Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
batsim
batsim
Commits
93cff1c6
Commit
93cff1c6
authored
Jun 21, 2017
by
Millian Poquet
Browse files
[code] codacy {} cosmetics
parent
c1eec28c
Changes
2
Hide whitespace changes
Inline
Side-by-side
src/batsim.cpp
View file @
93cff1c6
@@ -391,7 +391,9 @@ Other options:
main_args
verbosity
verbosity_level_from_string
args
"--verbosity"
asString
main_args
verbosity
args
"--verbosity"
asString
if
args
"--quiet"
asBool
if
args
"--quiet"
asBool
main_args
verbosity
VerbosityLevel
QUIET
main_args
verbosity
VerbosityLevel
QUIET
catch
const
std
exception
catch
const
std
exception
@@ -813,11 +815,17 @@ void set_configuration(BatsimContext *context,
// Let's override configuration values from main arguments if needed
if
main_args
redis_hostname
"None"
if
main_args
redis_hostname
"None"
redis_hostname
main_args
redis_hostname
redis_hostname
main_args
redis_hostname
if
main_args
redis_port
1
if
main_args
redis_port
1
redis_port
main_args
redis_port
redis_port
main_args
redis_port
if
main_args
redis_prefix
"None"
if
main_args
redis_prefix
"None"
redis_prefix
main_args
redis_prefix
redis_prefix
main_args
redis_prefix
// Let's update the BatsimContext values
src/jobs_execution.cpp
View file @
93cff1c6
@@ -127,7 +127,9 @@ int execute_profile(BatsimContext *context,
computation_amount
xbt_new
double
nb_res
computation_amount
xbt_new
double
nb_res
communication_amount
nullptr
nullptr
if
size
0
if
size
0
xbt_new
double
nb_res
nb_res
xbt_new
double
nb_res
nb_res
// Let us fill the local computation and communication matrices
int
k
0
int
k
0
@@ -345,8 +347,10 @@ int execute_job_process(int argc, char *argv[])
job
state
JobState
JOB_STATE_COMPLETED_KILLED
job
state
JobState
job
kill_reason
"Walltime reached"
job
kill_reason
"Walltime reached"
if
args
context
trace_schedule
if
args
context
trace_schedule
args
context
paje_tracer
add_job_kill
job
args
allocation
machine_ids
args
context
paje_tracer
add_job_kill
job
args
allocation
machine_ids
MSG_get_clock
true
MSG_get_clock
true
args
context
machines
update_machines_on_job_end
job
args
allocation
machine_ids
args
context
machines
job
args
allocation
machine_ids
@@ -404,7 +408,9 @@ int waiter_process(int argc, char *argv[])
XBT_INFO
"Sleeping done"
XBT_INFO
"Sleeping done"
else
else
XBT_INFO
"Time %g is already reached, skipping sleep"
args
target_time
XBT_INFO
args
target_time
send_message
"server"
IPMessageType
WAITING_DONE
send_message
"server"
IPMessageType
WAITING_DONE
delete
args
delete
args
Write
Preview
Supports
Markdown
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
