name,os.path.getsize(filename)/(1024*1024)))
x_train,y_train,x_test,y_test = read_dataset('set-24x24-L')
## 3/ Have a look to the dataset
We take a quick look as we go by...
``` python
print("x_train : ", x_train.shape)
print("y_train : ", y_train.shape)
print("x_test : ", x_test.shape)
print("y_test : ", y_test.shape)
ooo.plot_images(x_train, y_train, range(12), columns=6, x_size=2, y_size=2)
ooo.plot_images(x_train, y_train, range(36), columns=12, x_size=1, y_size=1)
## 4/ Create model
We will now build a model and train it...
Some models :
``` python
# A basic model
def get_model_v1(lx,ly,lz):
model.add( keras.layers.Conv2D(96, (3,3), activation='relu', input_shape=(lx,ly,lz)))
model.add( keras.layers.MaxPooling2D((2, 2)))
model.add( keras.layers.Dropout(0.2))
model.add( keras.layers.Conv2D(192, (3, 3), activation='relu'))
model.add( keras.layers.Flatten())
model.add( keras.layers.Dense(1500, activation='relu'))
model.add( keras.layers.Dropout(0.5))
model.add( keras.layers.Dense(43, activation='softmax'))
return model
# A more sophisticated model
def get_model_v2(lx,ly,lz):
model.add( keras.layers.Conv2D(64, (3, 3), padding='same', input_shape=(lx,ly,lz), activation='relu'))
model.add( keras.layers.Conv2D(64, (3, 3), activation='relu'))
model.add( keras.layers.MaxPooling2D(pool_size=(2, 2)))
model.add( keras.layers.Conv2D(128, (3, 3), padding='same', activation='relu'))
model.add( keras.layers.Conv2D(128, (3, 3), activation='relu'))
model.add( keras.layers.Conv2D(256, (3, 3), padding='same',activation='relu'))
model.add( keras.layers.Conv2D(256, (3, 3), activation='relu'))
model.add( keras.layers.Dense(512, activation='relu'))
return model
# My sphisticated model, but small and fast
def get_model_v3(lx,ly,lz):
model.add( keras.layers.Conv2D(32, (3,3), activation='relu', input_shape=(lx,ly,lz)))
model.add( keras.layers.Dense(1152, activation='relu'))
return model
**Get the shape of my data :**
``` python
(n,lx,ly,lz) = x_train.shape
print("Images of the dataset have this folowing shape : ",(lx,ly,lz))
**Get and compile a model, with the data shape :**
``` python
model = get_model_v1(lx,ly,lz)
model.summary()
model.compile(optimizer = 'adam',
loss = 'sparse_categorical_crossentropy',
metrics = ['accuracy'])
**Train it :**
``` python
%%time
batch_size = 64
epochs = 5
# ---- Shuffle train data
x_train,y_train=ooo.shuffle_np_dataset(x_train,y_train)
# ---- Train
history = model.fit( x_train, y_train,
batch_size = batch_size,
epochs = epochs,
verbose = 1,
**Evaluate it :**
``` python
max_val_accuracy = max(history.history["val_accuracy"])
print("Max validation accuracy is : {:.4f}".format(max_val_accuracy))
``` python
print('Test loss : {:5.4f}'.format(score[0]))
print('Test accuracy : {:5.4f}'.format(score[1]))
## Episode 3 : Tracking, visualizing and save models
Our main steps:
- Monitoring and understanding our model training
- Add recovery points
- Analyze the results
- Restore and run recovery pont
``` python
import numpy as np
import h5py
from sklearn.metrics import confusion_matrix
import seaborn as sn
import os, sys, time, random
ooo.init()
## 2/ Load dataset
Dataset is one of the saved dataset: RGB25, RGB35, L25, L35, etc.
First of all, we're going to use a smart dataset : **set-24x24-L**
(with a GPU, it only takes 35'' compared to more than 5' with a CPU !)
``` python
%%time
# ---- Read dataset
x_meta = f['x_meta'][:]
y_meta = f['y_meta'][:]
# ---- done
return x_train,y_train,x_test,y_test,x_meta,y_meta
x_train,y_train,x_test,y_test,x_meta,y_meta = read_dataset('set-24x24-L')
Note: Data must be reshape for matplotlib
``` python
## 4/ Create model
Some models...
``` python
# A basic model
return model
## 5/ Prepare callbacks
We will add 2 callbacks :
- **TensorBoard**
Training logs, which can be visualised with Tensorboard.
`#tensorboard --logdir ./run/logs`
IMPORTANT : Relancer tensorboard à chaque run
- **Model backup**
It is possible to save the model each xx epoch or at each improvement.
The model can be saved completely or partially (weight).
For full format, we can use HDF5 format.
%%bash
# To clean old logs and saved model, run this cell
/bin/rm -r ./run/logs 2>/dev/null
/bin/rm -r ./run/models 2>/dev/null
/bin/mkdir -p -m 755 ./run/logs
/bin/mkdir -p -m 755 ./run/models
echo -e "Reset directories : ./run/logs and ./run/models ."
``` python
ooo.mkdir('./run/models')
ooo.mkdir('./run/logs')
# ---- Callback tensorboard
log_dir = "./run/logs/tb_" + ooo.tag_now()
tensorboard_callback = tf.keras.callbacks.TensorBoard(log_dir=log_dir, histogram_freq=1)
# ---- Callback ModelCheckpoint - Save best model
save_dir = "./run/models/best-model.h5"
bestmodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, monitor='accuracy', save_best_only=True)
# ---- Callback ModelCheckpoint - Save model each epochs
save_dir = "./run/models/model-{epoch:04d}.h5"
savemodel_callback = tf.keras.callbacks.ModelCheckpoint(filepath=save_dir, verbose=0, save_freq=2000*5)
``` python
``` python
# model.summary()
model.compile(optimizer='adam',
loss='sparse_categorical_crossentropy',
metrics=['accuracy'])
**Train it :**
Note: The training curve is visible in real time with Tensorboard :
``` python
%%time
batch_size = 64
epochs = 30
# ---- Train
# Note: To be faster in our example, we can take only 2000 values
batch_size=batch_size,
epochs=epochs,
verbose=1,
validation_data=(x_test, y_test),
callbacks=[tensorboard_callback, bestmodel_callback, savemodel_callback] )
model.save('./run/models/last-model.h5')
**Evaluate it :**
``` python
``` python
## 6/ History
The return of model.fit() returns us the learning history
``` python
ooo.plot_history(history)
## 7/ Evaluation and confusion
``` python
y_pred = model.predict_classes(x_test)
conf_mat = confusion_matrix(y_test,y_pred, normalize="true", labels=range(43))
ooo.plot_confusion_matrix(conf_mat)
## 8/ Restore and evaluate
### 8.1/ List saved models :
``` python
!find ./run/models/
### 8.2/ Restore a model :
``` python
loaded_model = tf.keras.models.load_model('./run/models/best-model.h5')
# loaded_model.summary()
print("Loaded.")
### 8.3/ Evaluate it :
``` python
### 8.4/ Make a prediction :
``` python
# ---- Get a random image
i = random.randint(1,len(x_test))
x,y = x_test[i], y_test[i]
# ---- Do prediction
predictions = loaded_model.predict( np.array([x]) )
# ---- A prediction is just the output layer
print("\nOutput layer from model is (x100) :\n")
with np.printoptions(precision=2, suppress=True, linewidth=95):
print(predictions*100)
# ---- Graphic visualisation
print("\nGraphically :\n")
plt.figure(figsize=(12,2))
plt.bar(range(43), predictions[0], align='center', alpha=0.5)
plt.ylabel('Probability')
plt.ylim((0,1))
plt.xlabel('Class')
plt.title('Trafic Sign prediction')
plt.show()
# ---- Predict class
p = np.argmax(predictions)
# ---- Show result
print("\nPrediction on the left, real stuff on the right :\n")
ooo.plot_images([x,x_meta[y]], [p,y], range(2), columns=3, x_size=3, y_size=2)
if p==y:
print("YEEES ! that's right!")
else:
print("oups, that's wrong ;-(")
That's all folks !
``` python
## Episode 4 : Data augmentation
Our main steps:
- Increase and improve the learning dataset
``` python
import numpy as np
import h5py
ooo.init()
## 2/ Dataset loader
``` python
%%time
# ---- Read dataset
# ---- done
## 3/ Models
This is my model ;-)
``` python
# A basic model
return model
## 4/ Callbacks
We prepare 2 kind callbacks : TensorBoard and Model backup
``` python
%%bash
``` python
## 5/ Load and prepare dataset
### 5.1/ Load
``` python
x_train,y_train,x_test,y_test = read_dataset('set-48x48-L-LHE')
### 5.2/ Data augmentation
``` python
datagen = keras.preprocessing.image.ImageDataGenerator(featurewise_center=False,
featurewise_std_normalization=False,
width_shift_range=0.1,
height_shift_range=0.1,
zoom_range=0.2,
shear_range=0.1,
rotation_range=10.)
datagen.fit(x_train)
## 6/ Train the model
``` python
``` python
model = get_model_v3(lx,ly,lz)
# model.summary()
**Train it :**
Note : La courbe d'apprentissage est visible en temps réel avec Tensorboard :
``` python
%%time
batch_size = 64
epochs = 30
#x_train,y_train=ooo.shuffle_np_dataset(x_train,y_train)
# ---- Train
history = model.fit( datagen.flow(x_train, y_train, batch_size=batch_size),
steps_per_epoch = int(x_train.shape[0]/batch_size),
epochs=epochs,
verbose=1,
**Evaluate it :**
``` python
``` python
## 7/ History
``` python
## 8/ Evaluate best model
### 8.1/ Restore best model :
``` python
# best_model.summary()
print("Loaded.")
### 8.2/ Evaluate it :
``` python
**Plot confusion matrix**
``` python
That's all folks !
``` python
## Episode 5 : Full Convolutions
Our main steps:
- Try n models with n datasets
- Save a Pandas/h5 report
- Write to be run in batch mode
## 1/ Import
``` python
import numpy as np
import h5py
import os,time,json
import random
VERSION='1.6'
## 2/ Init and start
``` python
# ---- Where I am ?
now = time.strftime("%A %d %B %Y - %Hh%Mm%Ss")
here = os.getcwd()
random.seed(time.time())
tag_id = '{:06}'.format(random.randint(0,99999))
# ---- Who I am ?
if 'OAR_JOB_ID' in os.environ:
oar_id=os.environ['OAR_JOB_ID']
else:
oar_id='???'
print('\nFull Convolutions Notebook')
print(' Version : {}'.format(VERSION))
print(' Now is : {}'.format(now))
print(' OAR id : {}'.format(oar_id))
print(' Tag id : {}'.format(tag_id))
print(' Working directory : {}'.format(here))
print(' TensorFlow version :',tf.__version__)
print(' Keras version :',tf.keras.__version__)
print(' for tensorboard : --logdir {}/run/logs_{}'.format(here,tag_id))
## 3/ Dataset loading
``` python
# ---- Read dataset
## 4/ Models collection
``` python
# A basic model
return model
return model
model.add(tf.keras.layers.Conv2D(32, (5, 5), padding='same', activation='relu', input_shape=(lx,ly,lz)))
model.add(tf.keras.layers.BatchNormalization(axis=-1))
model.add(tf.keras.layers.MaxPooling2D(pool_size=(2, 2)))
model.add(tf.keras.layers.Dropout(0.2))
model.add(tf.keras.layers.Conv2D(64, (5, 5), padding='same', activation='relu'))
model.add(tf.keras.layers.Conv2D(128, (5, 5), padding='same', activation='relu'))
model.add(tf.keras.layers.Flatten())
model.add(tf.keras.layers.Dense(512, activation='relu'))
model.add(tf.keras.layers.BatchNormalization())
model.add(tf.keras.layers.Dropout(0.4))
model.add(tf.keras.layers.Dense(43, activation='softmax'))
return model
## 5/ Multiple datasets, multiple models ;-)
``` python
def multi_run(datasets, models, datagen=None,
train_size=1, test_size=1, batch_size=64, epochs=16,
verbose=0, extension_dir='last'):
# ---- Logs and models dir
os.makedirs('./run/logs_{}'.format(extension_dir), mode=0o750, exist_ok=True)
os.makedirs('./run/models_{}'.format(extension_dir), mode=0o750, exist_ok=True)
# ---- Columns of output
output={}
output['Dataset']=[]
output['Size'] =[]
for m in models:
output[m+'_Accuracy'] = []
output[m+'_Duration'] = []
# ---- Let's go
for d_name in datasets:
print("\nDataset : ",d_name)
# ---- Read dataset
x_train,y_train,x_test,y_test = read_dataset(d_name)
d_size=os.path.getsize('./data/'+d_name+'.h5')/(1024*1024)
output['Dataset'].append(d_name)
output['Size'].append(d_size)
# ---- Get the shape
n_train = int(x_train.shape[0]*train_size)
n_test = int(x_test.shape[0]*test_size)
# ---- For each model
for m_name,m_function in models.items():
print(" Run model {} : ".format(m_name), end='')
# ---- get model
try:
model=m_function(lx,ly,lz)
# ---- Compile it
model.compile(optimizer='adam', loss='sparse_categorical_crossentropy', metrics=['accuracy'])
# ---- Callbacks tensorboard
log_dir = "./run/logs_{}/tb_{}_{}".format(extension_dir, d_name, m_name)
# ---- Callbacks bestmodel
save_dir = "./run/models_{}/model_{}_{}.h5".format(extension_dir, d_name, m_name)
# ---- Train
start_time = time.time()
if datagen==None:
# ---- No data augmentation (datagen=None) --------------------------------------
history = model.fit(x_train[:n_train], y_train[:n_train],
epochs = epochs,
verbose = verbose,
validation_data = (x_test[:n_test], y_test[:n_test]),
callbacks = [tensorboard_callback, bestmodel_callback])
else:
# ---- Data augmentation (datagen given) ----------------------------------------
history = model.fit(datagen.flow(x_train, y_train, batch_size=batch_size),
steps_per_epoch = int(n_train/batch_size),
epochs = epochs,
verbose = verbose,
# ---- Result
end_time = time.time()
duration = end_time-start_time
accuracy = max(history.history["val_accuracy"])*100
output[m_name+'_Accuracy'].append(accuracy)
output[m_name+'_Duration'].append(duration)
print("Accuracy={:.2f} and Duration={:.2f})".format(accuracy,duration))
except:
output[m_name+'_Accuracy'].append('0')
output[m_name+'_Duration'].append('999')
print('-')
return output
## 6/ Run !
``` python
print('\n---- Run','-'*50)
# --------- Datasets, models, and more.. -----------------------------------
# ---- For tests
# datasets = ['set-24x24-L', 'set-24x24-RGB']
# models = {'v1':get_model_v1, 'v4':get_model_v2}
# batch_size = 64
# epochs = 2
# train_size = 0.1
# test_size = 0.1
# with_datagen = False
# verbose = 0
# ---- All possibilities -> Run A
# datasets = ['set-24x24-L', 'set-24x24-RGB', 'set-48x48-L', 'set-48x48-RGB', 'set-24x24-L-LHE', 'set-24x24-RGB-HE', 'set-48x48-L-LHE', 'set-48x48-RGB-HE']
# models = {'v1':get_model_v1, 'v2':get_model_v2, 'v3':get_model_v3}
# batch_size = 64
# epochs = 16
# train_size = 1
# test_size = 1
# verbose = 0
# ---- Data augmentation -> Run B
datasets = ['set-48x48-RGB']
models = {'v2':get_model_v2}
batch_size = 64
epochs = 20
train_size = 1
test_size = 1
with_datagen = True
verbose = 0
if with_datagen :
zoom_range=0.2,
shear_range=0.1,
rotation_range=10.)
else:
datagen=None
# ---- Run
output = multi_run(datasets, models,
datagen=datagen,
train_size=train_size, test_size=test_size,
batch_size=batch_size, epochs=epochs,
verbose=verbose,
extension_dir=tag_id)
# ---- Save report
report={}
report['output']=output
report['description']='train_size={} test_size={} batch_size={} epochs={} data_aug={}'.format(train_size,test_size,batch_size,epochs,with_datagen)
report_name='./run/report_{}.json'.format(tag_id)
with open(report_name, 'w') as file:
json.dump(report, file)
print('\nReport saved as ',report_name)
print(f'Duration : {duration:.2f} s')
print('-'*59)
## 7/ That's all folks..
``` python
print('\n{}'.format(time.strftime("%A %-d %B %Y, %H:%M:%S")))
print("The work is done.\n")
``` python
## Episode 5.1 : Full Convolutions / run
Our main steps:
- Run Full-convolution.ipynb as a batch :
- Notebook mode
- Script mode
- Tensorboard follow up
## 1/ Run a notebook as a batch
To run a notebook :
```jupyter nbconvert --to notebook --execute <notebook>```
%%bash
# ---- This will execute and save a notebook
jupyter nbconvert --ExecutePreprocessor.timeout=-1 --to notebook --output='./run/full_convolutions' --execute '05-Full-convolutions.ipynb'
## 2/ Export as a script (better choice)
To export a notebook as a script :
```jupyter nbconvert --to script <notebook>```
To run the script :
```ipython <script>```
``` python
%%bash
# ---- This will convert a notebook to a notebook.py script
jupyter nbconvert --to script --output='./run/full_convolutions_B' '05-Full-convolutions.ipynb'
%% Output
[NbConvertApp] Converting notebook 05-Full-convolutions.ipynb to script
[NbConvertApp] Writing 11305 bytes to ./run/full_convolutions_B.py
``` python
!ls -l ./run/*.py
%% Output
-rw-r--r-- 1 pjluc pjluc 11305 Jan 21 00:13 ./run/full_convolutions_B.py
## 3/ Batch submission
Create batch script :
``` python
%%writefile "./run/batch_full_convolutions_B.sh"
#!/bin/bash
#OAR -n Full convolutions
#OAR -t gpu
#OAR -l /nodes=1/gpudevice=1,walltime=01:00:00
#OAR --stdout _batch/full_convolutions_%jobid%.out
#OAR --stderr _batch/full_convolutions_%jobid%.err
#OAR --project deeplearningshs
#---- For cpu
# use :
# OAR -l /nodes=1/core=32,walltime=01:00:00
# and add a 2>/dev/null to ipython xxx
# _ _ _
# | |__ __ _| |_ ___| |__
# | '_ \ / _` | __/ __| '_ \
# | |_) | (_| | || (__| | | |
# |_.__/ \__,_|\__\___|_| |_|
# Full convolutions
CONDA_ENV=deeplearning2
RUN_DIR=~/fidle/GTSRB
RUN_SCRIPT=./run/full_convolutions_B.py
# ---- Cuda Conda initialization
echo '------------------------------------------------------------'
echo "Start : $0"
source /applis/environments/cuda_env.sh dahu 10.0
source /applis/environments/conda.sh
conda activate "$CONDA_ENV"
# ---- Run it...
cd $RUN_DIR
ipython $RUN_SCRIPT
%% Output
Writing ./run/batch_full_convolutions_B.sh
``` python
%%bash
chmod 755 ./run/*.sh
chmod 755 ./run/*.py
ls -l ./run/*full_convolutions*
%% Output
-rwxr-xr-x 1 pjluc pjluc 1045 Jan 21 00:15 ./run/batch_full_convolutions_B.sh
-rwxr-xr-x 1 pjluc pjluc 611 Jan 19 15:53 ./run/batch_full_convolutions.sh
-rwxr-xr-x 1 pjluc pjluc 11305 Jan 21 00:13 ./run/full_convolutions_B.py
%%bash
``` python
Running Tensorboard from Jupyter lab
Vesion : 1.0
## 1/ Méthode 1 : Shell command
``` python
%%bash
tensorboard_start --logdir ./run/logs
``` python
%%bash
tensorboard_status
``` python
%%bash
tensorboard_stop
## Méthode 2 : Magic command
**Start**
``` python
%load_ext tensorboard
``` python
%tensorboard --port 21277 --host 0.0.0.0 --logdir ./run/logs
**Stop**
No way... use bash method
## Methode 3 : Tensorboard module
**Start**
``` python
import tensorboard.notebook as tsb
``` python
tsb.start('--port 21277 --host 0.0.0.0 --logdir ./run/logs')
**Check**
``` python
a=tsb.list()
**Stop**
``` python
!kill 214798
``` python
S. Aria, E. Maldonado, JL. Parouty
Objectives of this practical work
Traffic sign classification with **CNN**, using Tensorflow and **Keras**
About the dataset
Name : [German Traffic Sign Recognition Benchmark (GTSRB)](http://benchmark.ini.rub.de/?section=gtsrb)
Available [here](https://sid.erda.dk/public/archives/daaeac0d7ce1152aea9b61d9f1e19370/published-archive.html)
or on **[kaggle](https://www.kaggle.com/meowmeowmeowmeowmeow/gtsrb-german-traffic-sign)**
A nice example from : [Alex Staravoitau](https://navoshta.com/traffic-signs-classification/)
In few words :
- Images : Variable dimensions, rgb
- Train set : 39209 images
- Test set : 12630 images
- Classes : 0 to 42
Episodes
**[01 - Preparation of data](01-Preparation-of-data.ipynb)**
- Preparing and formatting data
- Organize and backup data
**[02 - First convolutions](02-First-convolutions.ipynb)**
- Read dataset
- Build a model
- Train the model
- Model evaluation
``` python
File added
Text Embedding - IMDB dataset
## Reviews analysis :
The objective is to guess whether our new and personals films reviews are **positive or negative** .
For this, we will use our previously saved model.
- Retrieve our saved model
## Step 1 - Init python stuff
``` python
import numpy as np
import tensorflow.keras as keras
import tensorflow.keras.datasets.imdb as imdb
import matplotlib
import seaborn as sns
import pandas as pd
import os,sys,h5py,json,re
ooo.init()
## Step 2 : Preparing the data
### 2.1 - Our reviews :
``` python
reviews = [ "This film is particularly nice, a must see.",
"Some films are classics and cannot be ignored.",
"This movie is just abominable and doesn't deserve to be seen!"]
### 2.2 - Retrieve dictionaries
``` python
with open('./data/word_index.json', 'r') as fp:
word_index = json.load(fp)
index_word = {index:word for word,index in word_index.items()}
### 2.3 - Clean, index and padd
``` python
max_len = 256
vocab_size = 10000
nb_reviews = len(reviews)
x_data = []
# ---- For all reviews
for review in reviews:
# ---- First index must be <start>
index_review=[1]
# ---- For all words
for w in review.split(' '):
# ---- Clean it
w_clean = re.sub(r"[^a-zA-Z0-9]", "", w)
# ---- Not empty ?
if len(w_clean)>0:
# ---- Get the index
w_index = word_index.get(w,2)
if w_index>vocab_size : w_index=2
# ---- Add the index if < vocab_size
index_review.append(w_index)
# ---- Add the indexed review
x_data.append(index_review)
# ---- Padding
x_data = keras.preprocessing.sequence.pad_sequences(x_data, value = 0, padding = 'post', maxlen = max_len)
### 2.4 - Have a look
``` python
def translate(x):
return ' '.join( [index_word.get(i,'?') for i in x] )
for i in range(nb_reviews):
imax=np.where(x_data[i]==0)[0][0]+5
print(f'\nText review :', reviews[i])
print( f'x_train[{i:}] :', list(x_data[i][:imax]), '(...)')
print( 'Translation :', translate(x_data[i][:imax]), '(...)')
## Step 2 - Bring back the model
``` python
model = keras.models.load_model('./run/models/best_model.h5')
## Step 4 - Predict
``` python
y_pred = model.predict(x_data)
#### And the winner is :
``` python
print(f'\n{reviews[i]:<70} =>',('NEGATIVE' if y_pred[i][0]<0.5 else 'POSITIVE'),f'({y_pred[i][0]:.2f})')
``` python
a=[1]+[i for i in range(3)]
a
``` python
FIDLE - Formation Introduction au Deep Learning
## 1/ Environment
To run this examples, you need an environment with the following packages :
- Python 3.6
- numpy
- Tensorflow 2.0
- scikit-image
- scikit-learn
- Matplotlib
- seaborn
- pyplot
You can install such a predefined environment :
conda env create -f environment.yml
To manage conda environment see [there](https://docs.conda.io/projects/conda/en/latest/user-guide/tasks/manage-environments.html#)
## 4/ Misc
To update an existing environment :
conda env update --name=deeplearning2 --file=environment.yml
\ No newline at end of file
