... | @@ -14,7 +14,7 @@ We provide source code and examples for our application. |
## LoRa Mote application
You can find LoRA application on the following [link] (hhttps://gricad-gitlab.univ-grenoble-alpes.fr/Drakkar-LIG/WiSHFUL-LoRa-connector/tree/master/code/Projects/Multi/Applications/LoRa/End_Node)
You can find LoRA application on the following [link] (https://gricad-gitlab.univ-grenoble-alpes.fr/Drakkar-LIG/WiSHFUL-LoRa-connector/tree/master/code/Projects/Multi/Applications/LoRa/End_Node)
This code needs to be copied on the board for the project to work. You can use [pySerial](https://gricad-gitlab.univ-grenoble-alpes.fr/Drakkar-LIG/WiSHFUL/tree/master/examples/Get_Started_Examples/LoRaWan_Example/pyserial/pyserial-master) or directly copy, paste the code on the USB drive which appears after you plugin the module.
