Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
OSUG
RESIF
ws-eidaauth
Commits
47ca7b04
Commit
47ca7b04
authored
Jul 10, 2020
by
Jonathan Schaeffer
Browse files
Logging through Flask app
parent
78825940
Changes
1
Hide whitespace changes
Inline
Side-by-side
eidawsauth/eidawsauth.py
View file @
47ca7b04
@@ -12,23 +12,20 @@ from config import Configurator
from
version
import
__version__
logging
basicConfig
format
'%(asctime)s %(levelname)s %(message)s'
logger
logging
getLogger
__name__
application
Flask
__name__
if
os
getenv
'RUNMODE'
'production'
logger
setLevel
logging
INFO
application
logger
setLevel
logging
INFO
else
logger
setLevel
logging
DEBUG
application
logger
setLevel
logging
DEBUG
# Loglevel can be overrinden by LOGLEVEL env var :
if
os
getenv
'DEBUG'
'true'
logger
setLevel
logging
DEBUG
application
logger
setLevel
logging
DEBUG
else
logger
setLevel
logging
INFO
application
Flask
__name__
application
logger
setLevel
logging
INFO
application
config
from_object
Configurator
def
wsshash
login
password
Compute a hash suitable for the IRIS wss stack.
@@ -45,10 +42,10 @@ def verify_token_signature(data, gpg_homedir):
def
parse_input_data
data
# Then we get the token :
token
re
search
r
'{(?P<token>.*)}'
str
data
groupdict
'token'
logg
ing
debug
token
application
logg
er
debug
token
d
dict
i
for
i
in
kv
split
1
for
kv
in
token
replace
replace
split
logg
ing
debug
"Transformed to dictionary : %s"
d
application
logg
er
debug
d
return
d
def
register_login
login
password
@@ -65,9 +62,9 @@ def register_login(login, password):
user
application
config
'RESIFAUTH_PGUSER'
password
application
config
'RESIFAUTH_PGPASSWORD'
cur
conn
cursor
logg
ing
debug
"Connected to users database"
application
logg
er
debug
except
Exception
as
e
logg
ing
error
"Unable to connect to database %s as %s@%s:%s"
application
config
'RESIFAUTH_PGDATABASE'
application
logg
er
error
application
config
application
config
'RESIFAUTH_PGUSER'
application
config
'RESIFAUTH_PGHOST'
application
config
'RESIFAUTH_PGPORT'
@@ -99,9 +96,9 @@ def register_privileges(login, fdsn_refs):
user
application
config
'RESIFINV_PGUSER'
password
application
config
'RESIFINV_PGPASSWORD'
cur
conn
cursor
logg
ing
debug
"Connected to privileges database"
application
logg
er
debug
except
Exception
as
e
logg
ing
error
application
config
'RESIFINV_PGDATABASE'
application
logg
er
error
application
config
application
config
'RESIFINV_PGUSER'
application
config
'RESIFINV_PGHOST'
application
config
'RESIFINV_PGPORT'
@@ -111,19 +108,19 @@ def register_privileges(login, fdsn_refs):
for
ref
in
fdsn_refs
ref
'login'
login
ref
'expires_at'
datetime
datetime
now
datetime
timedelta
days
1
logg
ing
info
ref
application
logg
er
info
ref
sql_request
"select network_id from networks where start_year=%(startyear)s and end_year=%(endyear)s and network=%(networkcode)s"
try
cur
execute
sql_request
ref
except
psycopg2
Error
as
e
logg
ing
error
e
pgerror
application
logg
er
error
e
pgerror
else
if
cur
rowcount
1
logg
ing
info
cur
mogrify
sql_request
ref
logg
ing
error
"%d networks found for %s"
cur
rowcount
ref
application
logg
er
info
cur
mogrify
sql_request
ref
application
logg
er
error
cur
rowcount
ref
raise
NameError
f
cur
rowcount
networks found for
ref
ref
'networkid'
cur
fetchone
0
logg
ing
info
"Inserting tupple in %s.eida_temp_users: %s"
application
config
PRIVILEGEDBNAM
E'
ref
application
logg
er
info
application
config
RESIFINV_PGDATABAS
E'
ref
cur
execute
insert into eida_temp_users (network_id, network, start_year, end_year, name, expires_at) values (%(networkid)s, %(networkcode)s, %(startyear)s, %(endyear)s, %(login)s, %(expires_at)s);
ref
@@ -140,7 +137,7 @@ def cleanup():
Clean old temporary logins and passwords in both databases.
logg
ing
info
"Cleaning up expired temporary accounts"
application
logg
er
info
rows_deleted
0
try
conn
psycopg2
connect
dbname
application
config
@@ -149,14 +146,14 @@ def cleanup():
user
application
config
'RESIFAUTH_PGUSER'
password
application
config
cur
conn
cursor
logg
ing
debug
application
logg
er
debug
cur
execute
"delete from credentials where expires_at < now();"
cur
execute
"delete from users where expires_at < now();"
rows_deleted
cur
rowcount
conn
commit
conn
close
except
psycopg2
Error
as
e
logg
ing
error
e
pgerror
application
logg
er
error
e
pgerror
raise
e
try
@@ -166,13 +163,13 @@ def cleanup():
user
application
config
'RESIFINV_PGUSER'
password
application
config
cur
conn
cursor
logg
ing
debug
"Connected to privlieges database"
logg
ing
debug
"Deleting from privileges database"
application
logg
er
debug
application
logg
er
debug
cur
execute
"delete from eida_temp_users where expires_at < now();"
conn
commit
conn
close
except
Exception
as
e
logg
ing
error
e
pgerror
application
logg
er
error
e
pgerror
raise
e
return
Response
"Deleted %d expired accounts."
rows_deleted
status
200
@@ -180,23 +177,23 @@ def cleanup():
def
auth
login
password
logg
ing
debug
request
mimetype
application
logg
er
debug
request
mimetype
data
request
get_data
logg
ing
debug
"Data: %s"
data
application
logg
er
debug
"Data: %s"
data
try
data
application
config
'GNUPG_HOMEDIR'
tokendict
parse_input_data
data
logg
ing
info
"Token signature OK: %s"
str
tokendict
application
logg
er
info
str
tokendict
except
ValueError
as
e
logg
ing
info
"Token signature could not be checked: %s"
str
data
application
logg
er
info
str
data
return
Response
str
e
status
415
# Now we have a dictionary corresponding to the token's content.
# Verify validity
expiration_ts
datetime
datetime
strptime
tokendict
'valid_until'
'%Y-%m-%dT%H:%M:%S.%fZ'
if
expiration_ts
datetime
datetime
now
total_seconds
0
logg
ing
info
"Token is expired"
application
logg
er
info
"Token is expired"
return
Response
'Token is expired. Please generate a new one at https://geofon.gfz-potsdam.de/eas/'
status
400
logg
ing
info
"Token is valid"
application
logg
er
info
"Token is valid"
# Compute a random login and password
login
join
random
choices
string
ascii_uppercase
string
digits
k
14
@@ -209,13 +206,13 @@ def auth():
# Check membership and get FDSN references
fdsn_memberships
for
em
in
tokendict
'memberof'
split
logg
ing
debug
"EPOS membership: "
em
application
logg
er
debug
"EPOS membership: "
em
if
em
in
application
config
'EPOS_FDSN_MAP'
logg
ing
debug
" ... is in epos fdsn map"
application
logg
er
debug
fdsn_memberships
append
application
config
'EPOS_FDSN_MAP'
em
if
len
fdsn_memberships
0
logg
ing
debug
"FDSN memberships: %s"
fdsn_memberships
application
logg
er
debug
fdsn_memberships
try
register_privileges
login
fdsn_memberships
except
NameError
as
n
@@ -224,5 +221,5 @@ def auth():
return
"%s:%s"
login
password
if
__name__
"__main__"
logg
ing
info
"Running in %s mode"
application
config
'ENVIRONMENT'
application
logg
er
info
application
config
'ENVIRONMENT'
application
run
host
'0.0.0.0'
Write
Preview
Supports
Markdown
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
