Commit f5c628f1 authored by Millian Poquet's avatar Millian Poquet
Browse files
Use my SG fork to use SMPI
parent b81c3b2e
...@@ -68,7 +68,7 @@ test: ...@@ -68,7 +68,7 @@ test:
- cd /builds/batsim/batsim/build - cd /builds/batsim/batsim/build
- make install - make install
- ctest -E smpi - ctest
dependencies: dependencies:
- build:clang - build:clang
...@@ -109,7 +109,9 @@ please note it might be outdated. ...@@ -109,7 +109,9 @@ please note it might be outdated.
### Dependencies ### Dependencies
Batsim's dependencies are listed below: Batsim's dependencies are listed below:
- SimGrid (recommended commit: dccf1b41e9c7b) - SimGrid. dev version is recommended (dccf1b41e9c7 for example).
To use SMPI jobs, use commit 587483ebe of
[mpoquet's fork](https://github.com/mpoquet/simgrid/)
- RapidJSON (1.02 or greater) - RapidJSON (1.02 or greater)
- Boost 1.62 or greater (system, filesystem, regex, locale) - Boost 1.62 or greater (system, filesystem, regex, locale)
- C++11 compiler - C++11 compiler
...@@ -12,7 +12,7 @@ global: ...@@ -12,7 +12,7 @@ global:
backend: docker backend: docker
from_docker_image: oarteam/batsim_ci:latest from_docker_image: oarteam/batsim_ci:latest
to_docker_image: oarteam/batsim:latest to_docker_image: oarteam/batsim:latest
dir: /root work_dir: /root
batsim_commit: c9542e1c3ff5ffff batsim_commit: c9542e1c3ff5ffff
...@@ -28,7 +28,7 @@ global: ...@@ -28,7 +28,7 @@ global:
hostname: batsim hostname: batsim
work_dir: /root work_dir: /root
simgrid_commit: dccf1b41e9c7b # Wed Nov 30 14:08:01 2016 simgrid_commit: 587483ebe7882e # Fri Jan 6 15:45:05 2017
execo_commit: 75d668d execo_commit: 75d668d
bootstrap: bootstrap:
...@@ -22,7 +22,7 @@ ...@@ -22,7 +22,7 @@
- exec_in: | - exec_in: |
mkdir -p $${work_dir} mkdir -p $${work_dir}
cd $${work_dir} cd $${work_dir}
git clone https://github.com/simgrid/simgrid.git git clone https://github.com/mpoquet/simgrid.git
cd $${work_dir}/simgrid cd $${work_dir}/simgrid
git checkout $${simgrid_commit} git checkout $${simgrid_commit}
...@@ -41,7 +41,7 @@ fi ...@@ -41,7 +41,7 @@ fi
# Let's check that tests run correctly # Let's check that tests run correctly
echo -n "Checking whether tests pass..." echo -n "Checking whether tests pass..."
cd ${base_dir}/build cd ${base_dir}/build
ctest -E smpi ctest
failed=$? failed=$?
# Let's stop the redis server if it has been launched by this script # Let's stop the redis server if it has been launched by this script
...@@ -3,7 +3,7 @@ ...@@ -3,7 +3,7 @@
<!DOCTYPE platform SYSTEM "http://simgrid.gforge.inria.fr/simgrid/simgrid.dtd"> <!DOCTYPE platform SYSTEM "http://simgrid.gforge.inria.fr/simgrid/simgrid.dtd">
<platform version="4"> <platform version="4">
<config id="General"> <config id="General">
<prop id="network/coordinates" value="yes"></prop> <!-- <prop id="network/coordinates" value="yes"></prop> -->
<!-- Reduce the size of the stack_size. On huge machine, if the stack is too big (8Mb by default), Simgrid fails to initiate. <!-- Reduce the size of the stack_size. On huge machine, if the stack is too big (8Mb by default), Simgrid fails to initiate.
See http://lists.gforge.inria.fr/pipermail/simgrid-user/2015-June/003745.html--> See http://lists.gforge.inria.fr/pipermail/simgrid-user/2015-June/003745.html-->
<prop id="contexts/stack_size" value="16"></prop> <prop id="contexts/stack_size" value="16"></prop>
#!/usr/bin/python2
import argparse
def generate_flat_platform(nb_hosts, output_file):
hosts_id = range(0, nb_hosts)
#on Taurus with TimeNasEP_C
freqs = [
{"freq":2301000, "maxWatt":203.12, "moyWatt":190.738, "time":28.2},
{"freq":2300000, "maxWatt":180.5, "moyWatt":171.02, "time":31.7},
{"freq":2200000, "maxWatt":174.0, "moyWatt":165.62, "time":33.7},
{"freq":2100000, "maxWatt":169.25, "moyWatt":160.47, "time":35.0},
{"freq":2000000, "maxWatt":163.5, "moyWatt":155.729, "time":37.0},
{"freq":1900000, "maxWatt":158.12, "moyWatt":151.30, "time":38.9},
{"freq":1800000, "maxWatt":153.88, "moyWatt":146.92, "time":41.0},
{"freq":1700000, "maxWatt":149.25, "moyWatt":142.95, "time":43.6},
{"freq":1600000, "maxWatt":145.25, "moyWatt":138.928, "time":46.4},
{"freq":1500000, "maxWatt":141.0, "moyWatt":135.368, "time":48.1},
{"freq":1400000, "maxWatt":137.5, "moyWatt":132.519, "time":56.3},
{"freq":1300000, "maxWatt":133.5, "moyWatt":128.87, "time":57.3},
{"freq":1200000, "maxWatt":130.25, "moyWatt":125.88, "time":62.7}
maxx = freqs[0]["time"]
for f in freqs:
f["speed"] = 100.0*maxx/f["time"]
#ll = []
#for f in freqs:
#ll.append(f["maxWatt"])
#print ll
idle_watt = 95.0
watt_off = 9.75
time_on_to_off = 6.1
watt_on_to_off = 616.08/time_on_to_off
time_off_to_on = 151.52
watt_off_to_on = 18966.4228/time_off_to_on
speed_str = "Mf, ".join([str(f["speed"]) for f in freqs])+"Mf"
speed_str += ", 1e-9Mf, "+str(1.0/time_on_to_off)+"f, "+str(1.0/time_off_to_on)+"f"
sleep_pstates = str(len(freqs))+":"+str(len(freqs)+1)+":"+str(len(freqs)+2)
ll = []
for f in freqs:
ll.append(str(idle_watt)+":"+str(idle_watt)+":"+str(f["moyWatt"]))
ll.append(str(watt_off)+":"+str(watt_off)+":"+str(watt_off))
ll.append(str(watt_on_to_off)+":"+str(watt_on_to_off)+":"+str(watt_on_to_off))
ll.append(str(watt_off_to_on)+":"+str(watt_off_to_on)+":"+str(watt_off_to_on))
watt_per_state = ", ".join(ll)
header ="""
<?xml version='1.0'?>
<prop id="contexts/guard_size" value="0"></prop>
</config>
<AS id="AS0" routing="Vivaldi">
<host id="master_host" coordinates="0 0 0" speed="100Mf">
<prop id="watt_per_state" value="100:100:200" />
<prop id="watt_off" value="10" />
</host>
<!-- The state 3 of Mercury is a sleep state.
When switching from a computing state to the state 3, passing by the virtual pstate 4 is mandatory to simulate the time and energy consumed by the switch off.
When switching from the state 3 to a computing state, passing by the virtual pstate 5 is mandatory to simulate the time and energy consumed by the switch on.
hosts = "".join(["""
<host id="host"""+str(i)+"""" coordinates="0 0 0" speed=\""""+speed_str+"""" pstate="0" >
<prop id="watt_per_state" value=\""""+watt_per_state+"""" />
<prop id="sleep_pstates" value=\""""+sleep_pstates+"""" />
</host>""" for i in hosts_id])
footer = """
</AS>
</platform>
output_file.write(header)
output_file.write(hosts)
output_file.write(footer)
output_file.close()
def main():
parser = argparse.ArgumentParser(description = 'One-point-topology SimGrid platforms generator')
parser.add_argument('--nb', '-n',
type=int,
help='The number of computing entities to create',
required=True)
parser.add_argument('--output', '-o',
type=argparse.FileType('w'),
help="The output file to generate",
required=True)
args = parser.parse_args()
generate_flat_platform(nb_hosts = args.nb, output_file = args.output)
if __name__ == "__main__":
main()
Supports Markdown
0% or .
Please register or to comment
