... | @@ -48,8 +48,8 @@ You can access the shared agenda: |
| 24 | 2022-06-16 | jeudi | | PETIT Pascal | PETIT Pascal | Presentation of several research projects focused on the exposome and its impact on human health using data science |
| 25 | 2022-06-23 | jeudi | | BECQ Guillaume | BECQ Guillaume | Effect of visual fixations during multidimensional choices: a hierarchical drift diffusion model approach |
| 26 | 2022-06-30 | jeudi | | PEYROU Martin | PEYROU Martin | Conception et test de composants pour circuits photoniques intégrés hybrides InP/Si et applications LIDAR |
| 27 | 2022-07-07 | jeudi | vacances d'été | HAMDAN Ahmad | | |
| 27 | 2022-07-07 | jeudi | vacances d'été | HAMDAN Ahmad | HAMDAN Ahmad | |
| 28 | 2022-07-13 | mercredi | vacances d'été | | Rosa Maria Fernandez Alcala | Proper Hypercomplex Processing as a Reduction Dimension Technique |
| 28 | 2022-07-13 | mercredi | vacances d'été | | Rosa Maria FERNANDEZ ALCALA | Proper Hypercomplex Processing as a Reduction Dimension Technique |
| 28 | 2022-07-14 | jeudi | vacances d'été | | | |
| 29 | 2022-07-21 | jeudi | vacances d'été | NGUYEN Minh Toan | NGUYEN Minh Toan | a simple model of multitask learning |
| 30 | 2022-07-28 | jeudi | vacances d'été | | | |
... | @@ -62,19 +62,35 @@ You can access the shared agenda: |
| 37 | 2022-09-15 | jeudi | | JOURNE Sébastien | JOURNE Sébastien | Bivariate signal decomposition with singular spectrum analysis |
| 38 | 2022-09-22 | jeudi | | | SIVIGNON Isabelle | Exact and optimal conversion of 2D digital object into a set of balls |
| 39 | 2022-09-29 | jeudi | | NGUYEN Quang Hung | Hashem Ghanem | Supervised Graph Learning with Bilevel Optimization |
| 40 | 2022-10-07 | jeudi | | SEJOURNE Charles | | |
| 40 | 2022-10-06 | jeudi | | SEJOURNE Charles | | |
| 41 | 2022-10-14 | jeudi | | | | |
| 41 | 2022-10-13 | jeudi | | | GJORGJESKI Martin | |
| 42 | 2022-10-20 | jeudi | | LEBEAU Hugo | | |
| 42 | 2022-10-20 | jeudi | | LEBEAU Hugo | LEBEAU Hugo | |
| 43 | 2022-10-27 | jeudi | vacances de la Toussaint | ZARROUK Tayeb | | |
| 43 | 2022-10-27 | jeudi | vacances de la Toussaint | | FLAMANT Julien | Seminar |
| 44 | 2022-11-03 | jeudi | vacances de la Toussaint | | | |
| 43 | 2022-10-27 | jeudi | vacances de la Toussaint | | ROUEFF Antoine | Seminar |
| 45 | 2022-11-10 | jeudi | | BENDJEDDOU Imaddedine | | |
| 44 | 2022-11-03 | jeudi | vacances de la Toussaint | | CANO Cyril | PhD Defense - Outils mathématiques et de traitement du signal pour l'étude polarimétrique des ondes gravitationnelles |
| 46 | 2022-11-17 | jeudi | | KERIVEN Nicolas | | |
| 45 | 2022-11-10 | jeudi | | | COMON Pierre | GAIA day - Numerical & estimation stabilities: two sides of the same coin ? |
| 47 | 2022-11-24 | jeudi | | | | |
| 45 | 2022-11-10 | jeudi | | | CONSTANTIN Alexandre | GAIA day - Réflexions sur les notions de degrés d elibertés pour le dimensionnement des réseaux de neurones |
| 45 | 2022-11-10 | jeudi | | | LE BIHAN Nicolas | GAIA day - Lycra, gravité et vibrations |
| 45 | 2022-11-10 | jeudi | | | COEURJOLLY Jean-François | GAIA day - The median of P(λ) + U([0, 1]) equals... |
| 45 | 2022-11-10 | jeudi | | | CABRAL-FARIAS Rodrigo | GAIA day - Algorithmes de factorisation booléenne de matrices binaires et applications |
| 45 | 2022-11-10 | jeudi | | | BROSSIER Jean-Marc | GAIA day - Boosting |
| 46 | 2022-11-15 | mardi | | | PILAVCI Yusuf Yigit | PhD Defense - Wilson's algorithm for randomized linear algebra |
| 46 | 2022-11-16 | mercredi | | | DESOLNEUX Agnès | Seminar - Maximum entropy distributions for image synthesis under statistical constraints |
| 46 | 2022-11-17 | jeudi | | KERIVEN Nicolas | IKEDA Shiro | Seminar - The images of blackhole shadows |
| 47 | 2022-11-21 | lundi | | | CHATALIC Antoine | CNRS Candidate - Nyström kernel quadratures |
| 47 | 2022-11-24 | jeudi | | | KERIVEN Nicolas | Work done at Gipsa |
| 48 | 2022-11-28 | lundi | | | BELHADJI Ayoub | CNRS Candidate - Some investigations on design problems for kernel-based approximations |
| 48 | 2022-11-29 | mardi | | | ADU-ALEXANDRU Dragomir | CNRS Candidate - Optimization methods for large non-quadratic problems |
| 48 | 2022-12-01 | jeudi | | ATTARD Pierre | | |
| 49 | 2022-12-08 | jeudi | | DERENTY CAMENET Gautier | | |
| 49 | 2022-12-05 | lundi | | | CASTERA Camille | CNRS Candidate - A second-order inertial algorithm for non-smooth non-convex large-scale optimization |
| 50 | 2022-12-15 | jeudi | | TREMBLAY Nicolas | | |
| 49 | 2022-12-08 | jeudi | | DERENTY CAMENEN Gautier | | |
| 50 | 2022-12-12 | mardi | | | CHERFI Roza | PhD Defense - Navigation en intérieur avec filtrage de Kalman et anti-développement |
| 50 | 2022-12-15 | jeudi | | TREMBLAY Nicolas | BENDJEDDOU Imaddedine | |
| 50 | 2022-12-16 | vendredi | | | EL BOUCH Sara | PhD Defense - Un test de normalité des séries temporelles mutlivariées: application à la sismologie |
| 51 | 2022-12-22 | jeudi | vacances de Noël | | | |
| 52 | 2022-12-29 | jeudi | vacances de Noël | | | |
| 01 | 2023-01-05 | jeudi | | | DERENTY CAMENET Gauthier | |
## Planned schedule - next cycle
| # Week | Date | Day | Comments | Expected Speaker | Actual speaker | Title |
