Commit d10e33ef authored by Jonathan Schaeffer's avatar Jonathan Schaeffer
Browse files
Ajout de message sur erreur
parent 1ca4b48e
...@@ -207,13 +207,24 @@ def cli(configfile, force_scan, dryrun, verbose, version): ...@@ -207,13 +207,24 @@ def cli(configfile, force_scan, dryrun, verbose, version):
host=cfg['postgres']['host'], password=cfg['postgres']['password'], port=cfg['postgres']['port']) host=cfg['postgres']['host'], password=cfg['postgres']['password'], port=cfg['postgres']['port'])
cur = conn.cursor() cur = conn.cursor()
for stat in statistics: for stat in statistics:
cur.execute( try:
""" cur.execute(
INSERT INTO dataholdings (network, year, station, channel, quality, type, size, is_permanent, volume, date) """
VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s) INSERT INTO dataholdings (network, year, station, channel, quality, type, size, is_permanent, volume, date)
ON CONFLICT (network,year,station,channel,type,date) DO UPDATE SET size = EXCLUDED.size; VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s)
""", ON CONFLICT (network,year,station,channel,type,date) DO UPDATE SET size = EXCLUDED.size;
(stat['network'], stat['year'], stat['station'], stat['channel'], stat['quality'], stat['type'], stat['size'], stat['is_permanent'], stat['volume'], stat['date'])) """,
except psycopg2.Error as err:
logging.error(err)
logging.info(cur.mogrify(
conn.commit() conn.commit()
if __name__ == "__main__": if __name__ == "__main__":
Markdown is supported
0% or .
Please register or to comment
