Commit 6b24e667 authored by Millian Poquet's avatar Millian Poquet
Browse files
[test] --batexec -> --no-sched
parent 75e983bc
...@@ -32,7 +32,7 @@ foreach(simu_instance IN LISTS simu_instances) ...@@ -32,7 +32,7 @@ foreach(simu_instance IN LISTS simu_instances)
add_test_robintest(NAME ${thistest_NAME} add_test_robintest(NAME ${thistest_NAME}
OUTPUT_DIR ${thistest_OUTPUT_DIR} OUTPUT_DIR ${thistest_OUTPUT_DIR}
BATCMD "batsim -p ${platform_filename} -w ${workload_filename} -e ${thistest_OUTPUT_DIR}/out --batexec" BATCMD "batsim -p ${platform_filename} -w ${workload_filename} -e ${thistest_OUTPUT_DIR}/out --no-sched"
SCHEDCMD "" SCHEDCMD ""
ROBINTEST_EXPECTATION "--expect-ctx-clean --expect-ctx-clean-at-begin --expect-ctx-clean-at-end --expect-robin-success --expect-no-sched --expect-batsim-success" ROBINTEST_EXPECTATION "--expect-ctx-clean --expect-ctx-clean-at-begin --expect-ctx-clean-at-end --expect-robin-success --expect-no-sched --expect-batsim-success"
Markdown is supported
0% or .
Please register or to comment
