Commit f747a2e8 authored by Steffen Lackner's avatar Steffen Lackner
Browse files
[code] Implement data staging (communication between storage tiers)
parent 688ab155
...@@ -188,8 +188,55 @@ int execute_profile(BatsimContext *context, ...@@ -188,8 +188,55 @@ int execute_profile(BatsimContext *context,
double cpu = 0; double cpu = 0;
double size = data->size; double size = data->size;
// TODO // The PFS machine will also be used
xbt_die("TODO"); nb_res = 2;
int pfs_id = nb_res - 1;
hosts_to_use = std::vector<msg_host_t>();
// Add the pfs_machine
switch(data->direction) {
case MsgDataStagingProfileData::Direction::LCST_TO_HPST:
hosts_to_use.push_back(context->machines.pfs_machine()->host);
hosts_to_use.push_back(context->machines.hpst_machine()->host);
break;
case MsgDataStagingProfileData::Direction::HPST_TO_LCST:
break;
default:
xbt_die("Should not be reached");
// These amounts are deallocated by SG
computation_amount = xbt_new(double, nb_res);
communication_amount = nullptr;
if(size > 0)
communication_amount = xbt_new(double, nb_res*nb_res);
// Let us fill the local computation and communication matrices
int k = 0;
for (int y = 0; y < nb_res; ++y)
computation_amount[y] = cpu;
if(communication_amount != nullptr)
for (int x = 0; x < nb_res; ++x)
// Communications are done towards the last resource
if (x != pfs_id)
communication_amount[k++] = 0;
else
communication_amount[k++] = size;
string task_name = task_name_prefix + to_string(job->number) + "'" + job->profile + "'"; string task_name = task_name_prefix + to_string(job->number) + "'" + job->profile + "'";
Markdown is supported
0% or .
Please register or to comment
