Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
OSUG
RESIF
datadump
Commits
fae5167a
Commit
fae5167a
authored
Jul 09, 2019
by
Jonathan Schaeffer
Browse files
Nettoyage des messages
parent
78647ff8
Changes
1
Hide whitespace changes
Inline
Side-by-side
src/resifdatadump
View file @
fae5167a
@@ -26,7 +26,7 @@ zabbix(){
irods_rollback
irods_rollback
KEY
$1
KEY
$1
echo
$KEY
] Rollback : try to recover latest.tar from previous"
echo
$KEY
ils
KEY
/previous.tar
ils
KEY
/previous.tar
2>/dev/null
imv
KEY
/previous.tar
KEY
/latest.tar
imv
KEY
/previous.tar
KEY
/latest.tar
if
-ne
0
then
if
-ne
0
then
echo
$KEY
] Error
recovering latest.tar Exit 1"
echo
$KEY
] Error
@@ -35,7 +35,7 @@ irods_rollback(){
echo
$KEY
] Rollback : OK"
echo
$KEY
] Rollback : OK"
echo
$KEY
] Rollback : try to recover previous.tar from previous_to_delete"
echo
$KEY
ils
KEY
/previous_to_delete.tar
ils
KEY
2>/dev/null
imv
KEY
KEY
/previous.tar
imv
KEY
KEY
/previous.tar
if
-ne
0
then
if
-ne
0
then
echo
$KEY
] Error
recovering previous.tar Exit 1"
echo
$KEY
] Error
@@ -88,6 +88,9 @@ if [[ $? -ne 0 ]]; then
exit
1
exit
1
fi
fi
SIZE
stat
-c
%s
$RESIFDD_WORKDIR
$KEY
.tar
SIZEGB
stat
-c
%s
$RESIFDD_WORKDIR
$KEY
.tar
1024
1024
1024
# Creating remote directory if not exist
imkdir
-p
validated_seismic_metadata
imkdir
-p
if
-ne
0
then
if
-ne
0
then
@@ -96,7 +99,7 @@ if [[ $? -ne 0 ]]; then
fi
fi
echo
"[METADATA] If previous.tar exists, move it around but keep it safe"
echo
ils validated_seismic_metadata/previous.tar
2>/dev/null
imv validated_seismic_metadata/previous.tar validated_seismic_metadata/previous_to_delete.tar
if
-ne
0
then
if
-ne
0
then
echo
"[METADATA] Error 003 moving previous.tar around Exit 1"
echo
@@ -105,7 +108,7 @@ ils validated_seismic_metadata/previous.tar && (
echo
"[METADATA] If latest.tar exist, move it to previous.tar"
echo
ils validated_seismic_metadata/latest.tar
2>/dev/null
imv validated_seismic_metadata/latest.tar validated_seismic_metadata/previous.tar
if
-ne
0
then
if
-ne
0
then
echo
"[METADATA] Error 004 moving latest.tar to previous.tar Exit 1"
echo
@@ -113,7 +116,7 @@ ils validated_seismic_metadata/latest.tar && (
fi
fi
echo
"Push metadata archive"
echo
$SIZEGB
GB)
iput
-N1
$RESIFDD_WORKDIR
/validated_seismic_metadata.tar validated_seismic_metadata/latest.tar
iput
-N1
$RESIFDD_WORKDIR
if
-ne
0
then
if
-ne
0
then
echo
"[METADATA] Error 005 Something went wrong pushing validated metadata, Roll back"
echo
@@ -122,7 +125,7 @@ fi
# Cleaning
# Cleaning
irm validated_seismic_metadata/previous_to_delete.tar
rm
$RESIFDD_WORKDIR
rm
$RESIFDD_WORKDIR
echo
"[METADATA] Dump terminate :"
echo
d
ils
-l
ils
-l
@@ -160,12 +163,12 @@ for dir in $(find . -maxdepth 3 -type d | sort); do
zabbix
$KEY
zabbix
$KEY
continue
continue
fi
fi
SIZE
stat
-c
%s
$RESIFDD_WORKDIR
$KEY
.tar
1024
1024
1024
SIZE
stat
-c
%s
$RESIFDD_WORKDIR
$KEY
.tar
SIZEGB
stat
-c
%s
$RESIFDD_WORKDIR
$KEY
.tar
1024
1024
1024
# Check if file exists on irods server
irods_latest
ils
-L
$KEY
/latest.tar
ils
-L
$KEY
/latest.tar 2>&1/dev/null
echo
$KEY
] irods latest file is :
$irods_latest
# Latest archive exist, lets move it to previous.
if
-eq
0
then
if
-eq
0
then
echo
$KEY
] latest.tar already exists on iRODS server. Let's compare hashes"
echo
$KEY
local_sha
sha256sum
$RESIFDD_WORKDIR
$KEY
.tar |
awk
'{print $1}'
| xxd
-r
-p
base64
local_sha
sha256sum
$RESIFDD_WORKDIR
$KEY
.tar |
awk
'{print $1}'
| xxd
-r
-p
base64
irods_sha
ichksum
$KEY
/latest.tar |
awk
-F
'/sha2:/ {print $2; exit;}'
irods_sha
ichksum
$KEY
/latest.tar |
awk
-F
@@ -178,7 +181,7 @@ for dir in $(find . -maxdepth 3 -type d | sort); do
echo
$KEY
] idos checksum:
$irods_sha
echo
$KEY
] idos checksum:
$irods_sha
echo
$KEY
] Local checksum differs from last dump. Let's dump it"
echo
$KEY
# Put previous.tar aside in case we need to revover it.
ils
$KEY
/previous.tar
ils
$KEY
/previous.tar
2>/dev/null
irm
-f
$KEY
irm
-f
$KEY
imv
$KEY
/previous.tar
$KEY
imv
$KEY
/previous.tar
$KEY
if
-ne
0
then
if
-ne
0
then
@@ -191,7 +194,7 @@ for dir in $(find . -maxdepth 3 -type d | sort); do
if
-ne
0
then
if
-ne
0
then
# Something wrong moving remote file arround
echo
$KEY
] Error 009 something wrong moving
$KEY
/previous.tar, cancel iput."
echo
$KEY
$KEY
ils
$KEY
ils
$KEY
2>/dev/null
imv
$KEY
$KEY
/previous.tar
imv
$KEY
$KEY
/previous.tar
if
-ne
0
then
if
-ne
0
then
echo
"[KEY] Error 010 restoring previous.tar"
echo
@@ -202,11 +205,11 @@ for dir in $(find . -maxdepth 3 -type d | sort); do
fi
fi
fi
fi
# Send latest archive file to IRODS
echo
$KEY
] Sending latest.tar to iRODS (
$SIZE
GB)"
echo
$KEY
$SIZE
GB
GB)"
imkdir
-p
$KEY
imkdir
-p
$KEY
# Décommenter le bloc et les redirections pour traiter stdout et stderr différemment
iput
iput
--retries
5
-T
-K
-f
--retries
5
-T
-K
-f
-X
$RESIFDD_WORKDIR
/irods_restart
-N1
$RESIFDD_WORKDIR
$KEY
.tar
$KEY
/latest.tar
$RESIFDD_WORKDIR
$KEY
.tar
$KEY
/latest.tar
if
-ne
0
then
if
-ne
0
then
echo
$KEY
] Error 011 sending file to irods. The command was: iput --lfrestart
$RESIFDD_WORKDIR
$KEY
.lfrestart --retries 5 -T -K -f
$RESIFDD_WORKDIR
$KEY
.tar
$KEY
/latest.tar"
echo
$KEY
$RESIFDD_WORKDIR
$KEY
$RESIFDD_WORKDIR
$KEY
.tar
$KEY
/latest.tar"
@@ -216,10 +219,10 @@ for dir in $(find . -maxdepth 3 -type d | sort); do
zabbix
$KEY
zabbix
$KEY
fi
fi
# Cleaning up the safety previous file
irm
-f
$KEY
irm
-f
$KEY
2>/dev/null
echo
$KEY
] Sent successfully"
echo
$KEY
] Sent
$SIZE
bytes
successfully"
# TODO Checksums check
echo
$KEY
] Cleaning local generated tar"
echo
$KEY
rm
-f
$RESIFDD_WORKDIR
$KEY
.tar
rm
-f
$RESIFDD_WORKDIR
$KEY
.tar
$RESIFDD_WORKDIR
/irods_restart
done
done
echo
"Dump of validated data done"
echo
Write
Preview
Supports
Markdown
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
